Question about Frigidaire FSC23F7D Side by Side Refrigerator
Frigidaire frs26znhd1 freezer seems to be icing up and refrigerator is warm
  • Anonymous Jan 01, 2009
    frigidaireFRTl8S6A00 Serial#BAll200l7l freezer icing up back panel and sides refrigerator warm
  • 115 Answers
You have a bad defrost thermostat or defrost heater the way to get to both of these is go inside your freezer section and take off the panel on bottom the defrost t-stat is on top of the coil clipped to the line and the defrost heater goes up under the coil
Posted on Dec 30, 2008
Why are only drawers in fridge cold & not making ice?
Contact a professional. Sounds like either your damper door is not operating correctly and not letting enough cool air from the freezer enter, or there is an air leak that is making ice form .
Aug 12, 2012 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire Gallery Warm Refrigerator Cold Freezer
Generally the thermostat that turns on and off the compressor is in the freezer and so is the coils. The control knob that is in the refrigerator section is just to adjust the air flow between the two sections. If the air flow is blocked you don't get cooling in the refrigerator section. This could be a bad fan motor not creating circulation, ice blockage because the defrost cycle is not melting away ice accumulation. If it's defrost problems it could be timer, defrost thermostat, or heater element.
Feb 29, 2012 | Frigidaire Gallery GLRT218WD Stainless...
Ice from ice maker sticking together. Is the temp in the freezer to high or to warm causing this?? The ice is just one big clump of ice cubes all stuck together!!
to warm or maybe staying in deforest to long if you don't have a good amount food in the freezer it will warm up in deforest and make ice to lump
Sep 29, 2010 | Frigidaire Refrigerators
Ice keeps building up in freezer. Then the refrigerator stops cooling. You can get the ice off the vents in bottom back of freezer and it will start cooling again but only last a couple days before it...
Your freezer coil needs a good defrost. You are getting only a little bit of the ice off. It stops cooling because the ice acts like a insulator over the coil so it is unable to cool. Was to get this done is to empty it out and shut if off and leave the door open or maybe a hair dryer or even so warm water.
I hope this helps.
Apr 20, 2010 | Frigidaire FRT17G4B Top Freezer...
Frigidaire White 16.5 cu. ft. Top Freezer Refrigerator (FRT17HB3)- The freezer works, the refridge portion is warm, it started last week ans seemed intermitten, we turned the cooling higher and it was fine...
All of your cooling coils on this model are located in the freezer. If you are cold enough in the freezer your problem is air flow to the fresh food section.
- There is fan behind the back wall of the freezer, be sure that is running.
- Look for frost build up on the back wall of the freezer, if present we have a defrost problem
- look for the duct or channels between the floor and freezer and top of the refrigerator they could be blocked with ice, if so we have a drain problem.
Let me know what you find and I will help you from there.
Apr 18, 2010 | Frigidaire 20.6 cu. ft. Top Freezer...
I have a frigidaire gallery series frig side by side with ice and water in door. The frig part won't stay cold. It also seems to take long time to make ice. The frig part works ok for awhile and then...
Check for two things. Look under the refrigerator and make sure the compressor fan is turning.
Second, check inside the freezer for proper operation of the fan that moves cool air throughout the freezer and refrigerator. If this fan is working, you can probably hear it. It should be behind an access plate in the freezer (near the top). Remove the plate and look at the fan. If it's not turning, you will have to replace the fan motor.
Oct 17, 2009 | Frigidaire FRS23KF7AB Side by Side...
Freezer is cold, bottom compartment warm
check to see if if the back wall of the freezer is full of ice if so this is an automatic defrost problem
timer ,heater or limit switch
Apr 23, 2009 | Frigidaire FRT21H7AS Top Freezer...
My refrigerator is 60 degrees and my freezer is hovering around 25 degrees
Seems to me that your defrosting timer is not working.When defrosting is not working unit will collect ice on element(Hidden)Could also be fan inside refrigerator which is not working properly.You need a repairman.Jan
Feb 02, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Bottom is too warm
Make sure your fan is working ,its in the freezer behind panel .If not the fan your passage area is probably covered with ice and the air cant get in freezer
Jun 14, 2008 | Frigidaire FRT15G5CS Top Freezer...
Frigidaire FSC23F7D Side by Side Refrigerator Logo
196 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
