Question about Panasonic Televison & Video
Panosonic DCMR-EX95V Shows "U61" and "self check not complete". Suggets press "enter" to eject DVD tray, then press power to restart. I have done this numerous times without success. Your suggestions please!
5 Suggested Answers
lambylamb
  • 113 Answers
SOURCE: Panasonic DVD RECORDER DMR-EX75EB
you have a jammed tray button, its really easy to fix, just take it down to a local dvd repair guy. I am one! and I quote a problem like this as about $15-20 and about 30min of your time :) good luck! p.s. if he/she charges more just take it to someone else!!!
Posted on Oct 09, 2007
  • 5 Answers
SOURCE: Model No'DMR-ES15 - U61problem
I get this message occasionally on my Panasonic DMR-ES15. It's actually a really simple fix. It occurs when there is a corruption in the disc which causes the recording mechanism to malfunction. There is a separate error message for this, however it is usually not detected until it's too late. When the recorder asks you to carry out the recovery process, do it. When the disc ejects, make sure you take the disc out that was in there when it occured and throw it away...it will keep happening because the disc is permanently corrupted. However, do not close the tray without a disc or the self-check will fail. Instead pop in a disc of the same format that the error occured in (if it was DVD+RW then put in a DVD+RW). It resolves the problem every time on the first try. (It only happened two times in a year and a half for me). As the manual says the unit is "NOT BROKEN".
Posted on Aug 11, 2008
  • 187 Answers
SOURCE: Panasonic DMR-EZ47VEB stuck on self check
Check IC in primairy power supply
Posted on Aug 29, 2009
SOURCE: Panasonic dmr-ez47v won't recover from u61 code
no solution sorry, I have same problem. any one else with same prob?. Thought panasonic was a good make, 18 months old and now knackered.
Posted on Jan 10, 2010
Demonic-2011
  • 467 Answers
SOURCE: I have a Panasonic DMR-EZ47VEB
U61 is a common fault in the Panasonic DVD recorders. It is generally a failure of the DVD-RAM drive and/or the digital controller board (in some cases it is both and both must be replaced together as a module). Unfortunately these are not repairable at individual component level; they would most likely need to be replaced and fitted by a qualified technician in an authorised Panasonic service centre. The only trouble here is the potential cost(s) involved (such as labour, the DVD drive, etc) - could be expensive and/or uneconomical. However, you can always submit your unit to a repair shop for a quote and a second opinion (on the costs of the replacement part(s) as well as estimated labour charges and the extent of the problem - this allows you to make an informed decision afterwards to get this fixed, but it is up to you.
The cost of a new DVD-RAM drive (if that is the actual problem, and not the board it is connected to) is quite high; anywhere between $130 US (for XVY1961 to suit DMR-ES35V/DMR-EZ47V models) up to $450 AU for the same device plus labour costs should you choose to have it replaced.
I assume you like your unit and want it working properly. If you do decide to deal with an authorised Panasonic service centre, ensure that when the work is completed they provide a detailed report, and some sort of warranty on that repair, especially if it involved replacing the DVD drive. Unless you have an extended manufacturer's warranty on this; which means it won't cost you anything to have it assessed and repaired fully.
Posted on Apr 22, 2011
Oct 09, 2007 | Televison & Video
I have a Panasonic DMR-EZ47VEB and after recording overnight next morning dicovered the machine had swiched off with the word"Hello" on the front display. When switched on the unit displayed the...
Apr 21, 2011 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic dmr-ez47v won't recover from u61 code faul. Unit keeps ejecting tray and switching off.
Dec 01, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
I load up my Panasonic DVD recorder and it has built in freeview as well. Every time i load up my box it comes with up with U61 error and the machine makes a funny noise while trying to load the DVD drive...
The unit is carrying out the recovery process without a disc in the tray. The unit detected an error while recording or playing without a disc in the tray. The recovery process restores the unit to normal operation. Have the unit power cord unplug for about 5 minutes, then reconnect. If issue still exist have unit service.
Sep 21, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Aug 29, 2009 | Televison & Video
My panasonic dvd recorder is showing error screen u61, but what ever i do it does not solve the problem, ''self check did not complete''
First is there a disk in the dvd drive? If so it must be removed. have you tried a factory reset? Press and hold the up and down channel buttons on the front of the unit until the unit displays BYE then after it shuts down unplug it from the AC outlet for about 30 seconds then try to turn it back on it should be back in the first time setup.
Jun 06, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
no comunication betwen control y dvd
May 11, 2008 | Panasonic DMR-EZ27K
May 23, 2007 | Panasonic DMR-ES10 DVD Recorder
Televison & Video Logo
35 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
