Question about Panasonic TC-32LX60 32 in. LCD Television
L c d panasonic
Can you mount your television above the fire as this is the best wall?
    Genius:
  • Panasonic Master
  • 1,689 Answers
It is strongly suggested to NOT mount any Plasma or LCD TV above or near to a fire place!!! These are very sensitive to heat when it comes to their lifespan.
Jerry G.
Posted on Oct 22, 2008
I have a panasonic viera plasma tv model number TC-P60U50, where on tv do I put brackets to mount to the wall?
You will need to purchase a suitable wall mount separately. (You'll need one for LARGE TVs.) On the back of your TV set you'll see there are 4 holes in the lower-central region of the rear panel. They are about 20" apart (left-right) and about 12" apart (up-down) These should match up with the bracket that comes with your wall mount. You will need M8 metric screws that are about 1.25" long. These will also be included with the wall mount. (Which will include some general directions for wall mounting.)
Here is a manual for your TV:
PANASONIC Viera TC P60U50 Owner Manual Page 7
Feb 09, 2016 | Panasonic Televison & Video
WHERE CAN I GET A TILT BRACKET FOR MY PANASONIC PLASMA TV MODEL TH-50PX50U?
Well, the best and cheapest I have found was Walmart. However, most electronic stores like Radio Shack or Best Buy also carry these items.
Jul 13, 2014 | Panasonic Silver Tilt/Tilting Wall Mount...
How do I replace the main board on Panasonic TC-55ST50 tv?
Replacing main board is a skilled work, as it might need a firmware update, and other adjustments. It will be best to contact any service technician. Contact the authorized service center for Panasonic, to buy a genuine main board.
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 11, 2014 | Universal Heavy Duty Easy To Install...
Can you give me some advice on, how to mount a 46in tv above my non working fireplace mantle?
You would have to use a mounting bracket specifically designed for the type of installation you describe and it certainly would have to be fastened into the studs behind the sheetrock. A TV of that size will be heavy to lift and install in the bracket
Mar 04, 2013 | Universal Bedroom Mounting Bracket For...
How do i mount my panasonic tx-l26x10b on the wall. no fixing holes
drill holes put in wall plugs fix bracket insert and tighten screws
Aug 07, 2012 | Panasonic Televison & Video
How do i remove the stand/base off a panasonic viera TX37LZD70 37" flat screen tv so I can wall mount it?
Place the TV on a flat bed preferably your mattress and look for the base mountings. The lock and base mount can be slid off and you can use a good wall mount that will support the weight to be fitted.
Please find the link below for help:
Wall mounting flat TV
Jan 07, 2011 | Panasonic Televison & Video
I have a Panasonic TH-42PZ80U 42" plasma tv I would now like to mount on a wall. I have gotten conflicting information as to whether it is VESA or not. Can you tell me anything about wall mounts for...
Just purchase a mount for 42" and above They come in different styles for your likening and make sure the wall bracket gets mounted into the wall studs and your all set. No major job. I get $150 all day long for those installs.
Nov 26, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
I want to take take the stand off so that I may mount it on a wall....how do you do this? Is there a preferred wall mount also?
The best thing to do - is to read owner's manual first.
Normally there is 4 or more screws on the bottom middle part of rear cover that are holding stand and TV together.
Wall mount choice depend on your budget. It have to be rated for weight of your TV set. There should be 4 bigger size bolts on the back of your TV especially for wall mounting purpose. Again - owner's manual have more detailed explanations of all of the above.
Regards.
Russ.
Apr 04, 2010 | Gateway GTW-P42M303 42 in. Plasma...
Can I wall mount my Tv above a gas fire?
If your talking about enclosed fireplace with the glass front and the vents from it are facing down. Then yes you can use your judgment though. Just make sure their is enough space between the tv, and the fireplace so their isn't direct heat blowing on the tv. A good 4-5 feet above the fire place or more would be fine.
Sep 29, 2009 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
Panasonic TC-32LX60 32 in. LCD Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
