Question about Kenmore Elite HE4 Electric Dryer
Door opens on its own
Door opens after/during cycle on its own and light stays on
  • 943 Answers
Hi. Thanks for the question. The problem is with the door catch .On the door there should be a small piece of plastic ,sticking out the door and on te front , a catch to catch the striker.You need to replace that part thanks the appliance doc That's a fix ya
Posted on Sep 29, 2008
Whirlpool dishwasher adg7560 troubleshooting The
> broken wire.
>> call the service agent
Oct 17, 2013 | Dishwashers
I have filled dishwasher selected temperature and the start light is flashing but nothing happens I think the m/c type is 7197
The Start/Resume light is flashing
This flashing light indicates that your cycle or start-up was interrupted.
Possible causes: The door opened during the cycle, or the power was interrupted.
To resume operation: Make sure the door is closed, and press Start/Resume.
The Clean light is flashing
You should call for service if the Clean light is flashing and the machine is inoperable. It is normal if the Clean light stays on after the cycle is complete. The Clean light is an indication that the dishwasher has been run and that the dishes inside it are clean. Once the door is opened after the cycle is complete, the light will shut off.
The lights are rapidly flashing
Any key that gets stuck will rapidly flash. Press the key a few times in order to release it or press Cancel.
The Rinse Only light is rapidly flashing
If multiple keys are stuck, the Rinse Only light will flash. Press each key, one at a time, to release the stuck keys, or press cancel.
Jun 28, 2011 | Dishwashers
My Whirlpool Duet washer was out of balance and almost fell over during the spin cycle. The washer was shaking and the front door came open during the spin cycle. Now the front door will not latch and stay...
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Maytag neptune washer clothes staying wet after cycle
Is your door lock light on when machine is in use? I am having the same issue as you and I believe it is because my door is not locking during use.
Apr 17, 2010 | Maytag Neptune MAH5500B Front Load Washer
FRIGIDAIRE DISHWASHER CLEAN LIGHT FLASHING WILL NOT WASH OR DO ANYTHING
Do what 'mrrevo'l says to reset the dishwasher, and next time, try not to open the door during the wash cycle. Make sure that all the cycles are complete before opening the door. Especially don't open the door during the drying cycle.
Jul 15, 2009 | Dishwashers
Dishwasher will not start
Go to your electrical panel and turn off the circuit that feeds your dishwasher. It will also turn off the clean light. Wait three minutes and then turn the circuit back on. That should reset your machine.
Apr 07, 2009 | Electrolux Frigidaire Professional Series...
Whirlpool gold door falls open during cycle
You can probably get away with getting just hinges for the door if it is not bent also check the latch if it doesn't look broken the just go for the hinges.
Jan 11, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Dishwasher
Make sure that you do not open the door during the wash cycle. Wait until all the cycles are complete before opening the door. Especially don't open the door during the drying cycle.
Mar 20, 2008 | Dishwashers
Soap door won't open during wash cycle
its either the dispenser or the timer/pcb.
Mar 01, 2008 | Dishwashers
Kenmore Elite HE4 Electric Dryer Logo
129 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
