Question about HP LaserJet 3330 All-In-One Printer
HP Laserjet 3330 with Windows Vista
I have been using HP Laserjet 3330 with Windows Vista. Everything seems to work perfectly except that I can not print on both sides of a paper -- ever after I select the appropriate option in the 'properties.' Is it possible to fix this problem?
Thanks,
NVO
  • N VanOrder Oct 06, 2008
    Thanks. I did not make it clear -- I was talking about manual printing. I know this printer does not print on both sides automatically. When I select 'print on both sides' option, it ignores this and prints all the pages consecutively i.e. it prints pages 1, 2, 3, 4, ... as opposed to 1, 3, 5, ...
    Thanks for your help.
  • 35 Answers
Find where you select either All or Range for the pages to print. Then in range instead of 1-10 : to print odd number pages type 1,3,5,7,9. Then when you want to print the back sides make sure they are in the right order and the 'to be printed on' side of the paper is correct. Then select Range again only this time type 2,4,6,8,10. It should then do the job right. Do not leave any spaces between the commas and the numbers. Good luck.
Ger.
Posted on Feb 18, 2009
    Scholar:
  • 116 Answers
No you cannot print on both sides automatically.you have to give the prints 2 times.at first the paper will print on 1 side then insert the same paper in the printer and give the remaining printout and it will print on the back side of the same paper.as you can do it manually but the automatic printing on both side facility is not in HP Laserjet 3330 printers.
Posted on Oct 05, 2008
HP LaserJet 3330 will not print multiple copies
Does this happen only with some documents/software? I have a different HP printer (a LaserJet) that does the same thing only with PDFs printed from another program. (This happens with PaperPort and browsers using the Adobe Reader plug-in, for example.) If I open Adobe Reader and then open the document in question, I can print multiple copies correctly.
I hope this helps.
Jun 14, 2012 | HP LaserJet 3330 All-In-One Printer
Problems with hp laserjet 3330
suspect either worn ADF(automatic document feeder) pickup roller or there is a jam in the ADF unit where the paper feeds to the scanner.
Mar 11, 2010 | HP LaserJet 3330 All-In-One Printer
Printer mispick and how to solve it? I tried to open the door to take paper out, but left a little piece there I believe since the paper was broken. Now, I can not print anything and can not find any piece...
Clearing a paper jam - (or leftover bits of paper)
The LJ 3380 may be shown in this tutorial from HP: (do not try any disassembly other than opening the product doors as suggested in this tutorial)
HP LaserJet 3330 Clear Paper Jams
If this info is helpful, please vote.
Dec 29, 2009 | HP LaserJet 3330 All-In-One Printer
Vertical Thick Lines accross papaer on a HP Laserjet 3330
So the "White lines" went away when you replaced the cartridge, and now you have "dark Lines"?
It sounds to me like you have yet another bad cartridge. Is it remanufactured/ compatible?
Although, they can perform very well, they can also be awful depending on the source.
Return it and get another one, or different brand.
Jun 19, 2009 | HP LaserJet 3330 All-In-One Printer
HP Laserjet 3330 printed dark page especially around the middle
Does this happen both when copying and printing?
For printing solution, try another toner cartridge.
If lines continue to appear when copying (primarily through the automatic feeder) then lift the auto feeder, and clean the glass -mainly the narrow piece on the left side.
please rate solution :)
Apr 07, 2009 | HP LaserJet 3330 All-In-One Printer
Bad fuser Laserjet 3380
hii..
is u 3380 fuser fixing film ok...if ok try to change presure roller..it below fixing film....you can take out the fixing firm or presure roller.just check the size only.if same u can combine it.
2.try to clean paper pick roller at 3380 printer..
Nov 11, 2008 | HP LaserJet 3380 All-In-One Printer
Mac vs The HP 3330 all in one printer..need help
Hi there ,
I have a HP laserjet 3330 but cant find a CD to install in on my PC , I am trying to download drivers but having so much trouble .
can you help plz?
Jun 27, 2008 | HP LaserJet 3330 All-In-One Printer
Why is it printong crooked?
The problem can be with the software program. May be the formating of that particular text has been accidentally changed to italic. Or print the same on a plain A4 paper or slightly bigger paper than the check and see if you get the same problem.
Apr 22, 2008 | HP LaserJet 1320 Printer
HP LaserJet 3330 All-In-One Printer Logo
307 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
