Question about Lexmark Office Equipment & Supplies
Have Lexmark X9350 All in one - Need to block incoming junk faxes
  • 24 Answers
You can find these instructions on page 140 of the User's Guide. The English User's Guide is here: http://images.lexmark.com/publications/pdfs/2007/9300/v1116690_en.pdf
If you have Caller ID, you can block faxes sent from specific numbers and/or all faxes which do not include a Caller ID number.
To turn on the Block List feature:
  1. From the control panel, press up arrow or down arrow repeatedly until Fax is highlighted.
  2. Press select (checkmark).
  3. Press up arrow or down arrow repeatedly until the Fax Setup submenu is highlighted.
  4. Press select (checkmark).
  5. Press up arrow or down arrow repeatedly until the Fax Blocking submenu is highlighted.
  6. Press select (checkmark).
  7. Press up arrow or down arrow repeatedly until you reach the Block List menu item.
  8. Press left arrow or right arrow repeatedly until On appears.
  9. Press left curved arrow to save and exit.
To add each fax number you want to block:
  7. Press up arrow or down arrow repeatedly until you reach Blocked Fax Add Entry.
  8. Press select (checkmark).
  9. Use the keypad numbers to enter the name of the person associated with the fax number in the Name field.
  10. Press down arrow once.
  11. Use the keypad numbers to enter the fax number in the Fax Number field.
  12. Press left curved arrow to save and exit.
To block faxes sent from an unidentified number (a number with no Caller ID):
  7. Press up arrow or down arrow repeatedly until you reach the Block No-ID menu item.
  8. Press up left arrow or right arrow repeatedly until On appears.
Posted on Sep 29, 2008
How do i set up my lexmark x9350 all in one fax machine to my computer so it can work.
If you have the installation disc, insert it into your hard drive. Follow the instructions on your computer screen. If you don't have the disc, please visit the Lexmark website at http://bit.ly/jwG67O. Download the driver (Note: use Vista driver in Windows 7.), execute the file and follow the instructions on your computer screen.
Jun 20, 2011 | Lexmark X9350 All-In-One InkJet Printer
Incoming faxes are not received
1. Make sure you have paper in the feeder tray.2. Make sure that Fax Forwarding is not selected: Use the up/down arrow buttons to scroll through the menuoptions until you see the option required, and press the "check mark" button to select:
Select "Fax" on the device main menu. Select "Fax Setup" from the Fax submenu, Select "Ringing and Answering" from the Fax Setup submenu Now find the "Fax Forward" option. Once you see this option, press the left or right arrow buttons until you see "Off". Now press the "Enter" button to save.
Let me know if this doesn't solve your problem, and include further detail to the problem if available.
Jan 21, 2008 | Lexmark X9350 All-In-One InkJet Printer
My printer will print everything but faxes
Here is a link to the users guide of the printer. In page 130 you will find specific details on how to setup the printer to receive and print faxes automatically.
http://bit.ly/cLSELk
Feb 08, 2010 | Lexmark X9350 All-In-One InkJet Printer
How can i block a junk fax number in a hp j3640 thanks in advance
Set the junk fax mode
By default, Block Junk Fax mode is turned On . If you do not subscribe to a caller ID service through your phone provider, or do not want to use this feature, you can turn off this setting.
To set the junk fax mode
Press Setup .
Press the right arrow to select Basic Fax Setup , and then press OK .
Press the right arrow to select Junk Fax Blocker Set Up .
Press the right arrow to select Block Junk Fax the press OK .
When prompted, press 1 for Yes or 2 for No .
Add numbers to the junk fax list
There are two ways to add a number to your junk list. You can select numbers from your caller ID history, or you can enter new numbers. The numbers in your junk list will be blocked if Block Junk Fax mode is set to On .
To select a number from the caller ID list
Press Setup .
Press the right arrow to select Basic Fax Setup then press OK .
Press the right arrow to select Add Number to Junk List , and then press the right arrow to select Number and then press OK .
Press the right arrow to scroll through the numbers from which you have received faxes. When the number you want to block appears, press OK to select it.
