Question about Acoustic A-5640 Computer Speakers
Accent acoustics no power with transformer
I've lost the original power source transformer to my accent acoustics speakers, but see this unit (of 2 speakers and one subwoofer) is run by a 9v transformer. I have several 9v adapters in my "electronics box" and have tried them. However, none of them will bring power to the woofer and speakers. What do you think is the problem. Is it internal in the unit itself, or does it have to do with an improper transformer. Thanks for your help. Kathy Trawick
  • 3 Answers
I have the same problem at the moment. I cannot find my power cord either.
One thing I noticed is that the polarity of this connection is opposite of all of my other 9V power adapters. The 'pole' is negative on this speaker set. That means that the inside of the plug (the hole) has to be the negative. See if that might be your problem. Finding an adapter with the correct polarity and amperage is key. I am trying to figure out the amperage by searching the web.
Posted on Nov 07, 2008
Although my turntable seems to be fine there is hardly any sound coming through my amp/speakers from it. I'm using a different power lead for it since I've lost my original but it fits fine an
your needle has worn down, or the RCA leads(red & white) arn't plugged in to the phono socket on the amp,or you haven't selected phono on the source select,or you have the tape monitor button switched on.
Jul 07, 2012 | Technics SL-BD22 Turntable
All static from the sound bar. adjustments don't help. tried different cables - that didn't help. System is not usable at this time.
The manual...
http://www.retrevo.com/search?q=Boston+Acoustics+TVee+Model+Two
Page 7
Distorted sound from the Soundbar.
Change the Trim Level switch setting to a higher number.
Check the signal source to be sure the distortion is not originating there. <<<<<<<<<
The woofer seems to have interference with its wireless signal.
Try changing settings of the Wireless ID switches on both the soundbar and bass unit. <<<<<<<<
The bass unit could be too far from the soundbar to get a good signal. Try moving it closer.
What is the source device that results in static? How is it connected?
Feb 08, 2011 | Boston Acoustics TVee Model Two TV...
Lost the adapter. I know i need a 9 V dc transformer, but what is the amp required?
This is all i could find
requiring 9VDC 500ma power .... Cyber Acoustics Studio CA-3000WW Multimedia Speaker System
Aug 03, 2010 | Cyber Acoustics CA-3000 Computer Speakers
Need 24v power supply, where can i get one.
Hi JR,
You didn't specify AC or DC. That's ok, I'm having a two-fer-one special.
Doorbell transformers give back 24VAC
Two 12VDC batteries in series gives you 24VDC. Overkill?
Transformers from many HP printers ar between 20 to 30 VDC.
The source I use is GoodWill. In the electronics or computers section, they usually have a big box of them.
Hope this helps you out
Mike
Oct 11, 2009 | Boston Acoustics Audio Players & Recorders
Need new Power Supply Boston Acoustics Model No.
Boston Acoustics 12VAC 3000mA (3A) Adapter -BA Model DM12-3A0-1AN Only Source: BA Direct (in NJ: 978/538-5000) $54.00 (Incl. S&H) Ordered one on 7/8/09. Meow! Florida
Apr 01, 2009 | Boston Acoustics BA7500 Computer Speakers
Lost ac adapter and dont know how to connect
just use some other adaptor round the house that will fit.
or you can buy a multi adaptor ac for it
thanks
Feb 21, 2009 | Cyber Acoustics Accent S-3022 Computer...
Background hum
I fixed the same issue by replacing the original AC power supply with a 13.8 volt DC power supply (Radio Shack) It seems to be more consistent at high SPL and no hum , as the Boston acoustic unit accepts either AC or DC power.
Jan 29, 2009 | Boston Acoustics MediaTheater Computer...
POWER SUPPLY
Hi, the mA rating for this power adapter is 1500 mA !! I'm gonna give you all the specs. you need to order a new one, and I'm gonna tell you where you can order a new one at; at your preference ?
POWER SUPPLY/POWER ADAPTER TRANSFORMER FOR:(WALL PLUG IN)
BOSTON ACOUSTICS MICROMEDIA SYSTEM 7000596
2.1 SURROUND (2 SATELLITES) (1 SUBWOOFER)
MODEL # WK1201A5-1 AN (THIS IS THE MODEL # FOR THE PLUG)
I/P(INPUT) 120 VAC 60 HZ / 23 VA
O/P(OUTPUT) 12 VAC 1500 Ma
This is all the info you need to order a brand new one in the box.
Go to www.emtcompany.com and in your search box punch in the model # wk1201a5-1an. they cost 29.99 new but its worth it for a great sound system. good luck and I hope I helped a bit
steve - if you have any further questions, i will be glad to help out, you can email me bostonrox129@yahoo.com
Aug 28, 2008 | Boston Acoustics MicroMedia Computer...
Lots of problems please help!
  1. firstly you check the cable loose/break,
  2. check it by using multimeter
  3. dry soldering, loose contact
  4. resolder soldering points or reconnect cable
  5. your powersupply transformer coil may breaked now it become loose contact.
  6. you check the supply output voltage with and without load
  7. if low or no output voltage replace supply
  8. if you don't get the proper transformer rewind it
  9. also check power amplifier section short ckt
Jan 17, 2008 | Cyber Acoustics CA-3550 Computer Speakers
Acoustic A-5640 Computer Speakers Logo
422 people viewed this question
Top Acoustic Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Steve K
Are you an Acoustic Audio Player and Recorder Expert? Answer questions, earn points and help others
