Question about Brother MFC-7820N Laser Printer
Mfc 7820n - scan
Scan function not working. I called once before and they gave me a DOS command line that served as my work around. Can you provide me with that again?
What was the work around Dos command?
Posted on Nov 04, 2008
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 71 Answers
I would imagine only they can provide you with that.
Posted on Sep 29, 2008
Im using the Brother MFC 7820n at a hotel. how do i fax? i've tired 9+1+area code+the number, 9+area code+the number and a few others but nothing seems to work, what am i doing wrong?
Depends on the hotel.
Some have a specific dedicated line that allow direct dial (no 9). Some block long distance calls and required the use of a calling card.
Otherwise, dialing 9 should work.
Can you hear the dial tone? What kind of sound do you hear when it fails? Is ti list a fast busy signal? Or do you just hear nothing?
If they have the speaker off, try to call your cell phone from the FAX just to see if it can make an outbound call at all.
Also, try tracing the wire from the fax machine. Make sure it is plugged into LINE and not PHONE. (or the jack with the picture of a wall jack, not a picture of a phone). Some hotel patrons disconnect FAX machines to use the phone line on their laptop modem and then neglect to properly reconnect the fax machine. Also make sure it is connected at the wall.
Apr 20, 2011 | Brother MFC-7820N Printer
Brother MFC-7820N Printer--vertical lines
You need to clean the scanner glass. Also known as the strip glass. It is a 1 inch wide strip of glass that runs from the front to the back. Your documents pass over this glass when they are scanned. Some of the wax crayon probably smeared off onto the glass and now when you scan the scanner sees these marks as stationary and thus records them as solid lines. Just look into the scanner section where your documents are fed in or depending on model, some are just to the left of the large original glass.
Good Luck and thank you for using Fixya.
Feb 25, 2010 | Brother MFC-7820N Printer
How do I scan photographs on my Brother MFC-7820N. I've never used this feature. I have a Mac computer.
Hi friend,
You just install scan software in your computer. scan option will visible on your desktop then click on your scan option then ...you can scan your document.......
Dec 20, 2009 | Brother MFC-7820N Laser Printer
Cannot send or receive faxes
Try to call from your fax if u make calls then the line is ok,if not check the line.check the cable have 4 pin ,Take the user settings in the reports menu,check and confirm the mode is "tone" if its "pulse" change it as Tone.
May 05, 2009 | Brother MFC-7820N All-In-One Laser Printer
Not able to send fax to an eFax number
I've had the same problem before. I don't know if it will solve your problem directly but I can offer a work around or two.
1. I have an efax number but with a company called callwave.com , I fax stuff to other customers using callwave and my MFC 7820n completes each fax successfully. So if you can get yourself a callwave efax number you can fax to yourself and forward fax as an email to your intended party.
2. Or, you can use your mfc 7820n to scan your fax docs as a pdf directly to your computer and then emailing them to your intended party.
Unfortunately it might be a brother issue because at the office when I use the hp fax machine instead of the brother machine, the hp faxes to efax numbers without a problem.
Sep 05, 2008 | Brother MFC-7820N Printer
BROTHER MFC-7820N-SCANNER FUNTION NOT WKING
Is it still working as a copier? If so then there may be something wrong with the printer's network interface or the networking at that jack or a problem with your switch. Have you tried moving it back to the old location or plugging the network cable into another wall jack, or changing ports on your switch?
Jun 24, 2008 | Brother MFC-7820N Laser Printer
Scanning multiple pages
Use paper port software which is part of brother software suite but under different menu (check out under start - programs - paperport
Feb 05, 2008 | Brother MFC-7820N Laser Printer
Brother mFc 7820
I had work done on my laptop. I have a Brother MFC 7820N printer, scanner,fax,copier. I cannot find my cd for setting the drivers to have my laptop use the 7820N. Where can I pull the information down on line to enable my laptop to use my printer?
Shaun at WardLF357@aol.com:
Oct 17, 2007 | Brother MFC-7820N Laser Printer
Brother MFC-7820N Laser Printer Logo
79 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
