Water leaking from the machine from the base - Washing Machines
I have the same problem i have a tromm lg front load yesterday i pulled it out some and removed the back cover 4 screws turned the machine on and with a flashlight i found where the water was comeing from it was a hose on top but i still need to find out how to get to it
Posted on Sep 29, 2008
What to do to rectify water coming from the base of the washing machine?
The water will be from either the incoming mains water supply or the drainage system or the door seal etc.
check to see if its clean and clear, mains cold water.
or
grey soapy, waste water.
3 of the most common leaks are on the waste system.
1. the door seal.
2. the ribbed grey waste hose can leak when water is being pumped out, usually at the ribs of the hose.
3 the inspection port on the bottom front of the machine, which usually collects 5p's, 1p's, underwire from underwear etc.
Nov 21, 2014 | Samsung Computers & Internet
How to repair water leak from tassimo base?
The water tank at the rear must make a proper seal. Make sure it is clean and lubricate with Vaseline. The cup tray also catches drips so remove it and empty any water into the sink.
Nov 04, 2014 | Braun Tassimo Espresso Machine/Coffee...
My asko d1706 dishwasher doesnt let water in. As I
Base pan full of water means there is a water leak. So your machine has a flood detector (floater) and it prevents feeding further water into the machine to prevent the flooding. I think this is the reason. You have to fix the leak.
Just to make sure first clean the base pan water and try it. It will work until again water leaks and activate the floater (flood switch)
Sep 25, 2014 | Dishwashers
Electrolux dishwasher ESF6242, 911 236 182. Before the program was complete, the drain pump went into constant operation and the Error code i30 flashes, denoting 'water in the base' according to...
Hi
You have had a water overflow or leak which has triggered your flood switch. You need to disconnect the machine and pull it out. Throw plenty of towls on the floor and tilt machine back to empty the water from the base.
Hard to say where the overflow or leak is from. You need to reconnect machine while it is out of cabinet and run the machine to see if you can pin point a leak. Sometimes a burst drain hose.
Otherwise the front and side panels may need to be removed as the leak may be internal.
Other time a faulty PCB, faulty inlet solenoid which sticks or a faulty pressure switch or clogged pressure hose are the reasons for machine overflowing. Bad door seals can also cause machine to leak.
Therefore, there are a raft of items which can cause machine to overflow or leak.
Ash
Sep 08, 2011 | Dishwashers
Water leaking from reservoir
I had the same problem. All of a sudden my kitchen top counter got filled with water. The water was leaking from the Nespresso C190 water resevoir at the bottom. Exactly where the reservoir meets the coffee machine base. I had by chance an "O" rubber ring left from a faucet which I inserted at the base of the water rervoir right on the small **** which when it sits on the C190 base lets a valve open in order the water to flow through. The "O" ring was 2 to 3 mm in diameter and about 1 mm thick, You might experiment with different ones until you solve your problem.
Jul 02, 2011 | Nespresso C190 Espresso Machine
Adg 3962 IX showing fault code f2 with flashing
The machine has a switch inside that activates when a set amount of water is loaded.
If this switch then breaks (switches off) during the wash the machine assumes that the water has leaked out.
Run it through a couple of washes, check for a leak and see how it goes.
Hopefully it will be fine.
F2 indicates a flooded base.
Press and hold the start button until the start light goes out. (This resets the appliance)
Select a new programme and try the machine again.
If it comes up with a fault F2, take the panel off below the door and check for water in the base.
Be careful when you take the panel off, the exposed edges are razor sharp.
Drain any water in the base, reset and try the machine again and watch for a leak through the inspection panel.
May 24, 2010 | Dishwashers
Eco light comes on when I switch on machine but can't change programme and it doesn't work some water still under filter
This indicates water in the base, there is a polystyrene float that operates a cut off switch if water leaks into the base, this could be caused by a leaking pipe connection, or simply by water getting by the door seal and eventually having enough volume in the base te operte the float switch, try tilting the machine backwards if water comes out of the basethen this should cure the problem, but if it recurs fairley quickly you should have the hose connections checked for tightness, can be accessed from the base.
the dishwasher should be isolated from the supply first base tray is secured by 6 screws, the float switch is attached to the base so care should be taken when removing the base tray
Apr 23, 2010 | Hotpoint 24 in. FDW60 Free-standing...
Grinding sound SA8605x
Sounds like machine may have activated flood switch- this makes the dishwasher drain continously, which results in a grinding noise once the machine has no more water to pump out.
The flood switch is located in the base of machine- you need to remove bottom front panel to acces (disconnect from power first!!).
Once panel is removed, check:
-Is there water in the base? If so, machine has had a leak- clear water, restart, and locate + repair leak.
-If no water in base, it may have air lock in pressure tube. There is a small clear tube that goes to round flood switch on base of machine- remove tube and blow thru. Reassemble and test machine.
Only attempt if you a confident DIYer- if in doubt, call an expert (you can sometimes make an easy repair an expensive one)
Aug 10, 2009 | Smeg CSU2001 Built-in Dishwasher
Water leaking into machine
This happens when the boiler develops a leak, usually due to scale buildup. Order a new boiler and o-rings and replace.
Sep 29, 2007 | Saeco Magic De Luxe Espresso Machine
Washing Machines Logo
271 people viewed this question
Top Washing Machines Experts
