Question about Coleman 10' X 10' Sundome Tent 9160K101
Coleman powermate mod# pm0477023
There is no output on the receptacles
  • Landon V.W May 11, 2010
    More detail and i might beable to help...
    Scholar:
  • 121 Answers
If you have no output thrn there is an open circuit somewhere start at the begining and trace it thourth until you find it.
Posted on Oct 02, 2008
  • 51 Answers
I guess Just Check to make sure all circuts are closed... that is robalbey the best a can do with the info you gave me... try consulting the troubleshooting section in the manual. Hope this helps
No 120v/240 output @twistlock recptacle
The big box home supply centers carry these. match up the current rating and voltage rating on the generator, then buy the receptacle to match.
Jul 27, 2014 | Coleman Powermate Powermate 5000W...
Need a wiring diagram/schematic for the power output end/recepticals for the coleman powermate 5000 model pc0545305.01 generator
Couldn't get you a wiring diagram but the contact info should get you to someone who can. The other links will get the manual and parts breakdowns.
Coleman Powermate Powermate 5000W Generator
http://www.powermate.com/contact.php
http://www.powermate.com/pdfs/2007/11/12/manual_pc0105000.pdf
http://www.powermate.com/pdfs/2007/11/12/parts_pc0105000.pdf
Oct 01, 2012 | Coleman Powermate Powermate 5000W...
Have a coleman powermate 6750 generator that has quit producing power.
If the engine is running with the alternator not outputting then you must check with the LOAD TRIP switch.
if not remove the load and check if there is output. If not there is fault in tha alternator which might need some consensus.
Nov 05, 2011 | Coleman Powermate Powermate 5000W...
I purchased a Coleman Powermate 5000 6 years ago: Ser: 94411583. Never really used it for any length of time. Kept for emergency. An electrician checked it for voltage output a short time ago. 240V...
Voltage is adjusted by raising or lowering the engine speed (governor adjustment), however one must also pay attention to the rpm because your generator was designed to produce 120 volts at 60 cycles while turning 3600 rpm. Your electrician should have tested for htz while testing for voltage. I would recommend re-testing under load and adjust governor to turn 60 cycles to see resulting voltage.
Sep 30, 2010 | Coleman Powermate Powermate 5000W...
Have older powermate 5000 contractor gen. runs great but only puts out 5.5 to6.1 volts. has new brushes
Hello. Plug something into your generator's receptacle, say a trouble light. Then check the output. With no load at all [nothing plugged in, you will get a voltage reading that is low. regards, Joe
Jan 28, 2010 | Coleman Powermate Powermate 5000W...
I have a Coleman Powermate 5000 / No power output
Two suggestions. One: check for voltage from the secondary coil wires (if it has one). Two: unless stated do not do this, I have always flashed the excitor circuit through the 120vac receptical. Give these a shoot and I hope it works for you.
Mar 30, 2009 | Coleman Powermate Powermate 5000W...
Powermate 6250 model pm0545007.01 engine runs no a.c. output
You will need to install new diodes,they are located in the plastic housing behind the receptacles...It looks like little spark plugs..They work to put dc voltage to the rotor,without the exciter voltage applied,you will not get ac power out..The part number is 3483.01....You can buy these online for about $6 each,they have 2 inside the generator,and you should change both.
Dec 17, 2008 | Coleman Powermate Premium Plus 6250W...
Coleman 10' X 10' Sundome Tent 9160K101 Logo
163 people viewed this question
Top Coleman Sport & Outdoor - Others Experts
David Payne
David Payne
Vernon Taylor
Thomas Perkins
Thomas Perkins
Are you a Coleman Sport and Outdoor - Other Expert? Answer questions, earn points and help others
