Question about Vacuums
I have a Hoover Slider, Model #S2105, Serial #050500084989, and I need instructions on putting it back together; with parts and assembly of parts. I took it apart because it was making a noise, and I believe one of the belts had come off. However, when I took the screws out of the bottom to check the belts, the whole thing fell apart. Now I can't get back together properly. It will not come on, and I believe it is because the switch that makes it come on when you lower the handle is not positioned correctly.
  • 438 Answers
Greetings from GoVacuum,
Please see the link below for a parts schematic to your Hoover Slider, hopefully this will help you put the machine back together. If you find a part that is missing, and would like to order one, just shoot me an email at chris.jones at govacuum.com, and I can give you a price on it.
Please feel free to send me an email should you have any further questions.
Chris Jones
GoVacuum.com
Posted on Sep 29, 2008
The red light keeps blinking while I have the charger plugged in, is this normal?
Hi! If the light on the charger is blinking this can mean an issue with your charger adaptor. Check that the charger is still warm. If so, unplug the charger for a few minutes and plug it back in. If the light is still blinking your charger adaptor may need to be replaced. Hope this helps!
Sep 10, 2014 | Hoover S2105 Slider Bagless Stick Vacuum
How to open to clean
Hello! The dirt cup, filter and brushes need to be cleaned to ensure continued cleaning effectiveness. Below are steps for cleaning your Hoover Slider.
Turn switch to OFF position.
1. Press button and slide latch towards outside of cleaner. Rotate dirt cup toward back of cleaner.
2. While holding dirt cup, grasp filter frame and lift out filter. Empty dirt cup after every use. Dirt cup can be cleaned with a damp cloth. Allow to dry thoroughly.
3. Pull middle section of filter out of filter frame. To remove debris from filter, tap it on a hard surface or brush it with a soft brush.
4. Remove lint, strings, etc. from the brush roll located on the underneath side of the nozzle.
5. Replace the brush roll when the brushes do not touch the edge of a card as it is moved across the opening on the bottom of the nozzle.
Further disassembly of the cleaner is not recommended. Hope this helps!
F
Aug 13, 2014 | Hoover S2105 Slider Bagless Stick Vacuum
I have a Hoover Legacy model S3592 and the cord will not retract, it is fully extended. How can I fix this problem? Patty Lester
You may have to dis-assemble the machine to the point where you can gain access to the mechanism that retracts the cord. Then see if it can be fixed or needs replacement. Just don't lose any parts when dis-assembly, and make sure everything is put back together correctly.
Oct 14, 2013 | Hoover Elite & Legacy Vacuum Cleaner Belt...
I have a Hoover windtunnel, model U5470900. The on-off switch is broken. How do I order the parts and what is the instructions for replacing the switch?
I think this is a common problem, as the actual switch is located behind the cleaning tools caddy. The switch is toggled via a long, plastic rod connected to the thumb slider on the handle. It's a comically poor design. I'm not sure, but I think you'd have to replace the entire handle assembly if the slider no longer works. An easier solution is to simply plug the vacuum into a surge protector with an on/off switch.
Feb 13, 2011 | Hoover U6437-900 / U6439-900 Windtunnel...
Solution seals
Please use the following link:
http://www.hoover.com/parts/?category=carpetcleanertanks&part=42272134
This is for a replacement solution tank assembly
Sep 09, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Problem with Hoover slider
If it doesn't charge, the problem may be the batteries have gone bad.
Oct 04, 2007 | Hoover S2105 Slider Bagless Stick Vacuum
Replacement parts
go to thehooverstore online - they have your nachine listed with a diagram and parts listing
Feb 24, 2007 | Hoover S2105 Slider Bagless Stick Vacuum
Vacuums Logo
142 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
