Washing machine overfilling - Washing Machines
    Problem Solver:
It is a Hotpoint AQ xxd 169. During the rinse cycle the washing machine overfilled and some water spilled on to the floor. The machine stopped and said it could not fill with water. The door showed the machine completely filled to the top. Tried the pump cycle but the door lock opened and the door burst open. Checked the filter and this was clean.
Posted on Nov 03, 2011
  • 750 Answers
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, your washing machine overfilling.
please give us more information .
What is the manufacturer and model number of your problem washer?
Thank you
Posted on Sep 29, 2008
My LG model WM1812CW washing machine is leaking water and says FE in the display
problem with the inlet valve or oppressor switch,because of the overfilling water, sawing FE ERROR
Jan 26, 2014 | LG Washing Machines
What eroor8 in weat point washing machine
Error 8 Washing machine has detected an
overfill situation This error code can be caused by
overfoaming which is a result of overloading (see this article) or by overdosing or, incorrect detergent as
the pressure sensor will falsely read
that there is too much water in the
washing machine. Also check the pressure sensor and
that the machine has not actually
overfilled with water. Check for overfoaming or over
soaping Check the air chamber and the
pressure switch hose Check water level sensor Check wiring to water pressure
sensor Check connections to water level
sensor Check main electronic controller
Jul 14, 2013 | Washing Machines
The wash machine stopped working and is flashing FL
FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
Jun 13, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
My washing machine stops
FL = Overfill
You should check your pump. If the pump is letting the washer overfill, replace it. Look around for some ways to take the cabinet off.
How do I fix my washing machine when it flashes FL on the screen
Apr 26, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Water didnt shut off at medium load. overfilled
Sonds like faulty pressure swith/ or hole in air pipe feeding switch/or chamber blocked feeding air hose..Good luck
Sep 30, 2009 | Washing Machines
OVERFILLED AND FLOODED HOUSE
1 of two problems happened.
1) either the water level sensor went bad. Which tells the water inlet valve when to shut off and the machine to start operating.
2) The water inlet valve has failed. This comes from the water hose and fills the washing machine.
May 25, 2009 | General Electric WCSR2090D Top Load Washer
Washer is overfilling & leaking
Are you using front loader only detergent?(oversudsing) Overfilling is either a pressure switch, or pressure chamber is blocked(located toward underside of outer bowl approx 6 inches long) this is only in older machines with extensive cold washes.
May 23, 2009 | Speed Queen ATS90AWN Front Load Washer
Washing machine overfills with water at start up after two years in use.
If the washing machine operates and cycles correctly, and only problem is overfills, then you have a bad water level switch or a bad membrane sensor (water level sensor).
If instead the machine get stuck on filling, and does not stop even if you advance timer, then the inlet valve is stuck on open, or the control board is faulty.
If machine is only two years old, call manufacturer and complain, even id limited warranty is one year, they may cover the part cost the same if they decide this was a factory defect (if it is inlet valve) coming up after two years.
Mar 17, 2009 | Whirlpool Washing Machines
Washing Machines Logo
223 people viewed this question
Top Washing Machines Experts
