Question about Frigidaire GLTF1670A Front Load Washer
Washer will not spin
Washed 3 loads yesterday just fine. On the fourth load, the washer stopped spinning. Gets stuck in "spin" and wont do anything. Will drain when put on drain cycle, and will fill and rinse. Just stopped spinning and gets stuck there doing nothing. Washer will fill with water but will not agitate. Manually move the dial to spin and it will drain, cleaned drain and found several coins, I can feel the rubber coupling and easily detect when there is water inside but upon draining the pump is definitely doing the job of draining. When it is supposed to agitate or spin I can hear the drain pump making quite a bit of noise but it does drain. There is good tension on the drive belt and I can see the winding spin inside the motor if I manually turn the belt but I never see the motor turn on its own, it appears there is no signal being sent to the motor.
  • 1 more comment
  • jwfifield Jan 02, 2009
    I have a Frididaire Front Loan Washer that's 2 years old. Did 4 loads of laundry today just fine. Went to remove 5th load and was soaking wet. Put washer on Spin only to remove water and nothing happens. The washer will cycle through a normal wash cycle just fine, timer counts down, drains, fills, and agitates, just will not spin. What is wrong with it?
  • GolfGirl711 Jan 10, 2009
    Same problem here- I just want to know, is it worth fixing or should I buy a new machine?
  • Anonymous Mar 26, 2014
    It drains the water, but does not spin. just beeps, you can hear the motor trying, but won't spin
    Problem Solver:
  • 10 Answers
After doing extensive research, I found out it is the door lock assembly. We went to our local appliance parts store and bought the new assembly. If you are handy enough, you can replace it yourself. You have to remove the entire front panel of the washer, but it only costs $50, so that is a lot better than buying a new machine. After we got the new assembly installed, the machine worked like new. The guy at the parts store said the replacement part is a lot better than the original piece and hasn't seen one fail yet.
Posted on Jan 22, 2009
  • 26 Answers
I had what I believe was the same problem, at least same symptoms with my Frigidaire FWT445GES2 washer. It was caused by a broken door latch. A simple fix and an inexpensive part. Unfortunately I paid Sears about $70 to learn this. Look at the latch and if it is broken, replace it. If it is not broken then the cause for the problem must be different from mine.
Posted on Jan 21, 2009
    Sergeant:
  • 208 Answers
Hi,There are several causes for this problem. Check these.
  • No spin at all: the lid switch is fried. You test it with your meter. There will be a motor which spins the washing machine's drum. If you don't hear the motor running, then its the lid switch which would have been broken and needs replacing. A bad lid switch wil interrupt the spin cycle.
  • In the Whirlpool washers, a common problem is that thelid plunger stops making contact with the lid switch. Use a pen tomanually press the lid switch actuator (with the lid up, duh). If thewasher spins...well, you know the rest.
  • Older (belt-drive) Whirlpool: the spin solenoid isburned out or has cut wires. Ohm out that solenoid (20-30 ohms) andtest with a test cord. Make sure the wires are intact by giving them alittle tug. If this is OK, you may need to adjust/replace the basket drive.
  • Timer is fried. On older timers, it's sometimespossible to run an external jumper to replace the bad internalcontacts. Usually, however, the entire timer must be replaced. The onlyway to confirm is to use your meter and wiring diagram.
These are the causes that have to be inspected.You can also visit this site www.whirlpool.com/custserv/index.jsp
Hope my info solves your problem,Thanx for using fixya,Good luck.
Posted on Sep 29, 2008
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 71 Answers
My mum had this problem. I think it had something to do with the barrel coming loose.. - get a plummer ;)
Code LE on wm2277hb washer
I would pull the back panel off, and do a general inspection. When moved, things can get moved out of place by bumps and bouncing and may be apparent by inspection. Most front loaders use either a variable diameter pulley or a gearbox to change the drum rotation speed from slosh to spin. Take a look at the belt that on the pulley on the drum 'axle' and see if there is an apparent mechanism to 'shift into hi gear'. The code is just reporting that it could not spin. A visible inspection may reveal the cause.
Mar 15, 2014 | LG WM-2277HW Front Load Washer
Where is the filter on my Kenmore 44072 washer?
you have a sock or simler item stuck in you pump .adrianxxx
Jun 19, 2012 | Kenmore 44072 Front Load Washer
Whirlpool Front Load Washer (LHW0050PQ) not spinning
Use a quarter inch nut driver to remove the bottom panel. A tech sheet should be under there that will give diagnostics. Open the pump filter and check for objects.616c06e.jpgea4423e.jpgfb90284.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer stopped during spin cycle
Hello, try to checked the pump filter, and the pump is actually working. then I would suspect a draining problem.
If filter clean and pump works fine then it could be a control module fault. if this were the case, then it would probably be wiser to purchase a new washer.
Thanks
Jun 04, 2010 | Whirlpool LTE5243D Top Load Stacked...
Washer gets to spin cycle and stops
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 14, 2010 | GE WSM2700D Top Load Stacked Washer /...
Washer won't spin. Washed bath mats (small) and
Read a post from someone else on this - turned out it works fine, just wouldn't work with the small wet load. I added towels to the bath mat load, washed them, it spins fine. Washed clothes & that worked fine too. Yay!! Not broken. Just not found of small loads of bath mats!
Jan 22, 2010 | Frigidaire ATF6000ES Front Load Washer
Front loading washer won't spin
my amana washer wont spin and does not drain
Sep 11, 2009 | Kenmore Washing Machines
I fixed it yesterday. After checking the continuity of my lid switch and pressure switch and finding them ok I removed the tubing from the pressure switch and applied air (blew into it). There was a clog and blowing on it removed it for now. Apparently the pressure switch was telling the machine that the tub was full of water and wouldn't let it start the spin cycle. I ran three loads last night and it worked perfect. I may have to remove the connection on the side of the tub and clean it properly if it clogs again.
Mar 23, 2009 | GE Washing Machines
is the door lock lit make sure the door is closed all the way make sure the dispenser door is closed all the way their is a magnetic switch in it that will not let the washer spin if its not closed it also will not spin a small load try adding a couple of items let me know if this does it or not
Jan 11, 2008 | Frigidaire GLTF1670A Front Load Washer
Washer problems
if it wont drain , check your lid switch, check out your motor coupler, if it will not agitate and spin, replace your motor coupler, if it agitates and dont spin, replace your lid switch.
alot of times the washer will drain but we hurriedly cut it off when we hear noise or the water is out but it never spinned and so the clothes are soapy wet...
Nov 12, 2007 | Roper RAX7244KQ Top Load Washer
Frigidaire GLTF1670A Front Load Washer Logo
446 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
