50" Plasma tv does not come up. Lines are there and then when it warms up it displays ok. Then ater couple of hours then the half of the screen is with lines again.
  • sriram7 Sep 29, 2008
    Dont have the model number now.it is a Panasoninc 50" plasma tv. When I witch on first it displays color vertial lines in one square of the display. The Top portion of the area is empty. The pther half of the display is where horizontal lines come up and it looks like flickering. After warm up for about an hour it looks fine. then it starts the lines in the half where it appeared before.
    New Friend:
  • 161 Answers
The only thing i can think of is that its a bug i would replace the tv....bring it back to place where you purchased it and try to get a refund. it is a plasma tv...they are stil considered a new item and still have bugs.
Posted on Sep 30, 2008
    Master:
  • 479 Answers
The main board of your tv is the main problem,you may coldsolder the main board of your tv.
Posted on Sep 29, 2008
  • tech gurus Sep 29, 2008
    coldsoldering the board will tighten the loose joints on the board and will definately solve your problem.nothing much to worry.
    Brigadier General:
  • 3,614 Answers
What is the tv model# and the maker.. and also did all this line has the same color(what color) and did it change place..?
  • micromaster
    micromaster Sep 29, 2008
    To remove the black bars from the left and right hand side press the
    FORMAT button on the remote. The options available to remove the
    vertical bars are H-Fill, Just, and Zoom.
    To remove the black bars from the top and bottom press the FORMAT
    button on the remote. The option available to remove the horizontal
    bars is Zoom.
    Hope this initial info, helps you.
White horizontal lines covering picture on Toshiba 51HC85
The set uses a Hyper board inside that processes all signals, it is well known for this issue, board no longer available=reason is quite simple : about a dozen tiny surface mounted filter caps on that board with age dry out, at first it will work after warms up as poor caps regain some capacitance and seem to be ok.
Buy a new set, you can send that board out and have it repaired/rebuilt but the last one I saw which was under extended warranty cost about 200 just for the board rebuild.
In the last 4 years Here on Fixya I have encountered only 2 people who were able with instructions had the skill to remove the board and replace those caps, both were top notch computer repair techs.
Dec 09, 2012 | Televison & Video
The bottom half of the screen of my old Toshiba rear projection tv is black. It will usually correct itself after about an hour of warm up. What is the problem and how can it be corrected?
Hi ,it has to do with the light engine.Either the DMD board and this it how it works:http://electronics.howstuffworks.com/dlp1.htm Basically if your tv is a dlp it has a chip that carries 2 million pixels when those chips are in the off position you'll get lines or discoloration.God bless you and your family.
Oct 01, 2009 | Toshiba 50H82 50" Rear Projection...
Sony plasma 50 inch has lines in the middle of screen
It sounds like a bad plasma panel but I would have to see a picture to be sure
Oct 19, 2008 | Televison & Video
I dropped my 26 lcd tv and now my screen is obout half brack or lines in screen can it be fixed
The LCD display had evidently been damaged, you will need to have the LCD display replaced, it can be repaired but is expensive.
Call to the number listed on the owner manual to get a quote for the repair.
You can find parts here.
Oct 14, 2008 | RCA Televison & Video
Mitsubishi VS 50707 ( not 705)
I have the same TV built in 99. My problem is similar but the vertical hold gives out when the tv warms up about 5 minutes. I will attempt to locate the vertical hold circuit and replace any parts I suspects may be the problem. I suspect a cap is leaking or transitor around IC700 is degrading when warm.
Jul 31, 2008 | Mitsubishi VS-50705 50" Rear Projection...
Hitachi 50ux57B
First thing i would do is unplug it for a couple of hours then plug it back in.
Dec 08, 2007 | Hitachi 50UX57B 50" Rear Projection...
Visual
The same is true for rear projection. There may be an adjustment for vertical hold in a hole in the back of the cabinet.
Oct 06, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Black lines and menu problem
Check for bad caps in vertical circuit. Solder any/all bad connects. REPLACE vertical o/p IC w/OEM or better quality. I usually use Tosh,Hit,or Pana. 2)Check/replace tactil switch (menu)on front panel.
Sep 28, 2007 | Toshiba TZ50V61 50" Rear Projection...
Toshiba 50hx81 Squiglly Lines
Bad hyper board = Needs rebuilt, technician skill level high....
Sep 15, 2007 | Toshiba 50HX81 50" Rear Projection...
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
Electro Med Services...
