Question about Whirlpool GC5SHEXNS Side by Side Refrigerator
Leaking water from freezer
Water is leaking from the freezer and it is seen that there is quite abit of lice formation at the bottom of the freezer...even after fefrosting it manually or removing the ide, it comes back very quickly. Not sure what the problem is..although the settings seem fine...no info in the manual
  • 2 more comments
  • lisoccermom Oct 13, 2008
    My refrigerator started leaking after hurricane Guastav and the electricity went out. It only does it every now and then. The bottom of the freezer fills up with water and now it started making a really loud noise on and off. The refrigerator was fine until the hurricane came through.
  • benz4lt Jan 04, 2009
    Moldel #gr2shkxkt, Freezer accumulates excessive ice on bottom of freezer and evaporator coil on back of freezer. Water will then drip into refrigerator.
  • lgmcguire Jan 30, 2009
    I have Model #ED5PHEXNB00 with the same problem. Our power was off 5 days during Gustav...I'm not sure if that's when problem began, but it may correlate. I'm going to try Solution #1 and see if it helps. Thanks.
  • Anonymous Feb 07, 2009
    Same problem
  • 750 Answers
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
you said, the water is leaking from the freezer and it is seen that there is quite a bit of ice formation at the bottom of the freezer...even after defrosting it manually or removing the ice, it comes back very quickly.
If there is ice forming this means usually an air leak or the door left ope for to long.
or low freon and not cooling enough.
Try pulling the plug for 5 minutes and then restarting the fridge which will reset the system.
Let me know how it goes.
Please remember to leave a rating before you go!
Thank you
Posted on Sep 29, 2008
Why is water leaking from back of kenmore elite refrigerator?
Also, can be a crack on the plastic hose, close to the inlet water valve.
Aug 16, 2014 | Kenmore Refrigerators
Water leaking from whirlpool gold refrigerator
When refrigerators leak water it usally is a sign that the defrost drain found inside the rear of freezer and behind the rear panel of freezer has become clogged with ice or gunk. Sometimes the pan below refrigerator has a crack and allows water to leak onto floor. Please click here=> Leaking Refrigerators Just What may Be HappeningYou will at times see water build up inside freezer bottom especially on bottom freezer refrigerators. This will take a little reading over to understand what may be happening. Click Here=> Leaking Refrigerators
I will be here should you have questions, Thanks Sea Breeze
Feb 16, 2012 | Whirlpool GX5FHTXVA Bottom Freezer French...
The fridge keeps leaking water underneath,the freezer part keeps iceing up down the bottom under the draws,the water is the main problem.
Water in the drain overflowing can be the reason for the water spilling,it can be the defrost overflow or the leak from the evaporator tubing's to the drain. So drain off and check perhaps more condensation is the result of the overflow.
The icing can be related to water formation from the food or leak from the evaporator, high frosting can blow the water inside the freezer.
So set the freezer temp a little lower so that the freezer shuts off than to make it run continuously.
Sep 30, 2010 | Samsung Refrigerators
Ge side by s
found norcold #160107210--new #160107200-----on E-Bay ,under RV Thermostate-----thru seller---- eastcoastrv---Lexington,South Carolina
Oct 26, 2009 | GE Refrigerators
Water leaking from freezer
Check for a blocked defrost drain. Take the panel off at the back of the freezer section and find the small hole at the very bottom center below the cooling coils. Use hot (but not boiling) water and a turkey baster to flush it out until water runs through it. (it will go into the defrost drain pan, where it will evaporate)
This will prevent water from comming out the freezer door and leaking onto your floor and running down your copper pipe to the basement.
May 12, 2009 | Hotpoint HSS25GFP Side by Side...
Freezer is leaking water
Sounds like your icemaker water supply fittings or the icemaker itself is leaking.
May 07, 2009 | Whirlpool Refrigerators
Water leaking and ice in bottom shelf of freezer
Chances are you have a bad seal around the door if it's leaking from the inside which causes the ice to form as well, or if it's leaking from under the freezer you lave a bad heating element that evaporates the water collected in the pan under the freezer or you have a clogged hose that goes to the pan under the freezer which also causes the ice to form because the water has no place to go. Defrost and try to find a way to blow out the hose that goes from your freezer to the pan under the freezer and that should take care of your problem.
Apr 18, 2009 | Refrigerators
WATER LEAK FROM BOTTOM
the ice maker is a common fault on those appliances expensive to replace but quite easly done with regard to the leak eithr the drainage tray is blocked or one of the water feed hose is disconnected or leaking call an engineer
Nov 10, 2008 | Samsung RS2630SH Side by Side Refrigerator
Freezer leaking water
The drain is plugged just below the coils in the back of the freezer. My fridge had the same problem and I found the hose (which can be accessed from the rear bottom) was plugged with mold. Also, i noticed the hose was connected to the water holding pan and was too close to the bottom and easy to plug. I removed it from the connector and just let it dangle in the holding pan.
Aug 30, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
The water input to the water filter is leaking - admiral model GC2224GEKB
my water filter water line is leaking from the bottom in the back of my refrigerater. How can i get to it to repair it.
Aug 19, 2008 | Admiral 26 cu. ft. Side-By-Side...
Whirlpool GC5SHEXNS Side by Side Refrigerator Logo
99 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
