Question about Sony PlayStation 2 Slimline Console
Wat up hey my disk wont spin right at all ive tried cvuttin it off and let it cool diddnt work though so should ai take it back or clean it with anti freeze
    Novelist:
  • 111 Answers
It seems there has been a malfunction within your CD Drive, this is what is causing the CD drive to not spin or read the disc. these problems can be only generally resolved by either getting the console repaired/replaced unfortunately.
The PS2 will still turn on and run because the CD Drive does not dictate whether the console works or not, but because the CD Drive is broken, you will not be able to play games or watch DVD Films unless you have the CD Drive Repaired.
NOTE : I would not encourage you to use Anti-freeze on the console/discs under any circumstance, Anti-Freeze is designed to De-Ice Car windows, Not to fix technical issues With PS2's, It is very dangerous !
Hope this Helps ?!
Posted on Oct 27, 2008
Disk wont spin, but laser works
You need to put a small weight ontop of the disc drive and then it should work
Dec 04, 2011 | Sony PlayStation 2 Slimline Console
My 5 Disk CD player doesn't work. It wont read any kind of CD. The radio and Tape Decks still work though. How can I fix the CD player.
Hello Alison hi, we need to check two parts to see which is the problem section why your player wont read.
  1. Does your CD spins normally, check your player if the cd spins normally, if you can see the disk spinning, take note of the spin, is it to slow? An abnormal disk spin has problems with its spindle motor assembly.
  2. Does your CD spins and then slow down to a stops, did not read the disk. This is caused by two things, FIRST: your CD player lens needs cleaning, you can buy a CD lens cleaner and use it to clean the lens, SECOND: The lens has degraded or worn out due to use and time, this needs a replacement lens assembly.
This things are way beyond a normal user, I suggest you send it for service. Sorry, there are no user serviceable parts here.
Aug 19, 2010 | RCA RS1285 CD Shelf System
Hp pavilion dv1000 fan not working
Try to clean your fan with anti rust oil, maybe due to old age the mechanism inside your fan is already clogged.
http://podnutz-hdlaptoprepairvideos.blogspot.com/
May 26, 2010 | HP Pavilion dv1000 Notebook
My xbox 360 wont read discs, it makes 2 noises coming from the laser roughly and then spins for 0.05 seconds and then stops, ive cleaned the lens ive made sure its in perfect position everywhere ive turned...
the only thing i can say is to send it back into where you got it from and have them look at it... of course, it might be that you have left it on for too long, but i dont know if you have done that or not... i accidentally left mine on for a couple days while i was travelling, and it slowed the disk reading process down a lot... but that's all i can say...
Jan 10, 2010 | Video Game Consoles & Games
I took apart my xbox 360 and when i turned it back on i saw that the disc wasnt turning fast enough and it just saids open tray
the disk is not being spun more than likely. thats why i always get open tray. wat u need to do is this
1) unplug it all and take it apart
2) get to the disk drive
3)unscrew the 4 screws on the SIDES onf the drive. not the 2 in the middle 4)take off the cover GENTLY
5)put the drive back intoplace without the top on it
6)plug it up and turn it on
7) observe the disk want to spin but it wont. there is not enough pressure to get it going, wat u need to do it give it a little "push-start" spin it while applying pressure. it may take a few trys to get the disk going fast. it will need to start going very fast.
8) when it does that, quickly place the top back onto the drive without screwing it back on.
it should contunie to spin. turn it off, unplug it, screw the top back onto the drive, then reassemble the 360. works for me EVERy time
Jan 03, 2010 | Microsoft Xbox 360 Console
Wont read disc
Hello there... Sony seems a choosy brand so it looks like your disc is not recognized by it. Check also your disc for scratches or you just need to clean your disc first before you can use it. Try it. If this doesn't help, try inserting your disc to other CD-ROM. See if your disc is okay. Hope this helps...
Ai-ai :)
Dec 03, 2009 | Sony Computers & Internet
Lenovo Y410 auto shutdown
go to system properties & disabled system auto restart
Aug 30, 2009 | Lenovo 3000 Y410 Laptop
My pc refuse to install anti virus
The AI prevents your Anti Virus(AV) from installing. The Anti Virus requires that you uninstall the AI before you can install your AV. Have you tried installing other Anti Virus software rather than what you have?
What the AI in your system anyway?
Nov 18, 2008 | Microsoft Windows XP Professional
Ps2 game disk wont spin
you should buy one of those laser disks to clean the laser and inside of the ps2 so it will work again cause mine had same problem and i used that and after it worked
May 04, 2007 | Sony PlayStation 2 Slimline Console
Sony PlayStation 2 Slimline Console Logo
43 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
