Question about Asrock K7VT6 (K7VT6 RAID) Motherboard
Graffics accelerator failure
My computer shuts down and restarts with the error message "graffics accelerator refuses to accept driver commands"
    President:
  • 2,351 Answers
Hi Carpeteddy,
The ASRock K7VT6 motherboard does not have a intergrated graphics card onboard. So your 1.5V, AGP8X / 4X card needs replaced. It wouldn't hurt to uninstall the AGP's driver software, reboot the system & re-install the software. Check the manufactures web site for updated driver software before replacing it.
Link to ASRock K7VT6 MB: http://www.asrock.com/mb/overview.asp?Model=K7VT6
Here is a link to an XFX 1.5v AGP card:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2412161&csid=ITD&body=WARRANTY#tabs
The good part of XFX is its warranted for life!
Good luck Carpeteddy!
Questions?
Mike
Posted on Sep 29, 2008
Hi all , My HP laptop auto shuts down when i open microsoft words , why is this so ? can somebody pls help me ? I need todo some work on it urgently!! , Thanks !!
You will need to press the F8 key before windows starts to load then disable
the auto restart on error. That will allow you to read the error message and
someone may be able to guide you.
You could also try booting from the XP CD and run the recovery console (if
that's an option) once in the recovery console type chkdsk /r to correct any
errors & try booting again.
OR
Disable automatic restart on system failure. This should help by
allowing time to write down the STOP code properly. Right click on
the My Computer icon on the Desktop and select Properties, Advanced,
Start-Up and Recovery, System Failure and uncheck box before
Automatically Restart.
Do not re-enable automatic restart on system failure until you have
resolved the problem. Check for variants of the Stop Error message.
An alternative is to keep pressing the F8 key during Start-Up and select
option - Disable automatic restart on system failure.
If you are using a wireless keyboard and the F8 key does not work
substitute a wired keyboard and mouse for this exercise only.
Please prost your feedback.
May 19, 2010 | Computers & Internet
Pavilion dv7 keeps shutting down
  • This may not fix your issue but its worth a try ...let me know how it goes
  • If the computer appears to shutdown and then attempt to restart without displaying an error message, do the following to disable the automatic restart on error setting.
    1. Click Start , right-click Computer , and then select Properties .
    2. Click Advanced system settings , grant permission to continue if prompted, and then click the Advanced tab.
    3. Click Settings in the Startup and Recovery section of the Advanced tab.
    4. Deselect the Automatically restart checkbox under System failure .
    5. Click OK to close the Startup and Recovery window, click OK again to close the System Properties window, and then close the Control Panel window.
    6. Restart the PC.
    Disabling the automatic restart setting allows time to view the error message that displays on the screen. Contact the manufacturer of the program or device that is causing the error for specific information about the error message.
  • Jan 21, 2010 | HP Pavilion DV7-1232nr Notebook
    Need Graffic card drivers
    go to sapphiretech .com. google it then drivers and support. you will see graphics cards with three dropdown menus select radeon,series 9550 card 9550 then you will go where the drivers are. finally select the os and download the driver.
    Jul 18, 2009 | ATI RADEON 9550 Graphic Card
    Computer just shuts down
    Run an Error check on your computer. Process takes anywhere from 1 to several hours, depending on hard drive size, files on computer and number of errors needing to be fixed. Manual steps to run Chkdsk at the command prompt loadTOCNode(3, 'moreinformation');
    1. Click Start, and then Run.
    2. In Open, type cmd, and then press ENTER.
    3. Use one of the following procedures:
      • To run Chkdsk in read-only mode, at the command prompt, type chkdsk, and then press ENTER.
      • To repair errors without scanning the volume for bad sectors, at the command prompt, type chkdsk volume:/f, and then press ENTER.
        Note If one or more of the files on the hard disk are open, you will receive the following message: Chkdsk cannot run because the volume is in use by another process. Would you like to schedule this volume to be checked the next time the system restarts? (Y/N)Type Y, and then press ENTER to schedule the disk check, and then restart your computer to start the disk check.
      • To repair errors, locate bad sectors, and recover readable information, at the command prompt, type chkdsk volume:/r, and then press ENTER.
    Jun 04, 2009 | Acer Aspire RC500 PC Desktop
    Blue Screen on Windows XP
    Sometimes there are conflicts that cause errors to show up, I am glad you mentioned that no new hardware or software have been installed. That helps to rule out some things. At this juncture, if it only occurred once, reboot and don't worry. If you see it again, it will most likely tell you a error occurred at such and such a place and the computer will now shut down. If this happens try to write down the offending part or error and contact us again. However, it is always prudent to backup your computer. You can go in to the setup and look in you event log to see if it was a heat event that will cause your computer to shut down. Should this screen appears again, try the following:
    Check to be sure you have adequate disk space. If a driver is identified in the Stop message, disable the driver or check with the manufacturer for driver updates. Pay attention to the video adapters.
    Check for any BIOS updates. Disable BIOS memory options such as caching or shadowing. If you need to use Safe Mode to remove or disable components, restart your computer, press F8 to select Advanced Start up Options, and then select Safe Mode.
    Tech Information:
    *** STOP: 0x0000007E (0xC0000005, 0xF85F9AD9, 0xF898B7A4, 0xF898B4
    please leave me a rating...
    May 15, 2009 | Microsoft Windows XP Professional
    Load Directx error when starting command and conquer tiberium
    Firstly, check that you have latest graphics driver or not.
    If not then download the latest driver from www.nvidia.com.
    After that remove your old graphics driver and install the latest graphics driver and then install the latest DirectX 9.0c also.
    Note : After each and every installtion just restart you machine.
    Feb 09, 2009 | EA - Electronic Arts Command & Conquer 3:...
    Web cam causing errors on my computer
    It is probable there is a camera hardware failure for the Live Cam.
    1. Try uninstall the drivers
    2. Restart computer.
    3. Install CD Drivers FIRST!
    4. Then plug in the camera.
    5. If still hangs, check with Creative in your country for warranty issues.
    Dec 30, 2008 | Creative Labs Creative Webcam
    My computer won't shut down it just keeps restarting
    The most common shut down problem is that the system will reboot rather than shutting down. In most cases, the reboot is triggered because Windows XP is designed to reboot after a critical failure. To stop windows from rebooting in case of a failure, you need to take the following steps:
    Right click on My Computer, Select Properties, Click on advance tab, Click on Settings under Startup and Recovery, Uncheck the option Automatically Restart under System failure, Click Ok twice and try to shutdown the pc. If it shows any error code then let me know
    Nov 24, 2008 | Toshiba Satellite M65-S809 Notebook
    System failure blue screen,error message. used recovery disks successfully. updated computer and service pack 2. i shut down computer and restarted it and it crashed again. redid recovery/formatting...
    Usually a device driver wrong. Check hardware divices. If yellow with exclamation driver needs to be loaded ith correct driver before next crash. Then reboot and test.
    Feb 28, 2008 | Computers & Internet
    Asrock K7VT6 (K7VT6 RAID) Motherboard Logo
    117 people viewed this question
    Top Asrock Computers & Internet Experts
    David
    David
    Computer Links
    Iqbal Husain
    Iqbal Husain
    Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
