Question about Frigidaire ATF6000ES Front Load Washer
Draining prob. can i straight drain my (model#) GLTF2940EE from washer to outside without any bends in pipe?
  • tnr616 Sep 29, 2008
  • 706 Answers
By code.probably not.. but if you aren't concerned about draining waste water outside.. it will work.. the idea of at least one bend is to keep water in the line as a trap to keep sewer gas from getting back into your house.. Also.. if you run the line without an air trap up high.. the water that remains inside the dishwasher will evaporate out and that's no t good for seals inside it.. I personally wouldn't do it but it is your call... Good luck
Posted on Sep 30, 2008
Water is entering the machine but going out the drain pipe immediately
Drain pipe too low there I usually a mark line on back of washer
Dec 13, 2014 | Washing Machines
Septic vs washout tub?
Waste water from the washer is not pumped out but rather is gravity fed down the drain. You cannot drain the water up higher than the washing machine's drain outlet. You would have to cut into the drain pipe - below the level of your washer's drain outlet - and put in a T that will tie into the drain pipe and allow for some type of connection to be made from your washer's drain hose.
Mar 23, 2014 | Washing Machines
Whirlpool dishwasher not draining
outlet pipe is prob. blocked with lime etc. use a wire coathanger with a half inch bend on the end from the outside to the inside of the house up the outlet pipe
Mar 27, 2013 | Whirlpool Dishwashers
Washer tries to fill, but water goes straight out the drain.
Either washer drain hose is too far down drain pipe, or there is a airtight seal where drain hose and house drain meet. Either would cause siphon effect.
Sep 06, 2017 | Washing Machines
Hi, My kenmore front loader washer (C44072) doesn't drain after the wash cycle. The drain pipe is straight and full of water. I have noticed this problem earlier. Before I was able to force the drain by...
check for a kink drain hose are you have lint clog up in you pump ,you have to take the lower front panel off to see the pump depend on your model.you may have the pump in back of your washer.
Apr 25, 2010 | Kenmore 43142 Front Load Washer
Water goes in then straight out of the waste pipe
The waste pipe is probably too low, this is letting the water syphon out.
Try lifting the outlet pipe higher up, this should solve the prob.
There is a line on the back of the washer, which incates the min hieght for drain outlet.
Please rate my solution.
Thanks.
Nov 24, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Electrolux dishwasher won't drain. Not a clog in the outlet hose or drain pipe.
The drain hose on a washing machinemag-glass_10x10.gif connects the drain pump to a stand pipe, a U-pipe under the sink, or another place for draining dirty water into the sewer. If your washer won't drain properly, the problem is sometimes an object blocking the drain hose, like a pair of underpants, a child's sock, or pieces of something that broke up in the washer.
  1. Unplug the washer and put the plug on top of the machine to keep it out of any spilled water.
  2. Step 2 Take any wet clothes out of the washer and bail the water out of the drum with the bucket. The washer may be too heavy to move if it's full of water and wet clothing.
  3. Step 3 Pull the washer out from the wall enough for you to get behind it.
  4. Step 4 Remove the plate from the back of the washer by taking out all the screws. Different brands and models of washers vary in how many screws hold on the back plate, and not all models require removing the plate to get to the pump where the hose is attached.
  5. Step 5 Locate the drain hose. Of the three hoses coming out of the back of the washer, the drain hose is the largest in diameter and is attached to a drain pipe instead of a faucet.
  6. Step 6 Check the drain hose for kinks and bends. These are often the cause of a blocked or slow-running drain hose.
  7. Step 7 Remove the drain hose from the washer by detaching it from the drain pump. You will need a screwdriver or a slide-lock wrench to open the clasp that holds the hose to the pump, depending on what type of clasp it is.
  8. Step 8 Keep the bucket nearby to catch any water that comes out of the drain pump when you remove the hose.
  9. Step 9 Remove the other end of the house from the pipe it drains into.
  10. Step 10 Bend the clothes hanger open so you can use it to poke inside the hose. Push or pull out the material that's causing the blockage.
  11. Step 11 Replace the hose and run the washer to check if it's clear.
Nov 13, 2009 | Electrolux 24 in. EDW5505EPS Stainless...
My Washing Machine fills and drains at the same time, what can i do? I have just about the same problem. We had put in a new drain line for my washer. This new line has been on for over a month W/O any...
Yes, it is a siphon problem.
Check the hose where it goes through the wall. It may be pinched and cutting off air.
If air cannot enter the hose it will siphon. If the hose is too low it will siphon.
May 23, 2009 | GE Washing Machines
Machine filling and then immediately draining
Hi You need to higher your outlet pipe on the back of the machine there is usually a clip to hold the pipe in place 3/4 of the way up the machine so it looks like a u upside down its should stop the machine from emptying straight away
Apr 29, 2008 | Zanussi ZWF1430W Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
59 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
