Question about Native Instruments GUITAR RIG
Just get clean tone through NI Rig Kontrol 2
I plug everything correctly. I plug my my guitar in RK 2 input and headphones at RK2 outputs. After launching Guitar Rig 2.2 or Guitar rig 3.0, I get no output. after 3 seconds, I hear the clean sound of my guitar. Please, help me. it was 3 mounths that I couldn't play guitar!!! any suggestions would be appreciated.
thanks
You need an asio driver for your rig kontrol.. you are probably set to use DirectX drivers, which will give you latency of 50ms and waaaayy beyond... By contrast, ASIO drivers will give you sub-10ms latency... Most people can play at around 7ms, but im picky, and no more than 5ms will do for me..
Go download the drivers from NI site, and try those.. if that doesnt work, there is ASIO4ALL... google and read.,. this will help ya
keep playin
DJYoshaBYD
Posted on Aug 22, 2009
Can I connect guitar to my Harmon Kardon receiver
Sorry. They are not compatible. The headphone jack is an output but you need an input for a guitar or bass. You will certainly damage the HK if you continue. There are no compatable inputs on the HK. The inputs are meant to be used with a 300mv output device, such as a CD or DVD.
Oct 02, 2013 | Harman Kardon Audio Players & Recorders
I have a Frontman Fender 25R, it has a power, the auxilliary input is working (the RCA, red and white ) sound is produce, when I plugged an electric guitar on the 1/4 input there is no sound coming...
You actually have the "B" version as the original 25R doesn't have RCA jacks. Anyway, on with your problem...
I want you to do a test: With a set of headphones plug them into the preamp output and then play your guitar... don't expect much loudness, it may be very faint and will ONLY be in one of the sides of the headphones. This tests the preamp section... have the guitar volume wide open.
IF you can hear the guitar that way, then the switch contact on the PA INPUT jack (not the preamp output) is not making contact. These jacks are really poor and the problem is not that uncommon. Fix is to open the unit and increase the spring tension on the contact or replace the jack. Never use the jack as they worsen evertime you plug something into it.
Note that the failing switch symptom MAY be broken soldering in the vicinity of the jack so look for that also. And also check the soldering of the guitar input jack as that is a common problem. Always loop your guitar cable through the handle so tripping over the cable doesn't break the jack by yanking the plug sideways... another common problem.
Mar 25, 2011 | Fender FrontmanTrade 25r Combo Guitar...
Bussing sound comes out the tube,even when it it connected correctly
Make sure you have the correct power adapter, not a substitute. Make sure your guitar is outputing enough... You LIKELY will need a guitar that has a preamp in the guitar, (not a passive pickup guitar). This device is nothing more than a small amp that drives a speaker which the sound travels up the hose. If your guitar creates a buzzing noise, then this device will do that too... Plug a set of headphones directely into your guitar to verify the sound is clean... NOTE, only one side of headphone will have guitar in it if the headphones are stereo type.
Jan 09, 2011 | Rocktron Banshee 2 Guitar Talk Box Talkbox...
I've just got an ampkit link and downloaded the free version of the app in my 2g ipod touch, the problem is when I try to play i dont get any input or output signal. I've checked my cable and the guitar...
If you touch the area where the input and output level bars are (lower right of the screen) it will open a page called "Input Options".
Make sure the input and output gains are up about 75%. Usually the output gain is about 5-10% lower. If you're getting a button that says "No Input" where the input/output level bars should be on the lower right corner, it is telling you that your iPhone headphone/mic jack is not sensing the line from the Amplink. Leave everything connected, and exit the Ampkit program and then start it again. It should reopen with the level indicators showing. These connections are all finicky.
Jan 06, 2011 | Peavey AmpKit LiNK High Fidelity Electric...
I PLUGGED THE GUITAR INTO THE GUITAR INPUT AND PLUGGED ANOTHER JACK INTO THE SEND UNIT TO MY AMPLIFIER BUT CAN'T HEAR ANY SOUND EVEN THOUGH I GET A READING THAT SHOWS SOUND IS HAPPENING. THE OL LIGHT IS...
try this: plug a stereo headphone into send & check if you get something on one side of the headphones (should be left side) if yes check the cable you use, it's possible that a mono plug (as used for guitars) is disabling the send output, using a stereo plug & adaptors may work (especially if you get the sound in the right side of you headphones check also the manual you may find a description how to connect/insert a guitar effect when recording or live mix
Nov 12, 2010 | Tascam Dp-02cf Digital 8-track Recorder
Output jack
Have you tried another cable between amp and guitar? Usually the cable goes bad first. Have you tried another amp or possibly tried another guitar on your rig? If this still indicates that your guitar's Standard 1/4" TS Jack is noisy, remove the oval cover over the jack and check the solder joints for the wiring. Follow the wires back to the tone and volume pots and check those solder joints. If everything is secure...Plug in, power up and check for noise while turning the volume pots stop to stop. If the pots make a scratching noise, shut down rig and unplug the guitar. Get a can of spray contact cleaner with a small extension tube (available at electronic shops) to spray in the pots while turning them. (May have to remove pots fom the guitar to get at small openings on side of pot can.) Spray jack and test for noise. Jack STILL
noisy...If you can solder...unwire old jack, remove from guitar, take to electronic shop, match to Standard 1/4" TS Jack, install in guitar, resolder wire connections and test. If you cannot solder...take guitar to
a reputable shop or dealer that does this repair. Good Luck! P.S. The
spray contact cleaner can be used on the amp jack, pots and switches
too...just make sure the amp is unplugged from the power supply before
doing any spraying.
Jul 14, 2010 | B.C. Rich Nt Warlock Electric Guitar
My Tascam CD GT1 mkii guitar trainer is doing everything except when I plug my guitar into the unit, I can not hear my guitar?
Here is the manual if you don't have one:http://www.tascam.com/details;9,21,23,19.html Make sure your guitar cord is working. Make sure your are plugged into the Guitar/Mike input jack.Do not connect a guitar amp to this jack via line out on the amp or otherwise. Set the Guitar/Mike switch to Guitar. Use the Input control to adjust the level of the input.Adjust your Headphone level using the Output control.Carefully read pages 12, 13, 14 and 15 of the manual.There are various combinations of controls that would make your guitar too quiet to be heard. Example: Mix Balance page 24. Let me know if this helps.
Nov 29, 2009 | Tascam CD Gt1mkii CD Guitar Trainer
What is wrong with my audio plug?
Yep, you blew it up, all right.
The headphone jack in the laptop is a low-level OUTPUT which goes TO a set of headphones or the INPUT of an amplifier. You went the wrong way and fed a high-level signal (the guitar amplifier OUTPUT) INTO the laptop.
The electronics inside the laptop are not made to deal with the high level you fed in, so it's been damaged. Ever blow out a set of speakers with too high a volume? That's basically what has happened here.
To fix the problem and get your sound back would require a new system board.
Jan 19, 2009 | Computers & Internet
No effects
Double click on your speaker icon in the task bar next to the time (Or go to audio in control panel and find advanced settings)
Look for microphone and line in and mute them ...
Then click options, Goto advanced and choose recording and click ok ... Look for the input your using and turn that up as much as you need.
Then check guitar rig ... All should be fine now
Jun 25, 2008 | Native Instruments GUITAR RIG
Native Instruments GUITAR RIG Logo
450 people viewed this question
Top Native Instruments Computers & Internet Experts
ray gallant
 Chuck N
Chuck N
Dan Shibata
Dan Shibata
Are you a Native Instruments Computer and Internet Expert? Answer questions, earn points and help others
