I have a Samsung hdtv model no. LN-82338W, and the picture is in black and white. I was trying to play my wii and I know its not my wii being broken because I plugged it into another tv and it worked fine. I tried switching inputs and I also tried using a component cable instead of the wii cable and it is still in black and white. Can it be fixed?
SOURCE: poor picture with hdtv Hitachi 37HDL52 plasma
What EXACTLY is wrong with the picture? Is it black and white? Green? not there? distorted? need info...
SOURCE: Rainbow color effect appears when Samsung LCD plays Wii or DVD
Hello, I have a question which video inputs are you using for your DVD and Wii connections? The reason I ask is because this sounds like video distortion cuased by noise. If possible can you send a picture of the screen when it has this problem and send which video ports are being used? If it is noise in the video you may have a saw filter problem, or a decoupling issue. In any event I'll know more once you send those pictures and which inputs you are using for your DVD and Wii. Thank you, Shuttle83 http://www.electron-age-technologies-llc.com [email protected]
SOURCE: My Samsung LN-T4066F TV is only showing colored
Ur backlight inverter board is dead.
U need a new one.
Testimonial: "Thank you so much. I had looked on the Samsung website but couldn't find anything that matched my problem. You mean new tv right?"
SOURCE: I cannot get my PC sound to play through my Samsung LE32457A HDTV
I hope 3.5mm to twin phono would have plugged in headphone jack of PC to get sound for TV, right?
Reduce PC volume level up to zero and increase it very little bit to get sound in TV.
TV is getting excessive sound level from headphone jack and causing mute circuit to activate to avoid any internal damage.
Testimonial: "Good advice, but didn't work. :("
