Question about Moulinex DG6 Food Processor
Moulinox ovatio 3 dur - Pusher missing and need plastic kneading blade
The pusher part is missing in the original packing and need to order the plastic kneading blade - Part # 5966 922. thank you
Having contacted the Moulinex main office in Canada, I was informed that they do not ship parts to the US. However, they directed to the US sales office - contact "customer Service - Abtec Parts" <> who carry replacement parts for a large number of applicances. Hope this information helps someone in need. Thank you.
Posted on Oct 01, 2008
Insert pusher
"insert pusher" ...this just happened to me too! Such a simple fix! ...The handle needs to face the front!.. Yes, it all clicks in nice the other way around, but if the handle is facing the rear of the unit, you will get the error "insert pusher" and the machine will not work.
Jul 20, 2014 | Breville BFP800XL Sous Chef Food Processor
Need food pusher for this machine
The food pusher is no longer available for this model. Suggest you contact the official parts supplier for Black & Decker and see if they can recommend a pusher that is compatible.
See here for contact information:
Dec 12, 2011 | Black & Decker FP1400 Quick N Easy Plus...
This is an inquiry about Waring food processor model FP510; SN# 11FP10. I need a new driver (the thing with a hex head that fits over the axle or drive shaft (one side of the axle is flat) of the electric...
I broke mine too, but luckily I found an extra machine at a thrift store. The driver was missing (of course), but I cut the blades off (hacksaw, easy) and used the resulting shaft as a driver. It works well: better and tougher than the original! Though they are expensive, you can order a new set of blades and do the same thing with the blades you have now. -Paul
Dec 13, 2010 | Waring FPC15 10 Cups Food Processor
Cuisinart dlc-7 superpro food processor won't run.
The DLC-7 SuperPro is awesome -- very powerfull. Be aware they are 1.5 horsepower; the blade can take your hand completely off in a blink of an eye. Because of the potential danger, SAFEGUARDS are in place such that everything must be aligned and in correct position or it WILL NOT POWER-UP. So, yes, is very likely the safety switch.
Simple test: Use just the BASE, (no work bucket, no top, no blades), such that if it starts, only the spindle will turn. There is a little black button on the base, just back of the spindle. Use a chop-stick to depress it. Plug-in, press the button w/chop-stik, press the PULSE button. It should power up.
Presuming it powered up okay, the "problem" is probably in how the unit is assembled; such that the button is depressed properly.
1. The work bowl must be all the way down on the base, and the alignment column in the back, work bowl base skirt turned to the "Hard Stop". It will feel very solid when docked properly.
2. The top inserts and rotates into and snaps into position while pressing the plunger into the button.
It all sounds too easy, but if something is just a little off, the plunger doesn't plunge ind the power doesn't go on.
These are FABULOUS machines -- spend the time into getting it working. The near- equivalent if something this robust and powerful in today's products will cost nearly a THOUSAND dollars - seriously.
May 04, 2009 | Cuisinart DLC-2014 PowerPrep Plus Food...
I cannot get the top off the main cylinder on my DLC-85
The pusher sleeve has what I describe as a plastic "clip" on it - if you look carefully at this clip, there is a circle that says "Press Here". If you press on that clip, the whole pusher sleeve will ocme out, and then you will be able to remove the lid.
May 02, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
WE need the pusher/sleeve assembly. The motor is
I don't recognize model #PLE-8E, but if you have a DLC-8E, while you can't get the original parts from Cuisinart, you can get a whole bowl/pusher/lid that will operate your old base. I also see a few auctions for the original DLC-8 series parts, but there is some asterisk by each of them - they will work, but they have a chip somewhere, etc. But, I would keep your eye on eBay - I picked up many a good Cuisinart item at a bargain price.
Feb 28, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
I have spare parts GE 4-speed Food processor model 106622f
I would like to have the lid. Please let me know how to pay you for it. THanKs
Feb 20, 2009 | GE 106622F Food Processor
Kneading blade stuck
plz contact 022-23051554 /23095757
Feb 02, 2009 | KitchenAid KFP750 Food Processor
Moulinex DG6 Food Processor Logo
365 people viewed this question
Top Moulinex Food Processors Experts
Level 1 Expert
Colin Stickland
Colin Stickland
Are you a Moulinex Food Processor Expert? Answer questions, earn points and help others
