Question about Sewing Machines
Thread pickup i have a vx-1120 basic sewing machine and my problem is that the needle will not pick up the thread from the bobbin.
  • sonneflwr Sep 29, 2008
    the needle is new and correct according to the book.
    New Friend:
  • 46 Answers
I don't know this machine but most machines....You are either using a bent, or incorrect needle. Size matters! If you have the correct needles and they are not damaged in anyway then it may be timing. Unlikely but possible.
one more thing...Are you turning the handwheel in the correct direction?
Posted on Sep 29, 2008
  • Bonnie  Spialek
    Bonnie Spialek Sep 29, 2008
    humm old is the machine? If it's not the needle than the only thing might be timing, of course depending on the machine. I wish I could tell you more but I only really know janomes.
How do I reset the timing on my brother vx 1120 model?
Be sure to install a brand new needle.
If it still doesn't work, then search for "sewing machine timing."
Jul 28, 2017 | Brother Sewing Machines
I have a brother vx1100 sewing machine and I forgot how to combine the bobin thread with the upper thread to start sewing please help
ono secret
just pull the bobbin thread down the slot in the bobbin holder and under the spring plate
leave about 6 " thread loose and put the bobbin and holder back in the machine
use you hand and turn the machine over a few times and the needle thread will pull the bobbin thread up
or use a bit of scrap material and start a short sew
Jan 15, 2017 | Brother Sewing Machines
My brother vx-1120 needle wont pick up bobbin thread to make a continuous stitch
Install a brand new needle. Make sure it is installed correctly.
Remove the bobbin/bobbin case from the machine. Check that the bobbin is turning the correct direction and the bobbin tension is threaded correctly. Reinstall the bobbin case and confirm that it is latched into place.
Retest your machine. Slowly turn the handwheel and watch the needle descend and see if it picks up the bobbin thread. If not, then there is probably a sewing machine timing issue. Take it for service.
Nov 01, 2016 | Brother Sewing Machines
Wont pickup bobbin thread when sewing.
Make sure you are using a brand new needle. Bent/damaged/dull needles frequently will fail to pick up the thread.
If it continues to skip stitches, it most likely has a needle/hook timing issue--the needle arrives at the bobbin at the wrong time to intercept the bobbin thread.
There are web sites and videos available that discuss sewing machine timing, or you can take it for service.
Sep 10, 2016 | Sewing Machines
The needle will not pickup the bobbin thread?
First, make sure to install a brand new needle. Damaged needles frequently will not pick up bobbin thread.
If a new needle doesn't work, then most likely the machine has a needle/hook timing issue (the needle is arriving at the bobbin at the wrong time to connect with the bobbin thread).
There are many web sites and videos explaining sewing machine timing. Or you can take it for service.
sewing machine timing Google Search
Jul 25, 2016 | Sewing Machines
Shuttle on a Brother VX-1120 sewing machine will not pick up the bobbin thread
Bobbin in backwards, needle in backwards, needle damaged, needle too small for the thickness of fabric or needle not the correct needle system for the machine are my first guesses. Try a new size 12/80 needle, flat of the needle to the back of the machine, completely up in the needle clamp as a first pass at the problem.
Feb 18, 2014 | Brother Sewing Machines
I have problems with not be able to pick up the thread from the bobbin to start sewing
Make sure the needle is not bent and is installed with the flat side of the needle shaft to the back of the machine.
Thread the machine with the presser foot up, with the thread going into the needle from the front ,
Check the manual to be sure you have the bobbin inserted correctly into the bobbin case and the thread is feeding in the proper direction and through the guides on the bobbin case.
Hold onto the end of the top thread at the needle and hand walk the needle down and back up. This should bring the bobbin thread up. Take both thread ends under the presser foot and to the back of the machine.
Place a folded scrap of fabric under the presser foot, lower the presser foot and hand walk the needle down into the fabric and then use the power pedal to start sewing.
Apr 08, 2010 | Singer 1120 Mechanical Sewing Machine
Brother VX-1120- The needle is not picking up bobbin thread.
I had the same problem with my brother vx-1120 sewing machine. I set the needle to lowest position by using the hand crank. Then I loosened the knerled set screw that holds needle in place. Then I moved needle shaft till the eye of needle is just lower than the hook on the shuttle loop maker. It made my mechine work. There are instuctions for ajusting timing on machine but I think these mechines are built to not fix and throw out. Just because there where no ajustment marks at all on machine, any machanical machine will needed to be ajusted sometime.
Jul 08, 2008 | Brother CS-8150 Computerized Sewing...
Bobbin thread will not pick up nor will dog feed rise
my Brother sewing machine model VX 1120 will not pick up the Bobbin Thread. Machine is fairly new with only several hours use. I have changed needles , tried different bobbins, cleaned the machine. Any suggestions?
Jul 06, 2008 | Sewing Machines
Sewing Machines Logo
66 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
