Question about Lexmark X5470 All-In-One InkJet Printer
Missing edge of scanned object
When I scan a piece of letterhead the very top edge of the logo is missing. I've tried turning the original the other way around, but it still happens. Any ideas
    Problem Solver:
  • 7 Answers
Position the document on the corner of the flatbed scanner that has arrow signs.
Posted on Oct 10, 2008
Scan option is missing all of a sudden
Unplug the USB cord, if it's not a wireless printer, uninstall, and reinstall the software and see if this corrects it...
Mar 19, 2014 | HP PhotoSmart 7515 e-All-In-One Wireless...
How to use the *2670 lexmark scanner
Please follow the steps below on how to scan using your Lexmark X2670 printer:
Using the printer control panel
1. Open the top cover, and then load an original document face down on the scanner glass.
2. Close the top cover to avoid dark edges on the scanned image.
3. Make sure that the printer is connected to a computer, and that both the printer and the computer are on.
4. From the printer control panel, press the scan button.
5. Follow the instructions on the computer screen.
Using Windows
3. Do one of the following:
• In Windows Vista, click > All Programs, and then select the printer program folder from the list.
• In Windows XP, click Start > Programs or All Programs, and then select the printer program folder from the list.
4. Click Lexmark Productivity Studio.
5. On the main screen, click Scan.
6. Follow the instructions on the screen.
Using Macintosh
3. From the Finder desktop, double-click the printer folder.
4. Double-click the 2600 Series Center.
5. From the "What is being scanned?" list, choose the type of document to be scanned.
6. Click Scan.
Source: Lexmark X2600 Series User's Guide
Oct 09, 2011 | Lexmark X2670 All-In-One Printer
Active x is not working propperly and we are missing dll's
you can delete all the downloaded controls and make the web page redownload them. there is one option in the delete history (cookies, temp internet files etc) section of Internet Explorer options which you can view objects with. There you will find all the objects. delete all those objects and try those web site again. if the issue persists, you can try scan system files with SFC too. It can be run from command prompt sfc /scannow
Sep 09, 2010 | Computers & Internet
In copy mode I am getting a back strip along the left hand side of the copy. The strip also shows up in the preview. Strip used to be half inch thick and is now an inch thick.
Is any part of the image missing under this black strip, or is it just margin from the side of the document to the end of the glass?
If nothing's missing, then probably you set a larger original size in the settings somewhere.
Try a sheet of white paper the size of the glass, put on top of the (smaller) copied picture or document; when scanning it is not a big deal, you can always choose the area to be scanned, right?
If however part of the document is missing, this can mean that the photosensitive element is faulty and doesn't read a couple hundred pixels on that side and the device needs repair.
Oct 27, 2009 | HP Photosmart 2575 All-In-One InkJet...
White lines across my scanned images
I had the exact same problem! the problem seems to be with the CCD calibrating itself before it starts to scan.
If you look into the scanner, the scanner glass extends itself into the casing of scanner where the CCD rests. Every time before the scan starts the CCD starts to calibrate itself in its housing before it starts to scan. If there is any reminiscence of dust or anything object (like a piece of paper) stuck in the edges where the CCD rest, the white balancing is thrown off and it causes white lines to appear along the entire line where the dust was present.
Ideally the solution would be to open the scanner casing to clean the housing where the scanner CCD rest. This would solve the problem.
If you are unable to open the scanner casing, then try using a piece of paper or a thin edge of a cloth, slightly dampened to reach into the edge of the scanner glass where the CDD rests and clean it. This is what i did and this solved the problem.
Jul 09, 2009 | HP PhotoSmart C4385 All-in-One Printer
Printer will not scan pictures.
