Question about Maytag Kitchen Ranges
Maytag CWE4800ACB won't bake - Maytag Kitchen Ranges
    Scholar:
  • 47 Answers
Actually found that the bottom element was not heating, due to the fact that the wire is melted and broken off of back of unit.
Posted on Sep 30, 2008
Maytag cwe4800acb oven shuts off and display goes blank during heating
Display on maytag oven 8114p471-60 went blank - Fixya
www.fixya.com/.../t16018814-display_maytag_oven_8114p471_60_we...
Jan 20, 2013 - Stove top electric ignition still works fine, so there is power going to the .... maytag cwe4800acb oven shuts off and display goes blank during .
Oct 10, 2015 | Maytag CWE4800ACB 2.6 cu. ft. 24" Single...
Maytag electric wall oven model #CWE4800ACB
Try shutting off the breaker and turning it back on after a few minutes.
Sep 05, 2014 | Ovens
Maytag oven won t heat up
the upper element only comes on when you broil or clean with selfcleaner. the bottom comes on when you are baking, it sounds like your bottom element is bad.
May 07, 2014 | Maytag Ovens
Maytag Oven won't work
either you element is bad or the relay on your control will not open , if able check voltage to element and inspect element for defect .
Feb 20, 2013 | Maytag Kitchen Ranges
My maytag super capacity plus won't unlock after
this would be the best source look at link i hope it help out
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwjhpKi-i5TXAhVmyoMKHX_OAtMQFggnMAA&url=http%3A%2F%2Fproducthelp.maytag.com%2FCooking%2FWall_Ovens_and_Ranges%2FOven_Product_Assistance%2FHow_to_open_a_locked_oven_door&usg=AOvVaw3VNunJSAkZGld_PY0xGM3s
Oct 28, 2017 | Maytag Ovens
Oven won't bake F-4 signal
God i havent been around i hope you unpluged this unit by now, leave unpluged for a few min's , this will usually fix this problem
Nov 24, 2011 | Maytag Ovens
Maytag oven model mgr5770 oven hard to light and doesnt keep temp even when it does gas stops lighter still glows?
The problem beleive it or not is that the bake ignitor is weak ,and it is not drawing the proper amprage to open the gas valve.If you have a amp meter access the wires to the bake ignitor(usually behind the storage drawer) and check for 3.3-3.6 amps when oven is set to bake by clamping the meter around ONE wire wire of ignitor make sure only one wire,either one and not both.
if amp draw less than 3.3-3.6 amps replace bake ignitor. I know it seems improbable that if the ignotor comes on that it could be the problem.Professional appliance technicians who would charge a average of $250.00 to repair your oven,have found when the ignitor comes on yet the oven won't heat that a weak ignitor is the cause 100% of the time
I hope this helps
Gene
Aug 01, 2011 | Maytag Kitchen Ranges
Oven stays on
The oven won't come at all.
Jun 05, 2010 | Maytag Ovens
Burned out element
When the element burned in 2 iot may have tripped your circuit breaker.
Check your breaker box and look for a 40 or 50 amp breaker and flip it off and then back to on. If this doesn't help then a tech. may need to be called for service.
May 05, 2007 | Maytag CWE4800A Electric Single Oven
Kitchen Ranges Logo
83 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
Sal De GO PATS
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
