Question about Edirol UA-25 External Sound System
Can get signal from UA-25 to computer... but no audio from computer to UA-25?
I've got the UA-25 installed, drivers installed, Device manager says it's working properly, and when I hook up my MIDI keyboard to the UA-25 and try to record using it, it works wonderfully. When I change the sound settings of my computer to use the UA-25 instead of my on-board soundcard, I get no audio. My sound settings is set to use the UA-25 as my sound card, I open iTunes, or any other program that makes sound, and I get nothing from the UA-25. I can plug the headphones into the monitor jack on the front, or any of the output jacks on the back, and I get nothing.
Any suggestions?
    Master:
  • 479 Answers
Try reinstalling the device as some of the files may not be copied correctly
Posted on Sep 29, 2008
    Genius:
  • 1,550 Answers
Here is one solution uninstall the default driver or roll back driver. Restart your computer. When you get into windows wait for everything to load and then plug in your audio device. If you have it plugged in when windows starts then it will install a driver. In automatic updates you can select to notify of updates, but lets you install the ones you want.
Thanks for using Fixya
SAM ANDERSON
Do not get MIDI signal via EDIROL UA25
Midi is data only, there is no actual sound to the midi tracks themselves. They need to be assigned to either a software synth or an external synth to actually make the sounds you want to hear.
For instance if you load a demo of a midi sequance you will need to add a software synth such as the TTS-1 or Roland sound canvas which are general midi compatable and will play the instruments sounds assigned to the demo's midi channels. Use the Synth Rack feature in Sonar to open one of them. Then you will need to assign the output of each of the midi tracks to that particular synth and you will get sound. Make sure to assing the synth's audio track to you UA-25 as its audio output.
I would suggest reading in the manual and following the tutorials included in the manual to get yourself familier with how this is all done. spacer.gif
May 25, 2008 | Edirol UA-25 External Sound System
For some reason I cannot select my UA-25 as the ASIO Device in 'Audio System Setup' in VST5. VST 5 always seems to select 'ASIO Multimedia Driver' as the ASIO Device, which has a latency of 750ms. The...
I am using a laptop for my music creation and I am thinking about using an External Sound Card connected with a USB cable or getting an Sound Card. My integrated sound card has a little bit too much latency. Will I have just as much or more latency with the External Sound Card because it is connected with the USB cable or would I be better off with the Sound Card?
Thanks for vinu plz plz plz plz plz plz plz plz help me sir.
Mar 06, 2011 | Edirol UA-25 External Sound System
My computer has recently had a new PSU after a spell of crashing without warning frequently. Since i've had the new PSU my PC won't recognise the Edirol when I plug the USB in. I've tried uninstalling the...
check the lead/s for this edirol make sure it has a secure connection and that its not faulty
have you tried to see it in the device manager
control panel admistrive tools,computer management,device manager you could see a yellow question mark? right click to reinstall drivers or
in the device manager scroll to disk drives + to expand right click on the drive select properties then select enable this device from the drop down list you can also select the driver to update,rollback,uninstall also under policies optimize for quick removal,optimize for performance,restore defaults
hope this helps
Dec 13, 2010 | Edirol UA-25 External Sound System
Every time i try to play any sound through my external sound card Edirol UA 25 my computer reboots it self for no reason. Any one knows why is that happening? my laptop is Advent 9115 and i have...
first try reinstalling the driver of your external audio device, but first uninstall it.
Also check the device itself it may have faults like shorts and the like causing the laptop o protect and restart.
Jul 02, 2010 | Edirol UA-25 External Sound System
No midi sound
In sonar go to the options menu and select: Audio -->advance. and from the list select the "Asio" driver, then you'll have a new midi output (synthe sw...) select it to have a sound while playing MIDI files.
Sep 21, 2008 | Edirol UA-25 External Sound System
Edirol ua-25 not detecting midi but audio works fine
**** THIS IS THE SOLUTION ****
On the back of the UA25 there's a switch called "Advance" - this needs to be set to ON for the device to work as a MIDI interface.
LC (UK).
Feb 27, 2008 | Edirol UA-25 External Sound System
Volume to computer
Right Click on My Computer > Manage
In Computer Management, click on Device Manager. Do you see any Yellow colored traingle sized warning signs there? If you do, then there maybe a driver problem with the sound card. If you don't, locate your audio drivers, and install them again.
Oct 29, 2007 | Edirol UA-4FX External Sound System
Cannot record
some driver has been installed by your device...to go back, do you have "system Restore" turned on? if so, try restoring XP to a time before your device
May 27, 2007 | Edirol UA-25 External Sound System
"digital in" led flashes instead of burning constantly
Sorry, i'm new to the UA-25 as well, but from my understanding, if you are using a digital signal device and it is connected properly, that indicator should be steadily lit. IF you are NOT using a digital signal device and it's flashing, it's because you have the button pressed when you shouldn't have it pressed unless you want your sound to loop through the computer and come back to your headphones.
Sep 01, 2006 | Edirol UA-25 External Sound System
Edirol UA-25 External Sound System Logo
344 people viewed this question
Top Edirol Computers & Internet Experts
David
David
Brian Sullivan
Brian Sullivan
Steven Burn
Steven Burn
Are you an Edirol Computer and Internet Expert? Answer questions, earn points and help others