When the Select Another? prompt displays, do one of the following:
If you want to add another number to the list of junk fax numbers , press 1 to select Yes , and then repeat step 4 for each number you want to block.
If you are done , press 2 to select No .
To manually enter a number to block
Press Setup .
Press the right arrow to select Basic Fax Setup press OK .
Then press the right arrow to select Junk Fax Blocker Set Up and then press OK .
Press the right arrow to select Add Number to Junk List press OK , and then press the right arrow to select Enter Number .
Use the keypad to enter a fax number to block and then press OK . Make sure you enter the fax number as it appears on the display, and not the fax number that appears on the fax header of the received fax, as these numbers can be different.
When the Enter Another? prompt displays, do one of the following:
Remove numbers from the junk fax list
If you no longer want to block a fax number that number can be removed from the junk fax list.
To remove numbers from the junk fax list
Press Setup .
Press the right arrow to select Basic Fax Setup then press OK , and then press the right arrow again to select Junk Fax Blocker Set Up then press OK .
Press the right arrow to select Remove Number from Junk List .
Press the right arrow to scroll through the blocked numbers. When the number you want to remove displays, press OK to select it.
When the Delete Another? prompt displays, do one of the following:
If you want to remove another number from the list of junk fax numbers , press 1 to select Yes , and then repeat step 4 for each number you want to block.
If you subscribe to a caller ID service through your phone provider, you can block specific fax numbers, so the HP Fax does not print faxes received from those numbers in the future. When an incoming fax call is received, the HP Fax compares the number to the list of junk fax numbers you set up to determine if the call should be blocked. If the number matches a number in the blocked fax numbers list, the fax is not printed. (The maximum number of fax numbers you can block varies by model.)
Thank you.
Sep 17, 2009 | HP J3680 Officejet All In One Printer
We have a lexmark x9350 all in one printer, scanner, fax ect. but don't have a user guide ir manual. Can you email us one? Or tell us where to obtain one? many thanks, Roy
You may want to check the driver disc you got with the printer. Many mfrs are not including print documentation but they provide an electronic copy with the supplied media. Otherwise, you can download it from Lexmark at http://images.lexmark.com/publications/pdfs/2007/9300/v1116690_en.pdf
Jun 07, 2009 | Lexmark X9350 All-In-One InkJet Printer
BLOCKED CALLS
specific fax numbers so the device does not print faxes received from those numbers.
When an incoming fax call is received, the device compares the number to the list of
junk fax numbers to determine if the call should be blocked. If the number matches a
By default, Block Junk Fax mode is turned On. If you do not subscribe to a caller ID
off this setting.
▲ Some models have a Block Junk Fax button. Depending on the model you have,
Block Junk Fax button: Press the Junk Fax Blocker button, select the Block
Junk Fax option, and then select On or Off.
Color display menu: Press Setup, select Basic Fax Menu, select Junk Fax
Blocker Setup, select Block Junk Fax, and then select On or Off.
your caller ID history, or you can enter new numbers. The numbers in your junk list are
blocked if Block Junk Fax mode is set to On.
Feb 11, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Initial set up for fax.
Turns out I'd never had a problem in the first place. Lexmark - predictably - had people like me in mind when they designed there milti function printers particularly the X9350 Series. All I ever had to do was plug in a phone line into the correct port on the back of the prntr and the set-up software that I installed when I bought it does all the rest. It's terrific! The printer's software automatically found and configured my laptop and activated the fax function in the productivity suite the comes with the printer. There seem to be a lot of smart people at Lexmark. They've impressed the hell out of me.
Sep 26, 2008 | Lexmark X9350 All-In-One InkJet Printer
Fax Cover Sheets
Call tech support! That's why these people get paid. Sites like this wouldn't need to exist if they did their jobs correctly!
Mar 11, 2008 | Lexmark X9350 All-In-One InkJet Printer
Fax dial tone
sure...check the line, with a phone..do you have call waiting or something like that enabled..that can cause some issues, with the tone interruption to the internal modem.
Nov 14, 2007 | Lexmark X9350 All-In-One InkJet Printer
370 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
