Question about Hitachi DZ-MV730A DVD Camcorder
Finalizing the disc
When i go to menu it only has dic operations and does not show up with finalize
  • ferluchesi Sep 29, 2008
    I have the record on my computer and minidisc, but I don't get to finalizing!
  • 3 Answers
There is a cable with one end that plugs into the charger and the other end which looks and attaches the same way as the battery.
Posted on Dec 26, 2008
Push disk navigation then either the quick menu or the regular menu and it will say finalize BUT it will tell you you must use the ac adapter. They mean plug in the adapter because if you try to use the battery only it may go out and cause damage to the disk during finalization. How do you plug in the adapter to the camera and not the battery is the problem Im having.
Posted on Oct 12, 2008
I have the same problem,, Maybe we have the wrong ac charger???? I don't see anywhere on the camcorder that will connect with my ac adaptor. I have no manual, I got the camcorder from a fleemarket...
Posted on Oct 07, 2008
My centrios edw8020 dvr records o.k. but won't play dvd on any other dvd systems
If the disc is not "finalized" it will not play on other DVD players. The steps to finalize the disc are part of the DISC Utilities Menu. under "DISC OPERATIONS". Choose "FInalize DISC". Instructions refer to finalizing DVD=R disc, so you may want to try this type of disc first and see if it works. Says It can be used as DVD-Video disc but results are not guaranteed. You can not edit disc after finalizing, only playback.
Jan 28, 2014 | Centrios EDW8020 DVD Recorder
DVD Recorder is ruining the DVDs
Here is the link to the manual for LG DR1F9H
read pages 33&34
you may be using wrong
disc or wrong mode
Dec 13, 2007 | Televison & Video
Need to know how to finalize recorded disc so that it can be played in regular dvd player
You can record and finalize DVD+Rs one time. After you fill a DVD+R or
complete all the recordings you want on a single DVD+R, finalize it.
Otherwise, the DVD+R will play only on this Recorder.To play the Disc on
other DVD Players, you must finalize it first.
Once you finalize a DVD+R, you cannot record on it anymore or make
editing changes.Therefore, make sure the Disc is as you want it before you
finalize it.
Press SYSTEM MENU. Press
; to select in the top left
corner of the menu bar at the top of the TV screen.
Press CH-
9 repeatedly to select in the second screen,
then press
Press CH-
9 repeatedly to select Finalize disc. Finalize disc
appears in the menu only when an unfinalized DVD+R is in the
Recorder.
Press OK.
"Finalizing" will appear in the menu.The process may
take a few minutes.
When finalization is complete, the Index
picture screen will reappear.
You cannot unfinalize a DVD+R, and you cannot record or
edit the DVD+R after you finalize it.
A DVD+R will play on other DVD Players only after the
Disc is finalized.
Mar 22, 2011 | Philips DVDR75 DVD Recorder
How do you finalize disc in a dc100
To finalize the disk:
Select MENU --> then select: DISC OPERATIONS then select: FINALIZE then select: YES ... to go back to MENU
During the disk finalization, a progress bar is displayed. Close the MENU only AFTER the screen display returns to the DISC OPERATIONS menu
Feb 26, 2011 | Canon DC100 DVD Camcorder
CAN RECORD FROM VCR TO DVD+R, CAN PLAY DVD ON SAME, BUT CANNOT PLAY ON OTHER DISC PLAYERS. I THINK THAT THIS IS BECAUSE I AM NOT FINALIZING CORRECTLY. WHEN AND HOW DO I FINALIZE A NEWLY RECORDED DISC?...
Usually you finalize the disc after loading it with all the desired content (leaving a bit of space for the finalization). So if you are recording a TV show, depending on the setting (SP, LP, XP), you might finalize the disc after recording 4 1/2 shows. The How may vary by model but on my DVD recorder, I find the finalize command in the same menu area as adding a title and initializing a DVD-RW disc. So I press Setup to enter the OSD menu, then go down to Disc (looks like an optical disc) then right arrow to enter the sub menu. Then press down to Disc Finalize and the right arrow again and press enter. Select OK and Enter again. (RW discs can be unfinalized to add more content.) Then wait until the process is done.
I hope this helps.
Jul 09, 2010 | Philips Magnavox DVD/VCR Dual Player
There is no disc finalize operation on the menu, only initialze
You have to plug the unit into the wall before the finalize menu will show up in your screen.
Nov 13, 2009 | Canon DC210 DVD Camcorder
Finalizing
that's because u r in HDD mode. Change drive select to "dvd" , then "functions" will show: "disc setting" to include, disc name, pick menu, select first play, and Finalize.
Jul 17, 2008 | Panasonic DMR-E85H DVD Recorder
Cannot intialize/finalize mini-DVD in Canon DC210
The way to get it to finalize is like this:
1. turn it on
2. use cord.
3.move the on buttom to mode. it will show the recordings.
4. select a recording
5.press function butom. it will up bring several choices among "menu"
6. slect menu
7. it will give you all the chioces you need to title, finailize, protect and all needed to view the dvd
Any questions,
let me know.
OL
Jul 13, 2008 | Canon DC210 DVD Camcorder
Can not finalize a disc on the Hitatchi dz-mv730a camcorder
It must be plugged into wall power to finalize. You cannot finalize on battery power
May 29, 2008 | Video Cameras
Cannot finalize dvd-r
Have solved the finalized problem by simply looking on the Canon website and read that you have to plug the camera into the wall to do it! If only they simply put this in the manual!!! Goodluck!
Mar 01, 2008 | Canon DC95 DVD Camcorder
Hitachi DZ-MV730A DVD Camcorder Logo
734 people viewed this question
Top Hitachi Video Cameras Experts
jamie suver
Level 1 Expert
Are you a Hitachi Video Camera Expert? Answer questions, earn points and help others
