Cd/rom drive door will not open. Running xp pro. I have(2)cd rom units,# 1 works great,# 2 the door will not open. The computer shows it to be working.
    Scholar:
  • 174 Answers
Take a long pin or straigten paper clip and find a hole infront on the drive insert it and gently push it till open.
Take care sometimes u see cd disc spin while it come out dont touch it until it stop
Posted on Sep 29, 2008
My cd-rom on dell Dimension 8250 pc desktop computer will not show up on my computer. Am i missing cd-rom drivers.
hello,
1.first go to http://support.microsoft.com/mats/cd_dvd_drive_problems
click on the green button that has run now
Run the microsft fix it tool
if it works GREAT! if not go to #2
#2 go to this site http://www.techsupportall.com/fixed-solved-cd-drive-not-found-not-detect-remove-upper-and-lower-filter/
follow instructions
IF THAT WORKS GREAT! if not proceed to 3
#3 turn off computer unplug power cord.
open your computer case unplug the cables that connect to the back of the cd rom. plug computer back in power it up. shut it down once it loads. then once it is powered down open case again and plug the cables back in make sure they are connected well. close case and power up the computer.
hope that helps
Nov 25, 2012 | Dell Dimension 8250 PC Desktop
Not seeing new hard disk or reading XP cd-rom
It can use any 31/2" IDE hard drive. 30 Gb should be OK
If the BIOS cannot detect the hard drive or the CD drive then the drives maybe faulty or the disk controller in the computer is faulty.
Apr 29, 2012 | IBM ThinkPad A30 Notebook
Can't get into any folder because c:Windows/System 32/rundll32 .exe keep popin up
To resolve this issue, follow these steps:
1.
Put the Windows XP CD ROM disk in the CD ROM drive.
2.
Click Start , and then click Run .
3.
Type expand X :\i386\rundll32.ex_ c:\windows\system32\rundll32.exe in the Open box, where X is the letter of your CD ROM Drive.
4.
Restart the computer
2.
3.
4.
1) Put the Windows XP CD ROM disk in the CD ROM drive.
2) Click Start , and then click Run .
3) Type expand X :\i386\rundll32.ex_ c:\windows\system32\rundll32.exe in the Open box, where X is the letter of your CD ROM Drive.
4) Restart the computer.
Oct 27, 2010 | Computers & Internet
Hi I have a Toshiba Tecra M2 laptop with Windows XP Pro SP3. My CD-RW/DVD-ROM/CD-ROM drive is not working. When I try to burn a disc, it says no recorder, or no disc in drive. Also, Windows doesn't seem to...
>> it says IDE #1 error when it boots up.
IDE #0 is your disk-drive.
IDE #1 is your CD/DVD drive.
So, take your computer to a qualified technician, to first check that the connectors (power, data) from the motherboard to the CD/DVD drive are good, and then, if necessary, to remove & replace the "dead" drive.
Oct 27, 2009 | Toshiba Tecra M2 Notebook
DVD rom restarts xp home
It is the problem of your motherboard check it out to workshop
May 18, 2009 | Sony (2450455) CD-ROM Drive
I HAVE LOST MY PRODUCT KEY OF WINDOWS XP SERVICE PACK 2
Windows XP Product Key from the Windows XP CD:
1) Insert Windows XP cd into a working computer.
2) Exit the Autorun introduction.
3) Open “My Computer”
4) Right Click on the Windows XP cd-rom drive and select explore.
5) Open the USWXP32P_ZX folder. (It may be as a hidden folder. If you cannot locate the folder, you may also search for unattend.txt and mark “Search Hidden Files”.)
6) Open the sysprep folder.
7) Open unattend.txt
Your CD’s product key is contained within the unattend.txt file.
May 05, 2009 | Microsoft Computers & Internet
VMware Tools Installation Problem
Use Ultra ISO or other VCD-ROM to mount the cd iso image on your hdd and map it in VMware F
Jan 04, 2009 | VMware Fusion Full Version for Mac
Dvd tray and cd tray won't open on hp pavillion a 250n
Did it work OK under XP Home ?
Did you do a clean install or Upgrade your sytem when you "upgraded" to XP Pro ?
Jun 18, 2008 | HP (176135-630) (176135630) Internal 48x...
Windows xp service pack 2
Hi 1. Click Start, click Run, type regedit in the Open box, and then press ENTER. 2. Locate and click the following registry key: HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\CDRom 3. To disable automatically running CD-ROMs, change the Autorun value to 0 (zero). To enable automatically running CD-ROMs, change the Autorun value to 1. 4. Restart your computer. NOTE: This method disables automatically running CD-ROMs. If you want to disable automatically running CD-ROMs depending on the CD-ROM that you insert in the CD-ROM drive, you can press and hold down one of the SHIFT key while you insert the CD-ROM. This may help. Good Luck
Sep 12, 2007 | Microsoft Windows XP Professional With...
Computers & Internet Logo
169 people viewed this question
David Payne
David Payne
