What is the address and default login for a linksys 5 port Workgroup switch.
  • 268 Answers
The address is or
The username is: admin
The Password is: password
Posted on Sep 29, 2008
How do i connect two computers so they both have the same ip address i have a linksys 5-port workgroup switch will that work ? also i had hooked it up but only one of my computers had internet
They cannot have the same IP address due to the mechanics of DHCP. Buying a cheap 50$ router (not switch) will fix your problem as your internet service provider will see that device as a single unit that it will assign an IP and then the router will give out internal ip addresses so that they can get online. The switch does not have this functionality.
Feb 16, 2011 | Linksys EZXS55W EtherFast 10/100 5-Port...
I have a Linksys 5-port switch connected to a cox cable modem and I'm trying to use it to connect two computers at the same time. Only one works at a time and I have to reset the switch and modem to get...
Because the cox cable modem will only bind to one mac address (computer). You need to purchase a router, any router linksys, dlink, will do, get a wireless one so you can setup wifi as well. Plug your cox cable modem into the wan port on the router, plug your pc into one of the ethernet switch ports, you can use your web browser IE to login to the router and secure your wifi signal, power cycle your modem to make it bind to the new router. Most linksys dlink are programmed for a class c network, you could in theory put 254 devices, computers on your connection now.
Aug 27, 2010 | Linksys EZXS55W EtherFast 10/100 5-Port...
I am installing linskys to my home computer. I follow al of the directions on the linkys cd but when i switch the wire from the modem to the router and plug it back into the tower i wil not have an...
I think you need an extra cat-5 wire.
Plug one CAT-5 LAN cable into the port labeled WAN on Linksys then the other end into the cable Modem where your PC is normally
now take a separate Cat-5 LAN cable adn plug it into port 1 on the linksys - the other end into your PC NIC
Power cycle Cable Modem (remove battery), linksys, PC this will clear the MAC addresses
turn on modem, linksys then pc
loging to windows - open IE on address bar type - this should be the default address of your router (unless you've changed your subnet) in which case I recommend you factory default the route and use default settings. after typing teh 192.1386.1.1 you should see the linksys login
Now try in IE, the routers factory setting for DHCP should work fine without any end user programming from you.
please rate me, good luck
Aug 24, 2010 | Linksys Wireless-G Broadband Router
How do i set it up with my modum router and switch
Connect your modem/router to one switch's port. Connect your PC to the rest ports.
Dec 06, 2009 | Linksys Instant Gigabit 5-Port Workgroup...
Can u help me retrieve my wifi password?
You need to do a factory reset of your wireless router. This should clear the password in it. There is no password for your 5-port switch.
Nov 18, 2009 | Linksys EZXS55W EtherFast 10/100 5-Port...
Two computers and printer dont communicate with workgroup swith
Do you have a router in front of the switch? Most ISPs only give you one or two "public" addresses. If you don't have a router in front of the switch, your computers and devices will not receive the "private" addresses they need to communicate with each other and the internet.
Jan 28, 2009 | Linksys EtherFast Workgroup 8x10/100 Mbps...
Can't get two computes to run internet at the same time
If you login to your router and make sure DCHP is enabled, and then go to Services (services.msc) on your computers and make sure that the DCHP Client is running, it'll automatically assign IP addresses for your computers and they'll both connect okay.
Hope this helps
Chris (ziraffa)
Jan 17, 2009 | Linksys EtherFast 10/100 5-Port Auto...
I cant login to the motorola login screen?
For Linksys routers there is no username only the password which is admin.
Dec 19, 2008 | Linksys EtherFast 10/100 16-Port Workgroup...
Computers & Internet Logo
David Payne
David Payne
