Question about Philips 55P8341 55" Rear Projection Television
Help phillips 43pp8421/69 rear projection
I cannot line up the convergence phillips 43pp8421/69 my screen is all red lines and when trying to manually fix i have two red crosses to try to line up with
  • Philips Master
  • 3,459 Answers
Get a convergence kit from www.TvRepairKits.com
Posted on Jun 06, 2010
Im having colour problems with my phillips 43in hdtv blue and red lines across the screen tried to aligne but didnt help any ideas wat i can do
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Nov 24, 2009 | Philips 55PP9363 55" Rear Projection...
My color wont line up it shows all 3 colors at once on the screen
Replce IC of convergance and check pheriparal componets on the convergence board
Sep 28, 2009 | Philips Magnavox 9P6034C 60" Rear...
Phillips 55 inch rear projection tv red convergence screwed up
Install the DPTV305_DPTV345 Chassis convergence repair kit. You can get the kit at the following link and it contains the parts plus instructions on CD.
http://www.tvrepairworld.com/
Jul 25, 2009 | Philips 60PP9202 60" Rear Projection...
Can not line up red convergence
The convergence chips are toast. This is a common problem. Goto the site www.TvRepairKits.com to get a repair kit with instructions.
Dec 22, 2008 | Philips 60PP9202 60" Rear Projection...
I have a phillips rear projection 51PW9303 red and green lines showing in the left corners and red line thru middle of screen, bottom of screen shadows and so does left top corner if numbers and...
sounds like youre describing a convergence problem. Do the letters look like theyre 3D? If so you will need to replace both Convergence ICs STK392-120 you can get replacements at the following link and they include installation instructions with pictures plus gree tech support. heres the link.
http://servicemanuals.vstore.ca/
Apr 24, 2008 | Televison & Video
Phillips rear projection tv model #60pp9202/17f
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Feb 25, 2008 | Philips 60PP9202 60" Rear Projection...
After replacing stk392-110 convergence chips
behind your front panel is two rows of small black knobs that adjust the lamps brightness and focus. a phillips screwdriver might be needed to turn them. you need to adjust the red guns focus.
Feb 09, 2008 | JVC AV-56WP74 56" Rear Projection...
Phillips 55in widescreen hdtv
you convergance amp is is shot
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 14, 2007 | Philips 60PP9202 60" Rear Projection...
Philips 55P8341 55" Rear Projection Television Logo
137 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
