Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Not rinsing or draining properly
I usually use the lower temperature settings and full spin but recently the clothes seem to need to be spun twice otherwise they are very wet when they come out. also there always seems to be a slight foamy residue during the spin which i'm sure can't be right. please help, kate
  • k8shea Oct 01, 2008
    thanks for that, how do i get at the filter.cheers. kate
  • 706 Answers
Hello Kate,
Chances are the drain system ( filter, hoses, pump or your house drain ) is restricting water flow out of the washer..Try using 1/3 to 1/4 of the detergent you normally use for a while ( it must be HE grade and not std because Std will suds up way too much). Clean the filter and run a few wash loads with only a few items in there.. You can stop midway thru and add a cup or two of white vinegar to clean the inner works of deposits.. run a few wash loads like that .,. then from now on..use HE detergent, and only a very small amount. DO NOT FILL THE DISPENSER TO THE FULL LINE.. Hope this helps.. Please get back to me if you've tried these things and you are still having a problem,..
Posted on Sep 30, 2008
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
Aug 15, 2015 | AEG Washing Machines
My whirlpool duet will go through full wash cycle and when it get to rinse it does full rinse but light for spin does not go on and it doesn't spin it stays in spin cycle (no light on) but it does not...
Hi
This issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Hope this helps... Please post back for any further assistance.
Daniel
Aug 28, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Hi, i have an AEG Lavamat 1100. Although the machine runs through the spin cycle, and shows the wash cycle as being finished, when i open the door there is still water in the bottom of the machine and the...
Hi bwileman435,
It may not be draining well, because it is dirty, did you clean the Drain Pump filter?
Please follow my below Tip on how to do it:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER
Kind Regards d")
* If this solution helped you, please rate it
Aug 05, 2011 | AEG Washing Machines
Clothes not clean after washing
Were the settings appropriate for the clothing?
The settings on the machine should be set properly for the load. Different fabric types require different wash/rinse temperatures, spin speeds, and wash times. Always follow the instructions printed on the fabric care label. The soil level needs to be set in accordance with the load type. Heavily soiled clothing will not come clean with a light soil level setting.
Was the proper detergent used?
If too much detergent is used, or non-HE detergent is used, the machine will not wash properly. Too many suds present during a wash decreases tumbling action and will not rinse out well. Furthermore, detergent residue built up in the machine over time will deposit extra detergent on clothes and deposit soil back into clothing.
Was the washer overloaded? If the machine is overloaded, the machine will not wash and rinse properly. When the washer is overloaded, the clothes have no room to tumble, and the cleaning performance of the washer is reduced. In addition, when the clothes are packed tightly inside the drum the detergent and water will not distribute evenly throughout the items.
Front loaders require regular maintenance to ensure optimum performance. If this maintenance is not followed, residue can accumulate in the drum resulting in detergent and soil being deposited back into clothing. This can also lead to odor and other issues. Perform the required maintenance regularly (once or twice a month).
Jan 11, 2011 | Asko W6021 Front Load Washer
We have a problem with the rinse cycle. I can't seem to get it to drain the water out of the cloths. I keep putting it on rinse and spin. Can anyone tell me how to get the washer to drain without going...
put it in spin only. Check the drain sump under the front lower panel to see if it is full of crud. Might even make some money as they love to collect change.
Oct 15, 2010 | GE WSXH208A Front Load Washer
Water fills to proper level but agitator doesn't come on instead there is a grinding noise, when I move control to just prior to rinse cycle water drains properly, but still just grinding or buzzing n
Hi, Do you know if the washer spins at all?
It sounds like the coupler has gone bad.
Please let me know if it spins at all.
I can send yyou instructions on changing the coupler.
Vic
May 28, 2009 | Whirlpool LTE6234D Top Load Stacked...
Won't complete cycle, stops at rinse. and can't get hot water.
Are you on well water? turn off the cold water to the washer and clean the screen filter out. do not leave filter out.
the machine probably has a cold only final rinse so it won't work properly.
Mar 22, 2009 | Kenmore 24032\24036 Top Load Washer
Admiral washing machine MOdel AAV7000AWW On any spin will not drain 1st time through
is this machine induction motor or carbon brush if it is the inductin you need to be looking at the capacitor and if it is carbon brush then change them you will find them mounted each side of the motor and the capacitor will be @ the top under the lid near the pressure switch good luck
Jul 24, 2007 | Admiral AW22 Top Load Washer
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
54 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
