Question about Canon PIXMA MP160 All-In-One InkJet Printer
"Ink Absorber Full" Error 27 showed on display.
Your ink absorber is full message error 27 came up when I tried to print. She won't let me change the ink cartridge or print anything? What can I do to fix this problem?
  • Anonymous Oct 07, 2008
    help
    Sergeant:
    Champion:
  • 331 Answers
Do u have a reset button on te printer
Posted on Oct 11, 2008
How to solve the problem of "Waste ink absorber is full", then show "check printer" & "5800" after continuing to use it for Canon MP150 Printer?
Use this method with your own risk!!
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
Reset E27 Waste ink absorber full or platen waste ink absorber full for Mp170
firstly download MPTOOL
Download here
Download manual guide how to use MPtool
download here
OK hope this can help
Jul 12, 2010 | Canon PIXMA MP170 All-In-One InkJet...
Tank for used ink is full - how do I change it?
Issue: Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error)
Solution: Press the <RESUME/CANCEL> button to clear the error (1700)
Waste ink absorber error 1700
The printer has a built-in waste ink absorber to hold the ink used during print head cleaning. Eight flashes indicates that this absorber is nearly full.
Press the <RESUME/CANCEL> button on the printer to clear the error, so you can continue the print job. The printer will need to be serviced as soon as possible.
Dec 14, 2009 | Canon PIXMA iP2000 InkJet Printer
ERROR E 2 comes up on the little lcd screen when i try to print now.
www.fixyourownprinter.com
ERROR CODE CANNON MP150/MP160
E2 - No paper (ASF)
E3 - Paper jam
E4 - No ink
E5 - The ink cartridges are not installed or a non-supported ink cartridge is installed , or the ink cartridges are not installed properly
E8 - Waste ink absorber full, or platen waste ink absorber full «ОК»)
E9 - The connected digital camera / video camera does not support Camera Direct Printing
E14 - The Ink cartridges whose destination are wrong
E15 - Ink cartridge is not installed
E19 - Failed to scan head alignment sheet
E22 - Carriage error
E23 - Paper feed error
E24 - Purge unit error
E25 - ASF(cam) sensor error
E26 - Internal temperature rise error
E27 - Waste ink absorber full or platen waste ink absorber full
E28 - Ink cartridge temperature rise error -
E29 - EEPROM error
E33 - Paper feed position error
E35 - USB Host VBUD over current error - USB
E37 - Abnormal motor driver error
E40 - Other hardware error
E42 - Scanner error
Oct 26, 2009 | Canon PIXMA MP160 All-In-One Printer
Our Canon Pixma MP150 is showing an error message E5 and previously E3. Can you tell me what these mean please.
here are the error codes for your printer
E2 - No paper (ASF)
E3 - Paper jam
E4 - No ink
E29 - EEPROM error
E42 - Scanner error
Oct 16, 2009 | Canon PIXMA MP150 All-In-One InkJet...
I am getting an 5800 error
Ink Absorber Replacement OptionsThis printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible. Press the <OK> button to release the error. You will still be able to print for a short period. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk
the 5800 code. uplug cord from outlet. wait 1 full min, then plug in and let go through self test.
reply for more help.
have a great day and please rate bama46, thank you
Aug 17, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Ink absorber
actually ink absorber is full means you printer inside got small pieces towel
to absorb ink. but Canon PIXMA printers display an error when a certain internal counter suggests that the ink absorber may be full. If you've done a lot of printing, the ink absorber may actually be full and you might need to have it cleaned or replaced to ensure the best printing quality. However, if you haven't printed that much or you have and you just need to print something right this minute, there is a way to reset the counter and stop the error from showing up again
please try go to this website :
http://ij-forum.blogspot.com/2008/09/how-to-reset-ink-level-of-fine.html
the you go left hand side download General Tools (EEPROM Resetter) Collection and install on you cpu.
after download remember to turn on printer before install it.then go to Reset ink counter by clicking Reset main on waste ink counter menu
try this if can't i think you need send to shop for technician to open it and clearning for you....
Aug 17, 2009 | Canon PIXMA iP1600 Printer
I too replaced the ink cartridges on my MX700 & had error message
Hi ...
This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible by pressing the <Resume> button on the printer. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk.
Please vote if this helps ... Cheers :)
Aug 07, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Waste Ink near full shows on screen. Won't print!
Hi ...
Cannon Pixma MP780 have an absorber and this error is related to this absorber.
This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible. Press the <Stop/Reset> button to cancel the error. You will still be able to print for a short period. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Canon recommends having the printer serviced before the absorber becomes full. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset.
I would suggest that you take your printer to the nearest cannon service centre and get it repaired.
Don't forget to vote if this helps ... Cheers :)
Jul 17, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Canon MP145 Ink Absorber Full Problem.
I got on error message when started to print.
It’s kept happened and message dialog box “The ink absorber is full” occurred.
Mine is Canon MP145.
Can somebody please help me , on how to fix this problem !
tq
Jan 13, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Waste tank absorber is almost full ~ message
This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible. Press the <OK> button to cancel the error. You will still be able to print for a short period. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Personally, I wouldn't do it myself, I'd inquire w/ Canon about how much it would cost to have it done first...
Maggie B
Feb 10, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
199 people viewed this question
old marine
old marine
