Question about Kodak 6800 Thermal Photo Printer
Mecha error 07
Tried to change the printer kit today and for some reason the printer gave me the error message which i have put on as my subject any idea's
  • 4 Answers
Mecha error 07 and 08 are malfunctions of the paper feed pinch motor located in the right side of the paper compartment. The paper feed pinch is the first roller to grab the paper when it feeds into the machine. This error is tricky. I will walk you through a few fixes.
The first fix is to just power cycle the printer and try to reload the paper. Occasionally the pinch arm will end up in the wrong position due to the printer stopping because the ribbon was empty.
The second fix is to check and make sure that the sensor arm is reaching both sensors on the motor. Sometimes the arm binds on the metal plate inside the paper compartment causing it to not reach the sensor.
The third fix is to start replacing parts. The two things to start with would be the sensors and, although rare, the motor itself. After those are ruled out the only other options are the wiring harness running from the sensors to the junction board, the junction board itself, the power cable running from the junction board to the controller board, and then finally the controller board itself.
Posted on Dec 08, 2008
I found the above advise helpful! Upon inspection of the paper feed area, I found that the last person loaded the paper incorrectly. All I had to do was adjust the roller and "SHAZAAMM!", all better. Thanks! I would check this first before making calls into Kodak and having them start replacing parts that cost far too much.
Posted on Mar 14, 2010
Mecha trouble problem cutter pos
- in my case I received the error "mecha trouble cutter pos"
I removed both side panels and the panel directly in front of the cutter
this gave me access to the cutter assembly where I found that the cable that runs the cutter had fallen off of the pulleys.
I was able to get the cable back onto the pulleys and now the printer works perfectly
Feb 20, 2012 | Sony UPDR150 Thermal Photo Printer
How to fix mecha error on sony mhc-gx555,-stops-responding,-or-displays-mecha-or
Jan 09, 2012 | Sony MHC-GX555 Mini Hi-Fi System Shelf...
i need best solution for mecha error 03 kodak printer 6800
Mar 15, 2010 | Kodak 6800 Thermal Photo Printer
Kodak printer 6800 mecha error 11
this is error created at ur printers cuter unit , so open the frot cover and clean the all 3 sensors
Jul 03, 2009 | Kodak 6800 Thermal Photo Printer
Mecha Error 12 on Kodak Photo 6800 printer
I had a 6850 with the Mecha error 12. No listing in the service guide for this error. I took the front of the printer off and observed that the cut head was not moving far enough to the left to trigger the sensor. I realized that a screw of unkown origin had fallen down behind the cut head and was preventing it from triggering the left sensor. It took a curved pick tool and a pair of tweezers to get it out. I don't recommend taking the cut assembly apart as the alignment is pretty crucial.
Hope this helps some poor sole from the hours of fustration that it gave me.
Apr 15, 2009 | Kodak 6800 Thermal Photo Printer
Mecha error o3
Mecha error 03 is a malfunction of the main pinch motor. Ninety-Five percent of the time the problem is that the motor has failed. The machine will more than likely have to be sent in for maintenance.
Nov 27, 2008 | Kodak 6800 Thermal Photo Printer
Error 1203
I would email Lexmark. Thus far they have been good about assisting with problems. I have found that the User's Guide does not have the info in for numbered error messages also. Mention this to Lexmark when emailing them! Hope this is of help to you.
Oct 27, 2008 | Lexmark X7170 All-In-One InkJet Printer
Kodak 6800 Thermal Photo Printer Logo
1,527 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
