Question about Canon Office Equipment & Supplies
I have Canon S9000 printer. 3 inks have run out tonight - photomagenta/magenta/cyan and I have installed new cartridges. Prints are now not in full colours. eg document I am printing should have grey main head banner with blue/red/green/yellow index smaller banners. Main banner now light pink. smaller banners are dark pink/red/yellow/yellow. What do I need to do to correct this.
  • maffitingram Nov 22, 2008
    My Canon i9100 is printing a mauve colour instead of grey, orange instead of red among other abnormalities. Have carried out the maintenance apart from deep clean which does not seem to be working. What do I need to do now?
Breather hole blocked in cartridge. opened up with pin - works ok now.
Posted on Oct 06, 2008
Why is my Canon Pixma 4820 suddenly leaving lighter lines through color pictures.
Worn print head. And for what they charge for a stinking print head you can get a new printer for less with a warranty to boot!
Mar 24, 2017 | Office Equipment & Supplies
Canon Pixma yellow color problem
Either the ink you are using is not going to give the color you want, or you have print heads that are blocked.
Mar 11, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
My printer prints pink. new ink?
What particular color are you trying to print from but showing a pink output? Chances are, you may be running out of other inks such as yellow or cyan, and thus the printer uses the magenta since it is still available. Check your ink cartridges if they are full. If not anymore, replace them.
Dec 19, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
I've a canon MP610 printer and I cant get good colour prints, they are too red. Even when I try to print B/W they turn out brown. I've printer direct from the memory card and the same results. I use canon...
Do you have photo cyan or photo magenta installed? your machine does not use these inks, and will give wrong colors. You need plain magenta and plain cyan. If you are using generic inks, they could have bad colors too.
Aug 10, 2009 | Office Equipment & Supplies
Prints on Cyan
For the colors that are not printing, take the cartridges out. Now get a bowl and pour in about 1/4 on an inch of window cleaner. Now put the cartridges in the window cleaner with the the bottom that releases the ink in window cleaner. allow them to soak for about 10 minutes, dry them off, then blot the bottom with a paper towel to see if ink is now releasing. if so install the cartridges back in the printer to see if the colors print.
Jun 14, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
Canon i9950 prints green on photo paper
I had the same problem. Having checked other websites I came across the following which narrowed down the problem to the Photo Cyan / Photo Magenta ink tanks, and replacing the Photo Magenta one (although it was not empty) has successfully resolved the problem. Eveidently ink from the original one was not flowing and so caused the syan cast. (I experimented by subsequently removing the Cyan one which produced prints with Magenta cast)
TEXT OF POST I FOUND:-
That post is labeled "Cannon (sic) S9000 Print Head" and concerns a greenish hue error in all print quality levels OTHER THAN plain paper. In other words, all output designated as Photo Paper Pro, Glossy, High Resolution Paper, etc., results in output with enormous and unacceptable levels of green hue. All output designated as "Plain Paper" whether the output actually is on plain paper or photo paper pro, turns out well.
This problem is not unique to the S9000, as I experienced it identically with the S820 and predictably can occur in any printer with the six cartridge print head.
It is a frustrating problem because you know that the printer is physically capable of printing WITHOUT the hue (as it proves to you each time you choose a "plain paper" paper setting.)
Troubleshooting by reinstalling and updating the printer drivers, and uninstalling/reinstalling the ZoomBrowser EX, replacing the ink cartridges, and deep cleaning are all blind alleys.
A call to Canon support solved the problem for me with this simple and important revelation:
The Plain Paper setting is unique in its use of only 4 of the 6 cartridges. In the Plain Paper setting, only the black, cyan, magenta and yellow cartridges are utilized. The Photo Magenta and Photo Cyan are not utilized. In all higher resolution settings, i.e., in all other settings, all 6 cartridges are utilized.
It follows that if one's problem disappears when not using these two Photo cartridges (i.e., when printing at the Plain Paper setting), then the problem lies with these cartridges.
(In my case, I'd loaded a plain "Cyan" cartridge in the "Photo Cyan" slot during earlier trouble shooting and had forgotten to replace it with the proper Photo Cyan cartridge.)
Problems with magenta hues would admit of the same solution.
Hope that helps anyone else out there tearing out their hair trying to troubleshoot this. "
Dec 10, 2008 | Canon BubbleJet i9950 InkJet Photo Printer
Prints only green predominently
Without knowing what printer you have or what things you have tried I can only guess here. It sounds like you need a new cartridge. A color ink cartridge will have 3 colors of ink for most printers...cyan (blue), magenta (purplish-maroon), and yellow. Depending on what you print it is very possible that you could run out of one of the inks before the others. Printing green can be an indication that you are out of magenta ink. The cyan and yellow inks will combine and look green.
You can remove the cartridge and run a tissue over the printhead and see if you see all 3 colors as a quick test. If you only see cyan and yellow, then the magenta is probably empty or dried up. If you see all 3 colors I would reinsert the cartridge and try printing again. It is possible that the magenta was just clogged and you cleaned it with the tissue. If it still doesn't print all colors your best bet is probably to just get a new ink cartridge.
Sep 10, 2008 | Office Equipment & Supplies
Only Prints in Magenta
The cartridges may still be at fault, or there is a problem with the processor board in the printer. I have also seen problems with the ink jets in these.
Jerry G.
Apr 19, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Ink cartridge lights blinking
That is happening because you have "smart" chips on your cartridges, so even though you know there is still some ink left in the tank, if the chip says stop, the printer will stop printing. There is a way to bypass that and that is by using a re-setter. You can either buy one or ask to re-set your cartridge in a refill shop.
You can also try holding the "resume" button (triangle in circle for about 10 seconds for each cartridge, sometimes doing that resets the cartridges.
Do not refill the magenta and cyan cartridges if they are not empty, you'll just be wasting your money. Better use it to buy a re-setter ;)
Hope that will help!
Nov 27, 2007 | Canon PIXMA iP6700D InkJet Photo Printer
195 people viewed this question
old marine
old marine
