Question about Mercury P4VM800M7 Motherboard
Usb port is not detecting pen drives
I am using Windows XP SP2 and Fedora 7,in which usb port is not detecing pen drives,mouse & bluetooth devices but it can detect data cables and speakers.Pls suggest me.
    Problem Solver:
  • 4 Answers
Dear ... If u have msi 945 motherboard driver cd or u can download this from their site ... This cd contains all the drivers for xpsp2 ... U will get the vga and sound driver from it... ALSO if intel motherboard then sound driver is soundmax ...hope it will help u
Posted on Dec 21, 2014
  • 28 Answers
Fiend your solution direct from mercury. Here is your solution.....
http://www.mercury.com/motherboard/prob676ijt65/solution
aamknr-8
Posted on Sep 03, 2009
Insert the usb pendrive first then check the setting i have given becoz it will be shown only when pendrive is inserted
go to the       conntrol pannel > system > hardware >device manager > system devices (here check what is not installed removed that / or  update that item.... after installing that component sucessfully check usb pendrive again.
If ............ not check this one
Control  pannel > system > hardware >device manager > universal serial bus controller (here check what is it showing if unknown devices remove/uninstall it then install again/(scan for hardware changes) the device will be installed agin then use the pendrive.
Posted on Oct 08, 2008
Mercury 865 mother board disk are missing please give me sound & vga driver
Posted on Oct 01, 2008
In my PC USB ports are not detecting any mouse. If I put any pen drive it is detecting. I repaired my win-xp sp2 OS. I re installed all drivers. But problem was not solved.What shoud I do now?
Unplug all your usb devices. Go to device manager, then >USB controllers and delete all the controllers in there, it will not delete some, just delete all the ones it will allow you to. then reboot the system. Plug in each usb device one at a time and it should find each one.
Feb 17, 2015 | Computers & Internet
Tip
USB devices not recognised or not working properly?
Try these steps to reinitialize your usb ports on your pc
1. Unplug ALL USB devices connected to the computer. If you are using a USB mouse and keyboard, temporarily use the older type PS/2 devices if you have them, if you don't then just leave them connected.
2. Hold down the windows key and press r
3. Type devmgmt.msc into the run menu and press ok
4. Click on the + sign next to the Universal Serial Bus Controllers
5. You might need another mouse to do this if you have a usb mouse.. I recommend you get a ps2 connector mouse which goes into the green round connector in the back of your pc.
6. Right click and uninstall first the usb root hubs. all of them then uninstall the rest of the devices you see under Universal serial bus controllers
7. Ones you have uninstalled everything you should see the Universal serial bus controllers there at all.
8. Now go ahead and restart your pc.
9. Ones you have restarted the pc your usb ports will reinstall in a moment stand by while it installs all of them. If you get warning messages click ok or continue installation.
10. Now go ahead and plug the usb devices back in. Install software if required, all usb devices if not faulty or broken should work now. Also note the error code if you get one?
This solution doesn't fix all usb problems so if you have a yellow ! mark there and device status reports a error code. Then it might not be a problem with your usb ports.
Thank you for reading, do leave suggestions, comments, feedback below.
Ekse
usb mouse drivers for windows xp mouse trackball mouse drivers bluetooth mouse computer problems 2.0 usb driver microsoft windows scanner driver usb 2.0 air mouse computer service usb hubs update drivers fix windows computer services computers hub usb usb drivers usb 2.0 hub laptop mouse usb switch 4 port usb 2.0 hub wireless mouse usb driver fix computer windows xp pro usb optical mouse computer support computer repairs update driver 4 port usb hub usb security usb cable windows xp microsoft windows xp computer repair windows xp professional upgrade windows
on May 04, 2008 | Microsoft Windows XP Home Edition
Im using v165w pen drive.when i connect to pc its not detecting the USB.i also tried with another pc also,the same problem occurs.i tried with both windows7 and windows XP..Wat can i do to solve the...
If two computers(and two different operating systems) arenot detecting the pen drive then most likely there is something wrong with thatpen drive and it needs replaced.
In Windows 7 you can check the following.
Plug the pen drive into an available USB port.
Click the Windows Orb(Start menu in XP). Right-click on "Computer"(My Computer in XP) thenleft-click "Manage". If "Computer" does not exist in the "Start" menuthen it should be on the desktop.
In the left pane click "Disk Management".
In the right pane, the first column will show you the drives currentlyinstalled(C:, D:, E:, etc). C: is typically the drive your operating system isinstalled on. To check what drive is what, just click the Windows Orb(Startmenu in XP) then click "Computer"(My Computer in XP). If you see the same driveletters under "Computer" that you see in Disk Management then the pen drive isnot being detected. Do you hear any sounds coming from Windows when you plug inthe pen drive? If you have a different pen drive is that one beingdetected? Are other USB devices detected when plugged into thecomputer?
Mar 07, 2011 | Dell Computers & Internet
Computer not recognizing hard drive. Seems to be a problem with usb connection. Can I put the drive into another enclosure?
Definitely you can try with different enclosure, and it will work in any enclosure... But before buying a new enclosure it would be better if you try to connect the hard drive in a different computer to isolate where the issue is...
Jan 02, 2011 | SimpleTech SimpleDrive Pininfarina 320GB...
Transcend hard disk issue
The problem is the usb ports in your pc. You know the drive works and is properlly deteced on the laptop so you can ignore that.
IF you can try other usb devices in your pc usb ports and see if they work.If they don't at all then you either have dead ports or drivers are missing. You should see them listed under control panel system hardware.
If they work then I would wonder if the usb drive you have requires a differant usb port than what you have. There is a type 1 and 2 and type 3 which has just come out so we can ignore that one. A type 1 is slower and cannot power devices usually. A type 2 is faster and can power some devices. I don't know how old your pc is so it could be hardware, either failure or drives. You should also makre sure you have the service packs installed for windows. Sp3 is the latest version. There were some changes to the way usb devices were deteced in Sp2 if I remember correctly.
Apr 13, 2010 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
Windows is not detecting usb mouse and mouse is not working
which OS you have..? xp/2000 , both OS not need USB driver but auto detecting.., i request you to try another usb socket.
Jun 28, 2009 | Lenovo IdeaPad S10-1211U Netbook
Usb Driver For Huawei SmartAx Mt882 for win XP professional
Windows XP Professional doesnt require USB Drivers, these Driver built in Windows XP professional
or there already present in ur system..........
so go ahead connect anything to ur usb port(like digital camera, mouse, pen dirve, flash driver , memory card reader,..portable harddisk , digital cameras)
when u insert any of the component(for eg: pen drive) in to the usb port OS will automatically detected these devices and install USB Drivers.... dont worry... about this  and be rest assured....OS will do the work for u...............
Thanking You
M. Sridhar
Dec 26, 2008 | Computers & Internet
Usb pen drive not recognized on my computer
My computer have USB port and windows XP but my pen drive is not getting recognized do i need an additional software in order to use pen drive
Jul 22, 2008 | Microsoft Windows 98 for PC
Usb ports not working
All the USB ports were working before he installed SP3 and rebooted. After that only the mouse/keyboard ports worked. Same thing happened to me. No other changes were made, so something added/change by SP3 is the culprit.
Questions is...what did SP3 do to break USB and how to fix it?
Jun 14, 2008 | ASUS A8N-VM Motherboard
Mercury P4VM800M7 Motherboard Logo
7,291 people viewed this question
Top Mercury Computers & Internet Experts
Mark Gough
Abhinandan  Patil
Abhinandan Patil
Alun Cox
Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
