Question about Kenmore 24032\24036 Top Load Washer
Kenmore lid switch
Thank you for your help and quick response. the problem was the lid switch and i have purchased a new one at a local parts store. now i am confused on how to get the top of the machine off as to replace the switch. any suggestions.
  • hfactor23 Sep 29, 2008
    thanks for your help. the unit is repaired and up and running. my wife is also under strict instructions not to slam the lid any more. couldnt have done it without your help. very much appreciate it
  • 5,911 Answers
If this is a Kenmore top loader, you have to remove the exterior case of the washer to get to the lid switch. The following link explains how:
http://www.fixya.com/support/r385198-replacing_lid_switch
The entire case comes off as one assembly on these washers. Believe it or not, it is actually much easier and rather ingenious. Just make sure you pay particular attention to reassembling the unit when completed. If you do not get the washer case back on the frame correctly, the retaining clips will not insert properly. Good luck to you and let me know if you require additional assistance. I hope this helps you.
Posted on Sep 29, 2008
  • Jeff Rockwell
    Jeff Rockwell Sep 30, 2008
    Congrats on fixing your washer! I'm glad I was able to assist you. Could you do me the favor of rating the solution if you feel this resolved your problem? Keep me in mind for any future problems you may have. I'll be happy to assist you again. Thank you.
Washing machine model # 20707990 . fills up with water but does not drain. What could be the problem?
THe leading cause of the Kenmore washer not draining is a broken lid switch. http://www.fixya.com/support/r9939128-whirlpool_kenmore_estate_kitchen_aid
The part number for the lid switch on your model is 3949238 it could be purchased from your local appliance parts store or online at;
searspartsdirect.com
apwagner.com
partselect.com
apdepot.com
repairclinic.com
GENE
Sep 09, 2011 | Kenmore Washing Machines
Washer model#11092282100 won't drain or spin
The leading cause of the water not draining and the washer not spinning is going to a broken lid switch. This tip i wrote about the lid switch will explain how to check if its broken and also how to replace it. http://www.fixya.com/support/r9939128-whirlpool_kenmore_estate_kitchen_aid
The part number for the lid switch on your model# is 285671 it could be purchased at your local appliance parts store or online at;
apdepot.com
partselect.com
repairclinic.com
apwagner.com
GENE
Aug 31, 2011 | Kenmore Washing Machines
Kenmore washer 110.92587210 lid switch dropped away from under the lip
The lid switch asm. is broken and would need to be replaced.This youtube video will show you how to replace that lid switch. http://www.youtube.com/watch?v=MFsvLiuTniU
The part number for the lid switch for your model number is 285671 it could be purchased at your local appliance parts store would have one or it could be ordered online at;
apdepot.com
repairclinic.com
apwagner.com
partselect.com
GENE
Aug 28, 2011 | Kenmore 24032\24036 Top Load Washer
How do i remove my old lid switch and put in a new one
this video will show ya exactly how to replace the lid switch.The number ya have though isnt the model number i can be found under the lid toward the back just above where the water enters the tub order the exact part# by going to searspartsdirect.com to find the part# then you could either order it directly from sears ora local parts dist. that could be found by a quick look in your local phone book or a google seach for parts dist. in your area watch this video.......http://www.youtube.com/embed/MFsvLiuTniU" frameborder="0" allowfullscreen>
Jul 13, 2011 | Kenmore 24032\24036 Top Load Washer
My washer wont drain or spin
it has a bad lid switch.....a 20 dollar part from your local appliance parts dealer take the model and serial down and call the parts store ask for a lid switch for your model
Oct 25, 2010 | Kenmore 23822 Top Load Washer
My kenmore washer will run the wash cycle and then
Probably needs a lid switch. If it thinks the lid is up the machine won't spin and the cycle stops. Replacing the switch is not difficult. This page shows the procedure for removing the cabinet to access the switch. (It sounds scary but it actually quite simple.) You can find replacement switches at a local appliance parts store or from several online sources. If you don't feel up to doing it yourself, this repair won't cost as much as a new machine if you have it serviced.
Hope this helps get you spinning again. Thanks for using fixya!
Feb 20, 2010 | Washing Machines
How do I get to the lid switch to replace it?
It sound like you need a new timer which can be purchase at an appliance parts store. I hope this helps. Don't forget to rate my answer.
Feb 06, 2009 | Kenmore 23822 Top Load Washer
Kenmore series 80 washer won't spin or drain but will agitate.
you will need to replace the plastic piece that triggers your lid switch hopefully you havent damaged your lid switch (probably not) the are easy to replace and very inexpensive less than ten dollars usually you can purchase one of them from your local Sears or just about any appliance store they just push in to clip you dont even need any tools thanks hope this helps you
Dec 31, 2008 | Washing Machines
90 Series Kenmore Washer Not going to spin cycle not draining water
I've had the same problem...you can purchase a replacement lid switch at your local appliance parts store for about $35. Fortunatly, the sales person at the appliance store had diagrams and provided instructions to replace the switch. I was able to finish the job and fix the switch in less than 1 hour. Good Luck.
Oct 25, 2008 | Kenmore 15864/15862 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
24 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
