Is a hot modem a problem?
I recently subscribed to AT&T DSL and am using the modem provided by AT&T (Motorola 2210-02-1006). It's a small motorola. I am also using a Belkin router. I notice that the router is slightly warm but the modem gets very warm -- almost hot. I don't know if this is normal. I've had no trouble with connection or speed. My concern is the very warm modem. Could this cause a fire or damage my computer? Any thoughts or help on this? Thanks
  • 2 more comments
  • Anonymous Nov 06, 2008
    My Motorola was always hot as a firecracker, then it died after 2 months. Best Buy would not take it back since it was over 14 days and washed their hands of it. They told me to go back to Motorola for a replacement.
    This modem apparently has a overheating problem due to a lack of ventilating provisions in the case. I would recommend unplugging the modem after use.
  • jimcoates Dec 07, 2008
    I have the same modem, Motorola 2219,
    with the exact same symptoms ... very warm, almost hot. I do unplug mine at night because it makes me nervous.
  • Anonymous Feb 24, 2009
    Mine also stays very warm, and I'm also having problems with my internet connection. I have unplugged and powered back up so many times, only for it to happen again after a short while. I'm beginning to think I have a bad modem.
  • Penny Kunzman Aug 15, 2013
    Solved my hot modem and hot router problem. Bought a cheap laptop pad (with the fans) at Big Lots ($8), plugged it into my router, set modem and router on it. They don't get hot anymore.
4 Suggested Answers
SOURCE: Need to hook up Belkin G wireless router to Motorola SB5120
I have a Motorola SB5100 Cable modem and i have a belkin N wireless ROuter..i have conncted the wire from modem to router and computer to router and it doesnt work??what do i have to do??
Posted on Feb 26, 2008
SOURCE: Recently I subscribed ATT DSL Service conflict IP Address
the motorola modem that att is using uses 192.168.1.x subnet. log onto your router and change it to 192.168.b.x where b is any number between 2 and 254 (just not 1). You should also log onto the modem and change the setting that allows it to share the external ip address with the router. You will need to do this if you plan on accessing your network from the internet.
Posted on Jun 13, 2009
  • 74 Answers
SOURCE: xbox 360 on gears or war two sat firewall is two
Disable the firewall completely. When your done with the Xbox enable it again so you have less chance of getting a virus.
Posted on Oct 18, 2009
Dsl light goes beyween blinking green, then goes solid red, then back to blinking green. Cannot connect to internet anymore.
The modem cannot get a signal from your service provider. The DSL light is an indicator if your modem is communicating with the network of your service provider. DSL light should always stay solid green. Try contacting your service provider. It might also be an indication of a bad modem.
Aug 31, 2011 | Arris 221002 DSL Modem Southwest Region...
When plugged in no llights on modem motorola 2210-02
If there are no lights whatsoever illuminating when you have the modem plugged in to the electrical outlet, then this is going to indicate either a faulty power cord or a faulty modem. If you received this modem from your service provider, you may wish to contact them for assistance.
Aug 23, 2011 | Arris High Speed DSL Modem
Can I use motorola sbg900 wireless cable modem with at&t DSL internet service?
No, the AT&T service must be paired to the service by AT&T and therefore you will need to obtain a DSL modem directly from them. They don't usually charge for the DSL modem and offer the wireless service with their DSL service free of charge.
Jul 30, 2011 | Arris SURFboard SBG900 Wireless Router...
Hi Currently i am using internet Type: Broadband provided by Local Cable operator Modem:Motorola SB5101i Connection type: PPPoE [with username/password] Using with: Dell inspiron15 Laptop Location:...
There is a configuration facility included with the modem that you should be able to access to help troubleshoot the connection.
The Cable Modem has three active interfaces, the HFC, the Ethernet and the USB and each
interface has both a MAC and an IP address associated with it. When operating normally it is the
IP address of the HFC interface that is used for diagnostic access to the modem. However the IP
address associated with the Ethernet interface is always available to the client side network,
unless it has been disabled by management command. This means that a PC on the client side
can access the WEB pages within the modem using the reserved address 192.168.100.1. This is
a non-routed address so it cannot be reached from the Internet (routed) side of the network
The SB5100 family of modems contain an internal DHCP server, which is active until the modem
registers with the CMTS. In the case of a problem that prevents the modem from completing its
registration, the modem can still give an IP address to the client PC to enable diagnostics access.
This address is given with a very short lease (around 10 seconds) so that as soon as the
registration does complete the client PC obtains its proper IP address from the core network
DHCP server.
Mar 15, 2017 | Arris SURFboard® SB5101 Cable Modem
No dsl light, thus no internet connection
check connections of the modem, power recycle, then call your internet service provider.
Dec 17, 2010 | Arris High Speed DSL Modem
Ethernet Hub EN104 Hit and Miss.
Are you sure you got a compatible modem? They are not all alike.
Apr 05, 2017 | SMC Model EN104TP 4 PORT 10 BASE-T...
New modem will not work with my Belkin F5D7230-4 router
I would start by re-setting the modem. Disconnect the power for the router and modem. Wait a minute or two. Plug the modem back in first. Wait for the modem to complete communication with your internet service provider. When all communication lights are good on the modem then plug the power into the router. It amy take a few minutes to get all the lights. Hopefully this will allow the DHCP to release from the old router and renew to the new one. Make sure if your internet provider requires any manual configurations that they are properly configured in the new router.
Sep 12, 2009 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Qwest DSL / Issues with Motorola 3347
The modem overheats due to lack of ventilation. I fixed mine first with Ice packs then a small twelve volt fan and some inexpensive heat sinks glued to the top of the two processor chips.
You need to cool the modem down!
Jul 24, 2009 | Netopia (3347NWG-VGX) Wireless Router...
Computers & Internet Logo
1,510 people viewed this question
David Payne
David Payne
