Question about GE 29897GE1 Corded Phone
RE ORDER HELP!
OK. Ive lost my corded handset that went with this phone. How can i reorder it?
  • 2,071 Answers
Just click below for the manual,at the end of the manual there is an there,that you can contact and order there.
http://www.home-electronics.net/ge/pc/IB/29897GE1_IB.pdf
Hope it may helps;
Regards,
VOTIT
Posted on Oct 10, 2008
Had a att el52300 base that went bad so bought another one it seems to be working ok. all head sets have out of Range or no Power at base.Tried to clear with answer given but nothing worked Need help
Try the following:
1/ Make sure the power cord is securely plugged in at the base and that it's powered on ie: light is on and working etc..
2/ Reset the telephone base. Unplug the electrical power. Wait for
approximately 15 seconds, then plug it back in. Allow up to one minute for the cordless handset and telephone base to reset.
3/ Place the cordless handset in the telephone base for one minute to allow the cordless handset and base to synchronize.
Manual available here:
at&t el52300 manual
-Charles
Jul 02, 2016 | AT&T El52300 Cordless Phone
I was storing some extension numbers and spead dial numbers and I must have done something wrong as anytime I pick up handset to make a call a 'reorder tone' message comes up on the display- this is before...
So don't pick up the handset :-)
There are some line preference and pickup dial programs that just happen to sit in PROGRAM 1x. My guess is that you have assigned an empty or invalid pickup dial code to the phone.
Try this first. Press PROGRAM and dial 12 ENTER. Is the Hot Line mode ON? If it is, press SEL and ENTER. Wow. That was easy :-)
Didn't work? Let's go for Preferred Line Outgoing next. Dial PROGRAM 19 and 3 ENTER. That makes the intercom prime (0 is none, 1 is idle line 2 (xx) is a specific line).
If you tried both of these, and still no joy, then it's time to reset the phone. The problem with that is you have to dial the code IMMEDIATELY as you're picking up the handset. Good luck with that. The reset code is 79# or 790.
Carl
Jan 25, 2011 | Panasonic KX-T7630 Corded Phone
The cord will not stay in the receiver
There should be a little clip to retain the cord in the handset. If this clip is gone, the cord needs replacing. This clip is a plastic protrusion on the clear (most of the time) connector to the handset or phone. This clip must be depressed in order to remove the cord. If it has been forced and broke off, it will not longer retain the cord.
Cables and cord as well as connectors can be purchased and installed quite easily.
Oct 12, 2010 | RCA 25404RE3 Corded Phone
Avaya 18D phone only speaker works not the handset. Order a replacement phone and the new phone does the same. We swapped locations snd the problem goes with the phone. Handset placed on a known working...
Avaya Partner 18D Button phone:
Two possible solutions,
First, could have a bad handset cord.
Second, I have come across a bad handset connection ports on the Euro style phones. The handset cord and the port just don't mesh well or the port itself is bad.
Feb 09, 2010 | Avaya Partner 18 Eurostyle 18D telephone
The photo slide show is now blank. I have a GE model 27956 DECT6.0 Cordless Handset with Caller ID & Slide Show. I can not view or add new photos to the slideshow. I pushed the reset button, but it...
1/15/09
To fix this issue:
1. Unplug the Unit
2. Unplug the Phone Cord
3. Disconnect the Battery from the Handset
4. Wait 10-15 minutes… and put back together in Reverse Order
5. Connect the Handset Battery
6. Plug-in the Phone Cord
7. Plug-in the Unit
You can do this w/o the phone cord attached.
Dec 30, 2009 | GE Lands Phones
LOST AC CORD TO RECHARGE THE VECTOR VEC-157
u can get the cord from  radioshack just order 1 online for you.
Dec 30, 2008 | Vector 20 Million Power Series Spotlight
Adding handset to Panasonic KX-TGA542M phone. ? how to ?
I ordered a new kx-tg560m handset for my kx-tg5632 base unit, but the enclosed instructions for registering it with the base unit were wrong. Fortunately, I found the old quick setup guide in my files.
If you do not have the same base unit and handset, go to the URL:
http://www.panaxonic.com/RegisterYourHandset.
1. On the handset, press [MENU], then press [0][0]. The handset displays "Refer to manual to prepare base. Then press OK->"
2. On the base unit, press [SELECT] until the desired extension number [H1, H2, H3, or H4] is displayed on the base unit, then press and hold [CALL] until the CHARGE indicator flashes.
3. On the handset, press the [OK] softkey.
When the handset is off and sitting in the charger, the handset's extension is displayed in the upper right corner.
Oct 27, 2008 | Panasonic KX-TG5422M Cordless Phone
Phone problem
At the corded base set go to link handset go to 1 press flash/programm you will be asked to waiting for registration with handset, then go to handset go link base there also click on yes and again on flash/programm button you will be connected
Nov 27, 2007 | GE 25881EE3 Phone
GE 29897GE1 Corded Phone Logo
54 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