Introduction To use the scan features, the HP All-in-One and computer must be connected to each other and turned on. The HP All-in-One software must also be installed and running on the computer prior to scanning. To verify that the HP All-in-One software is running on a Windows computer, look for the HP Digital Imaging Monitor in the system tray at the lower right side of the screen, near the time. NOTE: Closing the HP Windows system tray icon can cause the HP All-in-One to lose some of its scan functionality and result in a No Connection error message. If this happens, correct it by restarting the computer or by starting the HP Image Zone software. Follow the instructions below to scan documents from the all-in-one to an application. Make a Scan Step one: Load paper
  1. Open the paper tray door. Figure 1: Opening the paper tray door c00315283.gif
  2. Pull the paper tray extender toward you, as far as it will go. Flip the paper catch at the end of the paper tray extender to open the extender the rest of the way. WARNING: Legal paper might get caught on the paper tray extender if it is fully extended when you print onto legal paper. To avoid a paper jam when using legal-size paper, do not open the paper tray extender.
  3. Squeeze and hold the tab on the top of the paper-width guide, then slide the paper-width guide to its outermost position. Figure 2: Sliding the paper-width guide to the outermost position c00315284.gif
  4. Tap a stack of paper on a flat surface to align the edges, and then check the paper for the following:
    • Make sure it is free of rips, dust, wrinkles, and curled or bent edges.
    • Make sure all the paper in the stack is the same size and type.
  5. Insert the stack of paper into the paper tray with the short edge forward and the print side down. Slide the stack of paper forward until it stops. NOTE: If using letterhead, insert the top of the page first with the print side down. For more help on loading full-size paper and letterhead, refer to the diagram engraved in the base of the paper tray. Figure 3: Inserting paper into the all-in-one c00315285.gif Squeeze and hold the tab on the top of the paper-width guide, then slide the paper-width guide inward until it stops at the edge of the paper. Figure 4: Sliding the paper-width guide to the edge of the paper c00315286.gif Do not overload the paper tray; make sure the stack of paper fits within the paper tray and is no higher than the top of the paper-width guide.
Step two: Load the original NOTE: Many of the special copying features will not work correctly if the glass and lid backing are not clean.
  1. Lift the lid and place the original face down on the left front corner of the glass, with the sides of the original touching the left and bottom edges. NOTE: For more help on loading an original, refer to the guide engraved under the glass.
  2. Close the lid.
Step three: Scan to an application NOTE: To use this feature, you must have installed the full software package and the HP Digital Imaging Monitor must be running.
  1. Press Scan on the control panel. A preview image of the scan displays in the HP Document Viewer window on the computer, where you can edit it.
  2. Click Done or Finish in the software. The HP All-in-One sends the scan to the HP Image Zone software, which automatically opens and displays the image.
NOTE: To stop scanning, press the Cancel button on the control panel, or in the HP Image Zone software, click Cancel . Have a good day,
Jun 18, 2009 | HP PSC 1410 All-In-One InkJet Printer
Nuance omnipage 17. Can anyone give me a step by step guide how I can keep my coloured letterhead intact whilst adapting as rules change the rest of the document. Thank you Regards
hi jwmikey
here is the manual for the software. you can find what you need beginning with page 37 onwards.
http://www.nuance.com/imaging/resources/quick-reference-user-guides.asp
http://www.nuance.com/imaging/pdf/ug_OmniPage17UserGuide.pdf
hope this helps.
regards,
voodoo
Jun 10, 2009 | Computers & Internet
Control panel icons and properties tab are not working
The first step is to scan for spyware. These nasties can alter system files. Download MS Antispyware and Ad Aware and scan or spyware.
Also run a system file checker command to update any missing files Go to Start>Run>type "sfc /scannow" without quotes.
Note: it is advised to keep the original windows CD handy while prforming SFC \scannow as it tries to update the missing/ corrupt files.
Regards,
Arpit
Apr 19, 2009 | Computers & Internet
Lexmark X2500 driver is missing OCR software
Sometimes companies only support only the basic drivers. The OCR software is on the CD (s) that came with the printer. Suggestion. Try to order the original CD from Lexmark., or search Ebay for programs that have OCR capability. You can use OCR programs from other vendors as long as they are stand-a-lone programs. Just make sure you have the original disc so as not to infringe on copyright privileges.
Note: you can buy OCR programs. Check Ebay and Amazon. They are usually better that the programs that come on the OEM disk.
Cheers.
Mar 27, 2009 | Lexmark X2500 All-In-One Printer
Lexmark X5470 All-In-One InkJet Printer Logo
37 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
