Set up universal remote
I need to program my "ONE FOR ALL'' urc-4330B03 to my '' SHARP' LCD TV with built-in dvd player. Please give me the 4 digit code or where do I go to find it?
Thank you,
Grand Ma Deb-e
  • 22 Answers
Here's a link to the manual in pdf format:http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=oneforall&dv=universalremote&md=urc43304devicebigeasy&kw=&st=&ar=&dt=&so=&pg=2&file=others/one_for_all/urc4330-manual.zip
Posted on Aug 19, 2009
Total Control Universal Remote. URC 4140. What is the 4 digit code to operate the above TV
Search Results
    [PDF]Total Control URC-4140 - Universal Remote Control Codes
    www.remotecodelist.com/remotes/URC_4140_B00_and_B01.pdf
    UNIVERSAL. Remote control. URC - 4140 ... Your TOTAL CONTROL can operate four devices: a Television, ... The TV, VCR/DVD, SAT and AUX keys select the device.... 4. Enter your four-digit code using the number keys. The red light will blink twice.... To set up your other devices, follow the same instructions above, only.
    Codes and links for a number of universal remote controls, including Sony, RCA, ... GE Remote Codes, General instructions for GE Universal 3 and 4 digit remote controls. ... This manual may work for a number of Philips-Magnavox remotes. ... Total Control URC-4140, PDF Instruction Manual (remote also known as Crest .
Jan 13, 2016 | Sanyo 42 in. LCD TV
Need code for magnavox tv urc-4021boo
Hi, the codes you have requested;
Magnavox - 0054, 0706, 0030, 1454, 1254
Instructions to program code:
1. Turn on a desired device (e.g.,VCR or DVD player) and, if applicable, insert media (e.g., cassette or disc). NOTE: Please read steps 2 through 4 completely before proceeding. Highlight or write down the codes and device you wish to program before starting step 2.
2. On the remote control,press a device key once (i.e., VCR/PVR, DVD, CBL/SAT,or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo, or TV/VCR/DVD Player Combo press VCR/PVR once.After programming a VCR Combo device, you will be able to control channel selection, volume, and VCR functions. NOTE: To program control of a DVD Player,DVD Player/VCR Combo, or TV/DVD Player Combo, press DVD once.After programming a DVD Combo device, you will be able to control channel selection, volume, and DVD functions. NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR) Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR) Combo, press CBL/SAT once.
3. Press and hold SET until the LED (red light) blinks twice,then release SET.
4. Use the Manufacturer's Codes (starting on page 18) to locate the type of device and brand name and then enter the first four-digit code for your device. If performed correctly,
the LED will blink twice. NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter
the same code again.
5. Aim the remote control at the device and press POWER once.The device should turn off. If it does not, repeat steps 2 through 5, trying each code for your brand until you find one that works.
Feb 12, 2011 | One For All URC-4021 Remote Control
Need the code for one for all universal remote to
The code for a URC-3021 to control a Toshiba DVD player is 0503.
To setup your URC-3021 for the DVD player, these are the steps:
1. Turn on your DVD.
2. On the remote control, press DVD once.
then release SET.
4. Enter the first four-digit code for your device. If performed correctly,
the LED will blink twice. If the LED did not blink twice, repeat steps 2 through 4 and enter the same code again.
5. Aim the remote control at the device and press POWER once. The device should turn off.
Hope that helps.
Oct 25, 2009 | One For All URC-3021 Remote Control
Need to program sharp tv, no codes, manual lost
here's a link to the manual in pdf format: http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=oneforall&dv=universalremote&md=urc43304devicebigeasy&kw=&st=&ar=&dt=&so=&pg=2&file=others/one_for_all/urc4330-manual.zip
Jun 03, 2009 | One For All URC-4330 Remote Control
Need codes for Sharp Tv. I have an older
URC-3220 One for All Big Easy 3 Universal Remote
I can help you to program your One For All Big Easy URC-3220 Universal Remote to control your Sharp TV.
Please review my Fixya Tip posts for:
  1. Searching for the proper codes, or
  2. Downloading the URC-3220 users manual / owners guide. This contains all the codes for the brands of devices your remote can control.
I hope that helps.
Mar 08, 2009 | LGDVB418 DVD Player
I need codes for URC-3021BOO universal remote
i need code for urc 3021B00 on element lcd flat tv.
Feb 19, 2009 | One For All URC-3021 Remote Control
URC-3021B00
PROGRAMMING DEVICE CONTROL
The One For All 3 Device Universal Remote Control is preprogrammed at
the factory to operate an RCA TV, a Toshiba DVD player, and a Motorola
cable box.To control devices other than the default brands,perform the following
steps; otherwise skip this section:
2. On the remote control,press a device key once (i.e., DVD/VCR,
CBL/SAT,or TV).
or TV/VCR/DVD Player Combo press DVD/VCR once.After programming
Combo, or TV/DVD Player Combo, press DVD/VCR once.After programming
then release SET.
4. Use the Manufacturer’s Codes (starting on page 18) to
you find one that works. If it still doesn’t work, try
Searching For Your Code on next page.
NOTE: If the device does not have a POWER key, press PLAY.
6. Repeat steps 1 through 5 for each device you want to control.
For future reference,write down each working device
Here is a link to your manual:
http://www.ofausa.com/remote_manual/CTGA...
Nov 26, 2007 | One For All URC-3021 Remote Control
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
