Question about SanDisk Sansa e250 MP3 Player
Connection When I hook it up to my computer it keeps saying it can't read device
I need help!
Posted on Sep 30, 2008
  • 3 Answers
To repair this problem you will usually need to remove all applications for this device from your computer and reinstall the system application cd.
My laptop is not readiny my ipod
Itunes has to be on the computer and also. when you connect it all you need to do is computer and input devices and find the one that says ipod and double click.
Feb 08, 2009 | Apple iPod touch
Device Manager can't read the device
Here is something you can try:
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Jan 12, 2009 | Philips HDD1630 MP3 Player
USB connect
insert the driver cd at the prompt of new hardware discover and install automatically as recommended by your computer
Dec 02, 2008 | Motorola Mobility RAZR V3
Loss of internet connection when going through router
Your laptop seems to be hooked to your neighbours unsecured network automatically and it is going online with that. About comcast, when you connect a router to the modem or a computer to the modem, the modem has to be rebooted to give a valid IP to the connected device. If the modem is not rebooted the computer or the router will get 192.168.x.x IP address which is called private IP address.
Nov 19, 2008 | Check Point (CPWSHCRA6500UUS) Router
Can't get my computer to recognize the device
You may use different USB ports. Make sure your computer USB is v2.0 Computer's Bios and Chipset update could be a possible solution. You may also try Firewire/1394 Connection which is more reliable and faster for video editing and conversion.
Usually in professional use hook up the Camcorder directly to the computer is not very preferred, Using DV converters are more common such as Canopus products as you can find them on
Nov 09, 2008 | Panasonic PV-GS250 Mini DV Digital...
Ipod classic
For it to recongnize, maybe try:
1: go to control panel
2:add hardware
3:connect your hardware device and click "yes i have connected the hardware"
4:scroll down and select install new hardware device
5:select install hardware that i manually select from a list
6:scroll down to windows portable devices
7:and choose MTP device
this should make it so your ipod is now recognised by the computer
Give credit to Randomassist
Nov 08, 2008 | Apple iPod nano 3rd Generation
Recording Device
Pcs needs drivers, and vista is far from being completely stable..
Disconnect the mobile pre...and go here:
then restart and connect.
Rock those beats, and keep me posted.
Dec 11, 2007 | M-Audio Mobilepre USB Bus-Powered Preamp...
Set up of adsl router
Try resetting the device to the default factory settings. Then see if you can get an IP address, either wireless or ethernet, to configure the router through its web interface.
Nov 18, 2007 | Belkin (F5D5231-4) Router
Computer won't read player
It means your player is in Autodetect/MTP. For your computer to recognize the device you should have windows xp with windows media player 10 or 11 / windows vista with windows media player 11. If your computer is in MSC then you will have there a safely remove icon, because your player act like a thumb drive. Note: You said it was working before on that computer try using a different usb port and uninstalling reinstalling your windows media player software. Hope this helps :D
Jul 16, 2007 | SanDisk Sansa e270 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
21 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
