Question about D-Link RangeBooster G DPR-1260 (DPR1260) Print Server
Connecting this print server
I am having problem connecting the DLink DPR-1260 Print Server to a Linksys Wireless - G, Model WRT54G Router
  • 1,879 Answers
Information you need about your wireless network :
SSID or wireless network name
If the wireless network is secured, the security type (WEP, WPA) and the key (passphrase)
install the print server or access the setup user interface using the above information.
Posted on Oct 02, 2008
    Master:
  • 763 Answers
At first see if the cables are correctly connected. install the driver camed with the linksys wireless if it has or see on the control panel the add hardware. see also the manual for compatibilities of your router.
CHARCOIS
    Sergeant:
  • 268 Answers
What kind of trouble are you having? Are you just having trouble with the initial setup? If that is the case you can chekc out this quick setup guide for the print server , has some pictures and what not should make the process a little easier.....
http://www.scribd.com/doc/493101/DLink-DPR1260-Quick-Install-Guide
Or have you already went through this and still have no connection? If not , let me know the details and we can definitly help you out!
    Sergeant:
    Champion:
  • 298 Answers
Try unplugging both and then plug in the router,let it reboot, then plug in the other and let them find each other. if that doesn't work let me know.
DLink DPR 1260 lost connection
Are the small printer icons lit up on the face of the PServer? Mine has recently started losing connectivity and simply unplugging the power and plugging it back in restores full function. Still looking for the reason it just started doing it though..
Mar 17, 2009 | D-Link Computers & Internet
Dpr-1260 onkly works when connected by ethernet cable
dpr-1260 searching for ap and connected keeps changing back and forth when I refresh.On dpr-1260 if status of wireless keeps changing from searching and connected, change wireless to WPA, instead of WPA2. even if you have WPA2 setup (as I did), if you choose WPA it will stay connected.
Jan 23, 2009 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Can't connect a Dlink 1260 Print server through my Linksys wireless G router
A couple of things to check for:
  • If the wireless network is encrypted on your router verify that you have the right encryption key programmed on the print server
  • You are connecting to the corret router (Verify the SSID of the network - SSID being the networks name)
  • Make sure you are in an acceptable range , not 500 feet away from the router
  • Verify that the print server has a connection to the printers connected to it
  • Try rebooting all of the equipment (router , server, printers)
Oct 02, 2008 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Without knowing more information, I can't give you exact instructions...however, in order to make the print server truly functional, it needs a dedicated IP address. Look through the settings on the print server interface (GUI) and see if you can assign it a local IP address (192.168.xxx.xxx, depending on your LAN setup).
Once you give it a dedicated IP address, you should be able to route print jobs through it.
Hope this helps - remember to rate :)
Problem with DPR-1260
this kind of problem occurs in dlink router sometimes & after some time router stop responding after 10 -15 min & once u reboot the router it again start work for a while. the best solution to this problem is to reset the router back to its factory defualt settings u can do this by press the reset button on the back on the router ( it looks like a small hole u have to use a pin for press that button) once u have reset the router to factory default settings just reconfig the router & i am sure it will start working fine in case u still face the same problem just contact D-link or send me the details about the problem & the physical setup of ur router & printer etc
Sep 28, 2008 | D-Link DPR1260 Rangebooster G...
Router and New Print Server Not Talking?
what hardware version and firmware is on router.you might need to update firmware depending on what firmware is on now.
Aug 15, 2008 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Printer eventually loses connection...
Try to upgrade the firmware revision to the last one (1.21).
I had similar problem with the dpr-1260 firmware rev 1.00.
Now after the firmware upgrade the problem seems solved
Nov 06, 2007 | D-Link RangeBooster G DPR-1260 (DPR1260)...
DPR 1260 will not work at all
I had the same problem earlier. Forget that I had MAC address filters setup. You might need to add your printer server's MAC. Then it should work. Mine did. Good luck
Nov 04, 2007 | D-Link RangeBooster G DPR-1260 (DPR1260)...
DPR-1260 ... prints but cannot access web config page
To get into the web configuration you need to know your firmware on the DPR-1260. If it is 1.12, us http://dlinkps-xxxxxx where the X's are the last 6 number of the mac address. If it is 1.20 and up, use http://dlink-xxxxxx, where the x's are the last 6 number of the mac address. If you do set it up as DHCP or static and know the ip address of the print server just type in the ip address of the print server on the address bar.
Oct 21, 2007 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Connect d-link print server with linksys router
you might need to set the Gateway on the router to match your ip on the print server.
Oct 07, 2007 | D-Link RangeBooster G DPR-1260 (DPR1260)...
D-Link RangeBooster G  DPR-1260 (DPR1260) Print Server Logo
159 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
