Question about Dishwashers
There seems to be an electrical fault in my dishwasher. It is a slimline candy dishwasher purchased only three years ago. Everytime I try to start it all the electricity goes in the downstairs of my house. I changed the fuse twice and it worked for a while only for the same thing to happen again. I also tried to turn off all other electical equipment downstairs to see if this made a difference, but it still didn't work. Would you have any idea what is wrong with it? Thanks. S. Byrne
  • 706 Answers
Hello sue by rne..
If your fuse blows when you are running the dishwasher alone, I would agree that your dishwasher may have a problem however becuse you stated that it works sometimes..I am more apt to believe that when you run the dishwasher in conjunction with other equipment on that same fuse that the overload condition happens because you've added that dishwasher to an already loaded circuit. The problem is that when you say that you turned off all other electrical equipment downstairs, you may or may not have shut off everything on the circuit the fuse feeds. If there is a way to isolate the dishwasher onto a seperate power feed that you know is not over-loaded then that would prove that the diwshwasher is ok or not.. If you aren't an electrician or trained in this, I suggest you get someone in that is. My initial impression of the problem from your description suggests that your dishwasher is OK but you are somehow overloading the circuit when other things are on.. Hope that helps...
Posted on Sep 30, 2008
What do I do with a one year old Frigidaire dishwasher that rinses and empties no matter what cycle it is set on. Jusy started doing this 2 weeks ago. I've tried everything in the instruction book?
I would personally contact fridgidaire direct or the retailer that you purchased it from and see what they suggest, sounds like an electronic fault in the control panel
Apr 03, 2016 | Frigidaire Dishwashers
Where can I buy new loading baskets for my DWI 160 dishwasher?
These come as several parts. Not sure if all are available anymore as Candy parts. But you can get replacement Hoover parts to fit.
Main basket from Candy
Candy DWI 160W UK Dishwasher Basket
Cutlery basket from Candy
Candy DWI 160W UK Universal Cutlery Basket
The Upper and Lower baskets may not be available from Candy but Hoover replacements are
Candy Use HVR41022779 Lower Basket
Best to ask Candy support to provide pictures of the parts for comparison with your model or purchase or a refund policy if not suitable.
There is another site worth checking (but prices seem high)
CANDY DISHWASHER BASKET LOWER for DWI160W UK
Sep 23, 2014 | Candy Dishwashers
Water doesn't heat up and cycle seems to be stuck, candy DFI 45
What is a Candy brand dishwasher? Made in the UK? That is not a manufacturer I have ever heard of here in the US.
What do you mean, 'doesn't seem to heat up any sense?'
If the dishwasher is older than 5 years, write it off to age a buy a new, high quality machine. Or do the dishes by hand.
Machines get old and die. If you are UK native, don't buy anothre Candy.
Aug 19, 2014 | Candy DFI Plan Built-In Dishwasher
Why is my Bosch SHE4AM15UC dishwashwer not heating water not sanitizing? How do I fix this problem?
The problem could be a failed heating element. If replacement of the control panel results in no change, the element could be the problem.
Jul 16, 2014 | Bosch SHE4AM15UC Dishwasher
I have a candy integrated dishwashed and when I set it to do a wash all it does is rinse for hours
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/PUMP MOTOR/DRAIN to work when it is commanded .Inthis case as the machine seems to work on and on it seems that the fault relates to the controller. It seems that the controller does not progress in the cycle and so goes on .
Check how to remove the control panel: http://www.espares.co.uk/advice/dishwashers/a/3/1287/how-to-replace-a-hotpoint-dishwasher-fascia-p.html
command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
Thank You for using Fixya
Aug 23, 2011 | Candy Dishwashers
Candy dishwasher 2 program lights keep flashing after program starts then stopas and flashing starts
My candy dishwasher Model No CDI 3015-S retains water in the bottom of the machine at the end of the program. I have checked the filter which is clear so do not know what else to do to clear the problem. Anyone faced this problem or know what might be the cause?
Jan 18, 2010 | Candy 17 in. CS455 Built-in Dishwasher
Candy GO1482 washing machine blows house fuse
u have an earth fault on mc caused by damp or water across the neutral check for water on electrical components
Nov 18, 2009 | Washing Machines
Dishwasher
its either the element or the motor, check element for visible signs of damage then if ok remove wires from it and ( making sure to insulate them ) and run the machine if it works then the element needs replacing. and if it doesnt then its the motor.
Jan 01, 2008 | Candy 24 in. CD622 Free-standing...
Open Questions:
Dishwashers Logo
93 people viewed this question
Top Dishwashers Experts
