Question about RCA TruFlat 27F520T 27" TV
It's gone crazy
I have no control over my TV. I cannot turn on or off, have no control over volume, programming is in and out. only thing i can do is unplug
  • 899 Answers
The EPROM chip inside is bad or IR sensor circut is causing random frequency's , will need repair
Posted on Oct 07, 2008
All ready got remote programed it does every thing but turn up the volume
If the remote turns the tv off an on it should also do the volume.
Some tvs have built in DVD players and you normally have to program the remote to the dvd button to control the volume on those models.
Feb 04, 2013 | Televison & Video
Dear Sirs, I have a Yamaha Rx- v363 receiver 2008 yr. model. I'm looking for help in programing the volume control on this unit. When I turn the unit off and then back on the volume it stuck on its highest...
Page 48 under Set Menu:
Initial volume INI.VOL.
Use this feature to set the volume level when the power of this unit is turned on.
Choices: Off, -80 dB to +16 dB
Control step: 1 dB
Feb 20, 2011 | Yamaha RX-V363 Receiver
Mitsubishi WS-65511 volume control has gone crazy. All of a sudden volume went to full blast and now with manually pressing volume button it is either full volume or lowest volume. We have DISH and...
Mitsubishi WS-65511 volume control went crazy after a storm. Now we don't having any volume. None of the controls are working on the front of the panel with the exception of the device control.
Jun 02, 2010 | Mitsubishi WS-65511 65" Rear Projection...
Remote doesn't control. batteries are good, but there is no apparent connection between the remote and the TV. It is in use with a Comcast turner-DVR, which works fine, but I have to turn on and adjust...
Are you using Comcast remote to control the TV? When you program the Comcast remote to control your TV, it will do two functions: on/off, and Volume control. The Comcast can also be programmed not to control the volume of the TV (TV volume will have to be set at about mid level manually, then the Comcast box will send out variable sound level to the TV), just on/off ONLY.
Oct 27, 2009 | Olevia 227-S11 27 in. LCD TV
The volume is turning itself down all by itself. The volume on the remote won't work, but the remote is fine with the other TV controls.
It sounds like the button is stuck. Take the remote apart if you can and see if the key is stuck somewhere. This happened to me once with a rubber key type of remote. It drove me crazy.
May 10, 2009 | Sansui HDLCD3210 32 in. LCD TV
Hum in sound volume
It could be a few things. The first thing you want to look at is make sure that the microphone is muted in the mixer controls of your audio cards. These settings are located in the control panel. If you need the mic, look under the advanced settings under it and disable the 20 db option for it.
If that doesn't work I have a few other ideas.
Mar 17, 2009 | Proscan 32LB30QD 32 in. LCD TV
Comcast Remote Can't Program My Sceptre HDTV
Thanks...this worked great for me. I used code 11100 on my Sceptre tv and it appears to be working perfectly!
Nov 27, 2008 | Zenith DBZN-311 Remote Control
Audio problems
Good Day, corilyn;
Several things that you may try:
1. Unplug TV and Cable/Sat box for 3-4 minutes, plug all back in, that's resetting the devices.
2. Some boxes have volume controls, make sure 'box' volume are turned to max.
3. Go into TV's customer menu, go to audio section, make sure speakers are turned on/ set to internal speakers.
Good Luck, Big Irish.
Jul 08, 2008 | Sony Televison & Video
Possessed remote and tv
How old is this set? some of the late 90's early 2ks had issues with the Gemstar module, then you also said that you unplugged the buttons, if unplugging the buttons fixed your problem, you probably have contamination in the buttons and they are $2 switches, I would replace all 8 (if you have 8) as I do in some of the CTC169 Chassis televisions, depends upon your level of expertise and such. This set has the Guide+ system and I think that you might have a Gemstar issue still, it is a little 2" square box that has 2 ribbon cables that plug into it, and is fairly easily replaceable.
Jul 08, 2007 | RCA F36665 36" TV
I am having problems programming the remote
Programming a GE Universal Remote Control takes about seven steps. Step One: Manually turn on the device you wish to program. Step Two: Press the Code Search button on the remote until the indicator light turns on. Step Three: Release the Code Search button. Step Four: Press and release the button for the device you are programming. Step Five: Enter the three-digit code for the device using the number buttons on the remote. After the code is entered, the indicator light turns off. Step Six: Aim the remote at the device and press the power button. The device should turn off. Step Seven: Press Channel Up on the remote with the device on. If the device responds, no further programming is required. To look up a device code to enter directly into the remote, visit the GE Remote Code Locator Website. http://www.jascoproducts.com/support/dow... http://www.jascoproducts.com/support/dow... Hope this helps, Good Luck :) Please Vote
Jul 01, 2007 | GE JASRM24977 Remote Control
RCA TruFlat  27F520T 27" TV Logo
43 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
