Question about Maytag Legacy Series Top Load Washer
Leak washer keeps filling after finished everything else woprks fine
    Novelist:
  • 177 Answers
You may need a new water valve. Turn the water off at the wall or source.
Replace the water vavle. You can go on line and order parts from almost any source. I like repairclinic and partselect go to Google and google your Manufactures name and parts, ex Maytag parts.
You will need your model and serial number.
Posted on Oct 02, 2008
My 7kg Electrolux front load washer keeps stopping from between 1 to 14 minutes before it finishes. I have to keep coming in to press restart button. It keeps saying ERR 10. What does this mean?
Family alarm code E10 means difficulty in filling during wash phase or water leakage.
Could be:
E11 - Tap closed or water pressure too low; Drain tube improperly positioned; Water fill solenoid valve is faulty; Leaks from water circuit on pressure switch; Pressure switch faulty; Wiring faulty; PCB faulty.
E13 - Drain tube improperly positioned; Water pressure too low;
Water fill solenoid valve is faulty; Water circuit on pressure switch is leaking/clogged; Pressure switch faulty.
Dado
Jan 03, 2018 | Electrolux Washing Machines
Lights keep flashing and door locks without finishing cycle
Kenmore HE2 Plus Front Load Washer Keeps unlocking ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
flashing prewash and add garment lights My HE2 Plus will fill with water, but when ...Kenmore HE3 2plus wont finish cycle Washer wont finish the last1 minute of cycle. ...We ran a load twice and it still did not unlock. du is the code for cannot ... Why does the door keep unlocking and locking in between the drum rotating?
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
https://www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your Admiral Top Load Washer that has these following symptoms: Not Completing all Cycles ...
Washing machines - Ariston
Jan 05, 2016 | Washing Machines
Washer wouldn't stop filling and leaks
Hello, here is a great link to check out everything you can think of on your washer repair and trouble shooting. Make sure you really check out the different areas to click on on this site..
Here is the link. I hope this helps you, mike
http://home.howstuffworks.com/how-to-repair-a-washing-machine.htm
Oct 20, 2011 | Whirlpool LCR5232H Top Load Washer
Smoke from under hood
Let it cool down, then, open the radiator fill cap and add coolant, being careful not to spill any. Then, carefully look for any leaks. Once the leak has been located, replace whatever is causing it, re-fill again and start the engine and re-check everything. It is OK to use water for testing. Once you are satisfied that the problem has been corrected, drain the system and replace the thermostat (they become unreliable after an overheat) then re-fill the system using antifreeze. While re-filling keep the heater on high heat to remove trapped air. Use enough antifreeze to restore a 50/50 mix (they sell little ball type testers for under $5.00). It's good to be exact but don't drive yourself crazy getting it perfect...close is fine.
If after the repair is finished you see any white smoke from the tailpipe then you have blown your cylinder head gasket (big job) Hope that's not the case!!!
Good luck!!
Jun 19, 2010 | 2003 Jeep Grand Cherokee
I have a Maytag washer, once it is finished washing and spinning and stops running, water keeps dripping into the washer. Why? In a day or so it will almost fill up with water.
First turn the water off at the wall. You have a bad mixing valve.
Write down your model number and then do a google search for Maytag parts. I like Partselect.com and Repairclinic.com both are reputable sites.
Dec 30, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Leaks out when it is filling.
Make sure the drain hose is higher than the top of the washer tub.
Sep 21, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite HE3 washer keeps filling with water
The inlet valve will need to be replaced. Its a fairly simple procedure and a pretty inexpensive part.
Nov 15, 2007 | Kenmore Elite 45986 Front Load Washer
Drum filling up with water when not in use.....
only source is leaking inlet valves and only way to cure is to replace
May 14, 2007 | Tricity Bendix AW1000W Front Load Washer
Washing Machines Logo
61 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
