Question about Samsung SCH-u340 Cellular Phone
Ringer I am having a problem turning my ringer on. I see a picture of a bell crossed out on the phone. Any suggestions on how I can get a picture of just the bell back? Craig
  • Anonymous Dec 05, 2008
    I have a sch-u340, when i press the button the side it comes up ringer off and arrow to the right and to the left, I have pressed every button I know to press and the ringer is still off. I use this as my businees line and I am missing calls. I need help fast.
Hold the # key for couple second and you will have your ringer came back on
Posted on Oct 07, 2008
I have a new uniden cordless D3097 series phone and I can't figure out how to have the handset ringer on and the base ringer off. When I turn off the base, the handset stops ringing
The Silent button on the D3097 is a global Do Not Disturb button. To reduce the ringer volume, press the Volume Down button on each handset when the phone system is in standby (not in use). When you have pressed the Volume Down button to the point where the ringer is muted, you will see an icon of a bell with a line through it.
See pages 6-7 of the manual for the details. The manual is available here: http://www.101phones.com/content/pdf/uniden/D3097.pdf .
I hope this helps.
Sep 18, 2017 | Uniden Lands Phones
I inherited a discontinued Southwestern Bell Freedom Corded Phone - Model FM2554. I need a manual. I am trying to turn the ringer off or down. Any help is appreciated. Thanks! - Dj
I can't help with the manual, but those old phones usually had a lever that poked out the back that worked as a ringer switch. If not, the mechanics are simple. Just open up the phone and snip the wires to the bell, or remove the bell itself.
Jul 22, 2017 | Bell Lands Phones
Please tell me how to turn the phone ringer back on! Right now it's off. My phone is a Panasonic KX-T7730. Somehow, while setting up my phone, I turned the ringers off & now my phone won't ring.
Hello Joyce Sia,
You have two ways to cut off ringing...
Look for a "DND" (do-not-disturb) control...
used for napping, studying or just plain
being left ALONE...
ELSE...
On the LEFT side of your base you should
also have a slide switch... a CRUDE volume
has three settings:
- big bell = High Volume
- small bell = Low Volume
- bell with an "X" over the top = OFF
Check these settings BEFORE you do a general power
and battery remove.. and begin All over AGAIN...
Ask com What Your Question
Sep 09, 2016 | Panasonic KX-T7730 Corded Phone
Somehow I have a bell icon on the screen at the bottom left with the words OFF beside it and now the phone does not ring only the ring on the fax/printer. Thanks Margaret
Hi margaret, is there a ringer switch either on the phone handset, or is there an option in the the fax settings to go directly to print. The issue sounds fairly straight forward, somewhere the phone ringer, or the settings for the phone to ring has been inadvetently switched off. Some investigation shoud bear fruit
Jun 08, 2015 | Bell Lands Phones
Phone ringer off
It a little bit older cordless phone, I CAN'T find the model number, there's a menu/elect button on the face but I can't turn the ringer off. The base has a ringer that I turned off but the phone still rings. There are no switches on the phone or base for turning it off.
Nov 14, 2013 | Northwestern Bell 36028-2 2.4 GHz Twin...
How do i change/control ringer volume on presidian cordless 5.8 ghz?
While the phone is on standby, press vol/bell to hear the current ringer tone. Press vol/bell again while the tone is ringing to switch to the other ringer tone. The last ringer tone heard will be selected as the phone's ring tone setting.
Get the manual from: http://www.google.com/url?sa=t&source=web&cd=9&ved=0CFcQFjAI&url=http%3A%2F%2Frsk.imageg.net%2Fgraphics%2Fuc%2Frsk%2FSupport%2FProductManuals%2F4300257_PM_EN.pdf&rct=j&q=presidian%20cordless%20phone%205.8ghz%20user%27s%20guide&ei=wPopTpSkE8zPmAXFhuitDA&usg=AFQjCNFGoj6kwkI8m_Hhi9K1t49wifNP2g&cad=rja
Jul 22, 2011 | Lands Phones
How to inactivate melody ringer
Base unit ringer tone
(use either the handset or the base unit)
Make sure the base unit is not being used.
Setting the base unit ringer tone by using the
4 Select the desired ringer tone by pressing [d]
or [B].
• The handset will ring and the ringer tone will
change. If the ringer volume has been turned off,
the handset will not ring
• You can also select the ringer tone by pressing [1]
to [7].
5 Press Save, then press [OFF].
Press VOLUME [<] or [>], then select the desired ringer tone by pressing
[1] to [7].
[1] to [3] : Bell ringer patterns [4] to [7] : Melody patterns
• After pressing VOLUME [<] or [>], the base unit will ring using the current ringer
tone.
• The base unit will ring and the ringer tone will change.
• To stop ringing, press [STOP].
1 Press [MENU].
2 Scroll to “Initial setting” by pressing [d] or [B], then press
Select.
3 Scroll to “Set base unit” by pressing [d] or [B], then press Select.
4 Press Select at “Ringer tone”.
5 Select the desired ringer tone by pressing [d] or [B].
• The base unit will ring and the ringer tone will change. If the base unit ringer
volume has been turned off, the base unit will not ring
• You can also select the ringer tone by pressing [1] to [7].
6 Press Save, then press [OFF].
This Can Be Found On Page 17 And 18 Of The User Guide.
If You Do Not Have The User Guide It Can Be Downloaded Here
http://support.radioshack.com/support_phones/doc73/73355.pdf
Thank You For Choosing Fixya.com
Dec 21, 2008 | Panasonic KX-TG2357 Cordless Phone
Ringer
press and hold the menu button, then use the up down keys and find the ringer off and press edit. this will turn the ringer on.
Jul 12, 2007 | Northwestern Bell 35807-4 Cordless Phone
Turn off ringer
No specific knowledge of your model but I have seen many people place tape over the housing holes for the ringer to cut down the volume level on phones where the ringer is too loud.
Jun 14, 2007 | Southwestern Bell GH-5812 Cordless Phone
Samsung SCH-u340 Cellular Phone Logo
290 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
