Question about Ricoh Aficio 1027 All-In-One Laser Printer
Our printer keeps saying set counter?
We pu in the venda card and the printer says set counter
  • 24 Answers
can you provide more info?
Posted on Oct 05, 2008
How to troubleshoot ink near full absorber?
Purge Counter Reset Instructions Please note that some of the terms used below to describe buttons may change from one printer to another. For example:
  • START may be down as MENU or SET on your printer or be a green button
  • STOP may be referred to as EXIT or a red button
Before you begin the reset procedure your Brother inkjet printer needs to be in maintenance mode, but depending upon the model of your printer the method of doing this will vary. For most modern Brother printers please try the following:
  1. With the printer turned on and ready to print remove the power cable from the printer (or turn the printer off if you have a fixed power cable).
  2. Hold down MENU/SET/START and re-insert the power cable/turn it back on.
  3. Keep the button held down until the screen reads MAINTENANCE.
If your screen does not now say MAINTENANCE it will need to be put into maintenance mode using one of the two methods below:
  • Printers with a built-in Fax: Hold down MENU/SET/START and quickly press * 2 8 6 4.
  • Printers WITHOUT a Fax: Hold down Menu/Set and the Black Start key before pressing the UP arrow four times.
Now your printer should say MAINTENANCE on the screen and you are ready to begin the process of actually resetting the purge counter.
  1. Type in 80 using the numerical keypad.
  2. Use the DOWN key to locate the purge counter. eg. PURGE0060025
  3. Use the number pad to enter 2783 (this should zero the numbers after PURGE).
  4. Press STOP/EXIT to return to the first stage of maintenance mode.
  5. Press 9 and 9 to exit maintenance mode.
Your purge counter is now reset and you can now resume printing as normal. If however this has not cleared the error message I advise going through this guide again following the instructions to the letter. If the error persists please let us know.
Jul 05, 2014 | Brother DCPJ125 All-In-One Inkjet Printer
How To Reset Purge Counter on a brother mfc-j4710dw
Mar 03, 2014 | Brother MFC-J4710dw Color Inkjet...
Ink Low message after installing new cartridge
There is no way to actually "reset" the counter. IF your MP170 has a RESUME/CANCEL button, Press and hold this button for about 7 seconds to bypass the counter (The PAGE FEED button will work for some other models). If your printer doesn’t have this button, you may bypass the counter by turning the printer OFF. Now hold down the RESET and turn the printer ON. Keep holding the RESET until the printer boots and initializes. When the display says, "INK VOL UNKNOWN" you may release the RESET and begin printing in the usual manner. You may need to start the printer in this manner each time, or the printer may remember this setting. Canon was experimenting during this time so some of the same models have different buttons and bypass tricks. Hope this helps.
I hope this helps you.
Sep 13, 2009 | Canon PIXMA MP170 All-In-One InkJet...
When I press the shutter button the light flashes red and it beeps.On the screen it says Frame No. Full. What can I do to correct this problem
It should tell you in the manual(if you have 1)
If you review your current photo's it should read in the top right corner the number of frames used. If your camera says frame number full then the numbers in the top right should read 999.9999 and you need to reset the counter.
To reset press menu and scroll down to settings. select FORMAT and format the current card in your camera. This will wipe everything on your card so make sure you have saved them to your pc first!
After you have formatted your card go back to your settings menu and select FRAME and set this to RENEW. Now come out of the menus and take a picture. Review the picture and the counter in the top right corner should now read 100. 0001 your counter has now been reset. Now go back to the settings menu and select FRAME again and set it back to CONT (continuous). Note: The counter has been reset for the current picture card only. Other picture cards will display the previous counter readings saved on to that card and will need to be FORMATTED in the same way to reset to 100.0001
Aug 06, 2009 | Fuji FinePix F480 Digital Camera
Set Key Counter error
press the user tools button, press the copier button on the screen then go into the administrator tools button in there you should see some option for turning the key counter off.
Dec 27, 2008 | Ricoh Aficio 2018D All-In-One Laser...
Problem with zebra p420i
Go in to control panel,
Printers. RT Click On p210i,
Properties, Device Settings Tools.
Send this Command using the Direct Commant
input Box. Just the First line..
1 +LC 0
Not This--
0
= Counter Value
Dec 16, 2008 | Zebra P210i Thermal Printer
Changed drum but it is still saying 'change drum'!
On some printers after you change the drum, you have to reset the counter so the printer knows the drum has been changed. How to reset the counter is as follows:
1. press the ONLINE button to return the printer to off line status.
2. press the MENU button repeatedly until the MAINTENANCE MENU is desplayed, then press the SELECT button.
3. Press the item button until DRUM COUNT RESET is displayed.
4. Press the SELECT button and the Drum Counter is reset.
Hope this helps.
Nov 10, 2008 | OKI B4350 Laser Printer
Lexmark 1200 printer
Dear Fixya Team,
Thank you for your kind invitation and prompt offer to help solve my Lexmark printer problem, but I have now received from Lexmark Brazil the following distributor contact details as a supplier of the adapter.
I'll let you know what the outcome is.
Regards.
Powerless2
MTR INFORMáTICA LTDA
Rua Senador Dantas, 75
Centro - Rio de Janeiro - RJ
Telefone: (021) 2142 7500
Vendas: vendas@mtrinformatica.com.br
Jul 13, 2008 | Lexmark X1270 All-In-One InkJet Printer
Dash drum
Sound like machine is set to wrong lingo but it will be telling you to replace drum with new then reset counter,
Nov 16, 2007 | Brother DCP-7020 All-In-One Laser Printer
Ricoh Aficio 1027 All-In-One Laser Printer Logo
43 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
