The front washer pump worked for awhile and recently quit. I bought the truck a month ago and filled the washer fluid with below freezing fulid. I didn't know what the previous owners put in so I tried to use up what was in there incase it froze. The rear makes a noise but neither he wiper nor washer pump work in back. and hasnt since I bought it. I checked all fuses and they are all fine. I want to be able to fix this myself and want to know how and maybe a good place to get the parts at a decent price.
SOURCE: front widshield washer fromm 1999 Cherokee doesn't work
Your rear bottle for the wipers should be at the back of the vehicle.Look in back for removable panel and bottle should be there.Turn your ignition on(no start)and activate rear washer Listen for the sound of the motor
SOURCE: Rear windshield washer motor works, but no fluid comes out
Rear washer may have it's own reservoir . Can you hear a pump humming when you activate the washer? Look in the under flooor compartment
SOURCE: Rear window washer not working.
it could a blockage at the spayer outside .take a safety pin and poke in the small hole outside.
to check the button remove,it from the dash take a
12volt tester check to make sure you have poweon one side
SOURCE: The front windshield washer fluid pump for me 2000
Check the wire harness to the windshield washer pump. The pump is located in the washer fluid reservoir, if the wires are good. Chances are the washer pump needs to be replaced and you can pick up the new pump st Auto Zone or Parts Source and they will have the step by step instructions for you to get the job done with common tools. Good luck and keep me posted.
SOURCE: The windshield washer fluid isnt coming out for
Yes there are two pumps located in the wiper fluid reservoir. If your in a bind, you can switch the plugs and small hose that go to them because they are both the same. The upper pump operates the back, and the lower pump operates the front. The back won't work until it gets replaced, but it beats driving backwards.
