Magic Chef CDB6100 Built-in Dishwasher
Problem for Magic Chef CDB6100 Built-in Dishwasher
DIshwasher doesn't drain or fill
By annie8866 on Sep 29, 2008
I have a Magic Chef dishwasher (cheapest you can get). The dishwasher has only been in use for 1 month, and now I can't get it to fill or drain or do much of anything. The water is just sitting at the bottom of the dishwasher from the last wash and it won't drain. Where should I start?
Comments:
Jan 13, 2009
- I eventually had to hire a repair person to come by and look at the dishwasher. $75 later, motor is shot, so they tell me. Not worth fixing, now I am looking for a new dishwasher.
Just really sucks that the dishwasher was only used for 1 month(Can't use warranty because it was sitting in the box for 2 years and it was given to me)
I guess now I need to know what kind to buy without spending a fortune.
Same Problem
Dec 24, 2008
-   It fills properly but drains very little. You can see water going through the disposal and hear it going down the drain but not nearly as before. I check the drain area inside the dishwasher and there was nothing. -   Guest
Best Solution
posted on Sep 30, 2008
Helpful)
rickzilla
Rank: Guru
Rating: 88%, 449 votes
Hello annie8866,
First off.. unplug power and then reapply power to it for a little while to see if a power reset will put it back in the proper sequence.. next, check inside the base for a drain inlet and a filter/screen and clean anything you see out of it.. Then try cycling it without dishes to see if it will run thru a cycle and drain properly.. Its ok to add a cup or two of white vinegar during the wash process to remove byproducts of the wash from the inner components.. Make sure the drain hose is not clogged or kinked up.. Try these things and get back to me if it is still misbehaving..
Comments:
Jan 13, 2009
- Hello again,
Sorry to hear about your situation. I suggest that no matter which brand you buy.. you consider the extended warranty option to make sure it gets repaired down the road, should components like the motor fail. I went thru that with LG front loader laundry products but took advantage of the warranty program and despite being a major pain, got everything resolved to my satisfaction eventually.. The only cost ( aside from the warranty) was downtime of the appliances while the service process was used. This entire forum would not be here if all appliances worked perfectly forever so you wil have to ask around, assess your budget situation, then decide which appliance makes sense for you... I do belive that routine maintenance wll extend the life on any of these products.. Good Luck...
Was this helpful?
Yes
No
Popular Solutions for Magic Chef CDB6100 Built-in
Questions and Unsolved Problems for Magic Chef CDB6100 Built-in
Do you recommend Magic Chef CDB6100 Built-in Dishwasher?
Answer
Answer
my dishes are dirty and the glasess have ground up food all over the out side and the bottom that is... (More)
Answer
Did not finish the cycle last night but continued to make the sound as if the pump was still... (More)
Answer
Hello Mr Fixit, When I turn the dishwasher to the normal clean cycle, I can hear it very quietly... (More)
Answer
I had my kitchen drain snaked. When I tried to start the dishwasher, the water entered, but it... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Magic Chef CDB6100 Built-in...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 905-9505
A&E Factory Service is a nationwide leader in...
A&E factory service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
