Question about Acer Computers & Internet
Whenever I leave my laptop open and walk away from it, withing a few minutes an Acer movie clip starts which begins with an erie and annoying sound like banshees howling. How do I get rid of this? Brand new Acer Aspire 5315 with Vista
  • phimcgi Sep 29, 2008
    Yeah, pretty simple, eh. I just bought this and certainly did not expect Acer to inflict a screensaver on me. Thanks.
    Problem Solver:
  • 24 Answers
Pls righclick ---properties -----screesaver then uncheck the screen saver.
thank you
Posted on Sep 29, 2008
ACER LAPTOP KEEPS FREEZING
Sounds like your system needs a anti-virus issue. Restart the system hitting the F8 key as it begins to start until it the system gives you option of how to start the system scroll down to "LAST GOOD CONFIGURATION THAT WORKED" click on that. The system should start as normal, once it has go to your anti-virus and run that - then go and do a system restore to a point before it began having the freezing problem. This usually comes from movie sites with pop ups do not click on pop up only go to sites you initiate.
Jan 13, 2013 | Acer Aspire 5610 Notebook
I have a PHILIPS DVP3962. My DVD player used to play where I left off watching my DVDs, but recently, when I turn it off and turn it back on, it starts from the beginning of the DVD. Dose anybody know why...
Resume function is wiped from the player's memory buffer whenever the unit is switched to standby (either with the [POWER] button on the main unit, the remote or turned off at the wall), the disc is removed, or the [STOP] button is pressed twice (either on the front or via the remote).
(The simplest thing you can try is to insert a DVD, play a few minutes of its main title, press [STOP] once, not twice, leave it for 10 minutes, then press [PLAY] - it should resume, and thus continue your movie from where you left off)
Resume is considered 'temporary memory' in DVD devices, and therefore is not intended to store the playback point of the disc permanently whenever power is lost, [STOP] is pressed twice or discs are ejected.
However, this is relatively normal, and is not a fault, but it can be annoying to the user.
Apr 26, 2011 | Philips DVP3962 DVD Player
Sound doesn't turn on after a few minutes!
hey you must be using win xp home edition sp2 - had similiar probs!
either do all the automatic updates available from microsoft.com
or install win2000, if it is an older model u use this might do, but ensure you got the right drivers for all your components and made a backup of all your personal data.
Apr 21, 2009 | Computers & Internet
Problem Bringing up Acer Aspire 3680
Hi i think the problem is with the battery or power supply.When you power up the laptop without the external keyboard and mouse everything is ok, yes?Check that the battery is charging properly and that the charger is doing its job.
Dec 24, 2008 | Acer Aspire 3680 Laptop
Trouble bringing up the computer
maybe your graphics card it stuffed up
"clean filter" prompt
Hi there
Not at all. This promp automatically appears after a certain amount of hours.
To get this message away , all you have to do is go into the Menu and reset the Filter Timer.
Apr 14, 2008 | NEC VT676 Multimedia Projector
How to replace the inverter on a gateway laptop
Fairly easy operation and is standard accross laptops for years.
Get yourself some microdrive screwdrivers
This is all slow and steady..if you get annoyed or frustrated at any stage, walk away for a few minutes and take a breath.
  • Carefully remove the rubber stoppers at the top and bottom of the screen and put aside (you need these to go back in later)
  • Remove the screws and set aside (get a magnet to hold onto them if you can..they have a tendancy to run away)
  • Very gently starting at the middle bottom, lift the bezel up and out slightly. You will hear it pop as it releases.
  • Move around and do one side, then the other side leaving the top intact.
  • When you have the 3 sides free, start along the top. You will have to slide the lid catches out of the way to pop it near those sections and is why it is left until last.
  • After you have the bezel removed, you will be able to see the inverter at the bottom (sometimes on the side)
  • Remove the plugs from both ends being careful not to break any of the connectors, and install the new inverter
Test the laptop before you put it all back together.
Hope that helps =)
Apr 09, 2008 | Computers & Internet
Computers & Internet Logo
57 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
