Question about HP Photosmart C5180 All-In-One InkJet Printer
Ink system failure, and printer turns itself back on..
When I try to print, it says "ink system failure" and it sounds like someone is scratching their nails on a chalkboard. When I try to turn it off it goes through it's shutting down steps then turns right back on, unprompted. The display screen then tells me to use the on button instead of unplugging it (I did!!). This has been happening all morning. I can't get it to print, and I can' t seem to get it to go off without unplugging it. Any suggestions?
  • trinidad1 Oct 15, 2008
    printer says ink system failed
  • HP Master
  • 19,396 Answers
Try the following reset:
Hold the OK and the Help button at the same time. While holding them down, plug the power in. Continue to hold both buttons until the unit shut off.
After shutting down, release both buttons and power on the printer.
Alternatively follow instructions on this document from HP.
Posted on Oct 15, 2008
Printer
Hello Jean,
Here is a link to a reset guide that should get you back up and printing in no time at all.
http://www.ccl-la.com/blog/index.php/hp-photosmart-ink-system-failure-1/
Feb 18, 2013 | HP C6280 Photosmart All-in-One Printer...
INK SYSTEM FAILURE HP 0XC18A0101
Ink System Failure refers to a hardware issue with the printer, however a series of troubleshooting can be tried as a last resort before you get a replacement of your printer.
Try the following:
1. Press and hold the “*” key and then press the “#” key and release both keys.
Now check if there is any message on the printer display, it should display something like "Enter Special Key Combo"
2. Now press and release in sequence the “1”, “2” and “3” buttons.
Now check if there is any message on the printer display, it should display something like "Support"
3. Press and release the right arrow button until the display says “System Configuration Menu”.
4.Press and release the “OK” button.
Now the display should say “Hardware failure status”. If not there already, scroll the arrow Key over to “Hardware failure status”,
5.Press and release the “OK” button.
Now the display should say “Hardware failure status: Clear. Press OK to clear”.
6. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
7. Now Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
8. Turn the printer OFF using the power button and unplug the power cable from back of the printer and wall outlet.
9. Wait for 30 seconds and then replug the power cable
10. Turn ON the printer and let it initialize itself. Then try printing a self test from the printer front panel by pressing the SETUP-->Print Report--->Self Test Report.
This should get it working again.
Jun 03, 2010 | HP Photosmart C6180 All-In-One InkJet...
Ink failure error OXc05d1281
Reset the system by holding down the OK, Cancel, Black, and Color buttons at the same time and turn the 3310 off. You should keep holding the buttons down until the printer shuts off and then turns itself back on. Turn the printer off twice for the printer to recalibrate. Make sure you have new cartridges in the printer so that it can reset.
May 12, 2010 | HP Photosmart C8180 InkJet Printer
Ink system failure oxc1910035 on hp printer c6100 series
This same error started occurring on my printer and eventually it would constantly power on and off. Apparently some defective components were used in the construction of the logic board (see photo). On my C6180 there were 3 failed capacitors (the green cylinders - the puffed top indicates failure) and a 4th from the same manufacturer (TEAPO - many unfavorable web references to this manufacturer). I purchased 3x 330uF 16V and 1x 680uF 10v rated to 105 degrees Celsius (total about 60cents). On the logic board, the capacitors I replaced are labeled C613, C614, C660 and C662. If you are not comfortable replacing the parts yourself (or don't have a soldering tool), you will have to find someone who will. The time to repair should be less than 30 min - I did it in 25 min with only a solder pen. This also fixed the ink system failures the printer was having. A similar fix may apply to other printers
Mar 06, 2010 | HP Photosmart C6180 All-In-One InkJet...
Ink system failure
This is a very common problem if you use refilled cartridges or let your ink run really low. The "Ink System Failure" error is causes by air in the ink feed tubes. We have a step by step guide purging the air from the feed tubes posted on our web site. Go to our site at: www.ccl-la.com , click on the printer repair link and then the HP link. Follow the steps and you should be back printing in no time at all.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jan 05, 2010 | HP Photosmart C5180 All-In-One InkJet...
Can print...ink system failure - followed process but it wont wor
release the right arrow button until the display says “System Configuration Menu”. (on C8100 use Touch Screen)
2. Press and release the “OK” button.
3. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
4. Press and release the “OK” button.
5. Display should say “Hardware failure status: Clear. Press OK to clear”.
7. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
8. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
9. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
10. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
11. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
12. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
13. If the error is still there, or reoccurs replace the unit
Aug 21, 2009 | HP Photosmart C6180 All-In-One InkJet...
Ink system failure
Try following this conversation with H.P;
Christina: Let us perform some steps to isolate the issue and find a fix for it.
Christina: Please perform the following steps and let me know the message that will be displayed on the printer.
Christina: A. - Press and hold the “*” key.
B. - Press the “#” key and release both keys.
Display should say “Enter Special Key Combo”
C. - Press and release in sequence the “1”, “2” and “3” buttons.
CustomerName: ok
CustomerName: screen says "support" R0631M
Christina: Fine.
Christina: 2. Press and release the right arrow button until the display says “System Configuration Menu”.
Christina: 3. Press and release the “OK” button.
Christina: 4. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
Christina: 5. Press and release the “OK” button.
Christina: 6. Display should say “Hardware failure status: Clear. Press OK to clear”.
CustomerName: yup
Christina: 7. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
CustomerName: ok
Christina: 8. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
CustomerName: ok
Christina: 9. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
CustomerName: done
Christina: Fine.
Christina: 10. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
CustomerName: done
Christina: 11. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK. The Printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
CustomerName: made a buncha noise, and it didn't print a diagnostic page
Christina: Good.
Christina: Is the error message still being displayed on the printer?
CustomerName: nope
Christina: Good.
CustomerName: should I try to print something?
Christina: Let us print a self test page to check the functionality of the printer.
Christina: Press Setup menu on the All-in-One then scroll using the arrow key and select Print Report then select Self Test Report.
Thanks
Fame !
May 17, 2009 | HP C6280 All-in-One Printer
Ink system failure
hp photosmart c7288 all-in-one
ink system has failed unable to copy receive faxes or print refer to printer documentation error oxc19a0002
Nov 25, 2008 | Office Equipment & Supplies
HP Photosmart C5180 All-In-One InkJet Printer Logo
123 people viewed this question
Seeker5211
Seeker5211
