Question about Black & Decker Irons
My Iron keeps turning off while I'm ironing
This iron has an auto shut off. Lately when I turn it on and it reaches the right temperature it will automatically shut off WHILE I'M IRONING! I have to turn it off then turn it back on to get it to heat up again but it will shut off again in less than 1 minute. Have you heard of this problem before? and what do I do?
First I called Black and Decker. No help there, just a very condescending man on the other end of the phone who finally put me on hold for more than 10 minutes. I hung up, and went to the store where I purchased the iron and without a receipt they listened to the explanation and exchanged it for the exact same new iron. Now THAT'S customer service.
Posted on Sep 30, 2008
Iron keeps shutting down while ironing
My rowenta iron keeps shutting down while I'm ironing. What ...
www.faqqq.com/.../my-rowenta-iron-keeps-shutting-down-while-im-iro...
Question Product: Rowenta Effective DX1900 Iron with Auto Shut-off Question Details: My rowenta iron keeps shutting down while I'm ironing. What can I do.
Top 229 Complaints and Reviews about Rowenta Steam Irons
www.consumeraffairs.com > Shopping > Appliances
Rating: 1.6 - ‎36 votes From the first day, iron shuts itself off while ironing. ... The last 3 have either leaked everywhere or the cord where it joins the iron keeps switching the iron off. ..... from the stainless steal down the right side of the iron and was leaking water all ...
Oct 31, 2015 | Irons
Shark iron g1462
the lights you witness are correct. once the iron has reached tempreture.
ensure the iron is stored in an upright position between ironing items if left laying down the iron may switch off as an anti-burn or fire safety feature as if left unattended. with the iron placed on its back plate with its point facing upwards the iron should stay on.
I hope this was useful.
May 14, 2014 | Irons
Why light blinks then goes off when switch is still in the on position
The thermostat in the iron controls the temperature of the iron. The red light indicates when the power applied to heat the iron which is set by the temperature dial on the iron. When it reaches the correct temperature the thermostat turn off the power and that is when the red light switches off.
Jan 15, 2012 | Irons
The green light keep clicking on and off
That is the normal way of operation. The green light comes on when the iron is heating up and when the temperature is right the thermostat switches off power hence the light going off.
Jan 31, 2011 | Hamilton Beach 14977 Iron with Auto...
Iron not heating
Here is a tip that will help you to troubleshoot our iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Jul 13, 2010 | Rowenta DZ5080 Iron with Auto Shut-off
Iron keep shutting off while ironing
The cord is broken...
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
heatman101
Jun 21, 2010 | Black & Decker Steam Xpress AS250 Iron...
My iron will not stop flashing and will not go to green light -- it will not heat up
Hello :
Check the fuse first ! If the fuse is in good condition , then try this troubleshooting .
1: Make sure there's enough water in the tank if the iron won't steam. Fill the tank up .
2:Check that the iron is set to a steam setting. Some of the settings are dry and won't create steam.
3:Set the temperature dial to the shaded setting which represents steam. You'll see a little dark cloud-type icon with raindrops as opposed to a white cloud with a stripe through it. The dark cloud represents moisture (steam), and the white cloud with the stripe through it represents no steam.
4:Allow the iron to heat up for a while and to emit steam for a couple of minutes while pressing the extra-long burst button a few times. That should get rid of any impurities which can cause blockages. Try this if the iron hasn't been used for a while and steaming is intermittent.
5:Iron horizontally. Steam is only generated when the iron is horizontal.
6:Use the maximum steam setting when the iron is set to its maximum temperature setting.
7:Let the iron get to a high temperature before expecting steam. If the soleplate isn't hot enough, the water won't turn to steam and will in fact drip, spit or leak from the soleplate. Some Rowenta irons have an anti-drip system, which will turn off the steam when ironing at a low temperatures. Turn the temperature up, if needed.
PLEASE DON'T FORGET TO RATE !
Apr 21, 2010 | Rowenta DZ5080 Iron with Auto Shut-off
Switch light goes on when pressed but goes off if not pressed
Switch light goes on when pressed but goes off if... OR iron does not heat at all even pressing the button to turn it on continually.
Don't understand which one question you are asking
But if there is no heat at all after switching it on, it needs to go to iron heaven but be sure to cut the plug of the end, Saftey reasons at the dump. BUT if lights are coming on the iron is working. the large dial on the water filler is temperature control. Turn this around to cotton or linen.
The light will come on and off while in use, it allows you to know that the iron has cooled and is going back to your select temperature( on the large dial)
Make sure that you use water in the iron as it will aid your ironing and make it quicker. Make sure that the iron temperature dial on the water filler is at the correct temperature for the item that you are ironing.
Hope this helps
Sep 17, 2009 | Black & Decker Steam Xpress AS250 Iron...
It shuts itself off
The SHARK ELECTRONIC Iron is equipped with an electronic auto-off. The electronic auto-off switches the iron off if it has been left standing unmoved in any position (sideways, flat or upright) for approximately 7-9 minutes. A red light on the LED display panel will flash when the iron switches itself off. (Fig. 7) To switch the iron back on, just shake the iron side-to-side several times.
Jul 31, 2009 | Euro-Pro Shark GI490 Iron
Auto shut off
either the element is faulty or the switch you turned to give the diffrent tempreture has solder, if it is lose then your iron can repair if it is the element then you have to buy a new iron.good luck.
Sep 06, 2006 | Tefal UltraGlide plus 1656 Iron
Irons Logo
1,690 people viewed this question
Top Black & Decker Irons Experts
tfelton3
Are you a Black & Decker Iron Expert? Answer questions, earn points and help others
